Egr delete
Discussion in 'General Tacoma Talk' started by Tmar04, Feb 12, 2025.
  1. Feb 12, 2025 at 5:23 PM
    Tmar04
    Tmar04 [OP] Well-Known Member
    Terry
    2004 Tacoma prerunner
    Anyone have any experience doing egr delete on gen 1 taco? Just checking, thanks
  2. Mar 5, 2025 at 11:02 AM
    natecastar
    natecastar Well-Known Member
    Any specific questions? I did it and think it bit me in the butt. I suspect it's causing ecm to make the evap canister purge valve remain open causing fuel leak.
    Aside from that install is was pretty straightforward except for the hoses, you can remove one entirely and plug remaining one underneath the throttle body.
    My kit came with 2 resistors, my truck is throwing a code for insufficient exhaust gas recirculation, thinking my connection is bad or I have the wrong resistor installed.
  3. Mar 5, 2025 at 11:04 AM
    Bishop84
    Bishop84 Well-Known Member
    You just block it off, easy peasy
    We cut a coke can the same shape as the gasket and dont put a hole in it.
