EFI NO 2 no power in the mornings or humidity like rainy days
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rickydiazpr, Aug 5, 2024.
  1. Aug 5, 2024 at 3:31 PM
    rickydiazpr
    rickydiazpr [OP] Member
    Ricardo
    Tacoma 2010 2WD 2nd Gen V6
    Hello,
    In the morning my Tacoma cranks but won't turn on. Doing these fail I noticed the Fuse EFI NO 2 is without power, i Already changed the EFI relay but nothing
  2. Aug 6, 2024 at 11:13 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The circuit goes like this:
    Battery >> 20A EFI Fuse >> EFI Relay terminals 5 and 3 for the contacts and terminal 1 for coil terminal 2 is ground >> 10A EFI No2 Fuse.
    I would probe each of these with a volt meter or test lamp to locate where the voltage is goes missing.
    #13 socket below is the EFI Relay Socket and it shows the terminal numbers.
  3. Aug 12, 2024 at 10:11 AM
    rickydiazpr
    Ricardo
    Hello,
    Just power in 5 and ground in 2 and 3. 1 is without power
  4. Aug 12, 2024 at 1:58 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    If you are never getting power to terminal # 1 on the EFI Relay then the ECM is never commanding the relay to energize. The EFI # 2 gets power when the EFI Relay is turned on and from what you said it isn't. Have you checked the immobilizer ( Car with a key in the center under the stereo )? What does it do when you insert the key Blink, Steady lighted, or no change?
    rickydiazpr[OP] likes this.
  5. Aug 12, 2024 at 2:04 PM
    rickydiazpr
    Ricardo
    when i insert the key, the car with key, stop blinking
    the curious thing is that happen just in the morning and cold weather
  6. Aug 12, 2024 at 2:06 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Jimmyh likes this.
