EGR Temp Sensor
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yotamachine, Oct 20, 2020.
  1. Oct 20, 2020 at 7:27 AM
    Yotamachine
    Yotamachine [OP] Well-Known Member
    2001 Yota
    Hello community,
    Again, I am here for the expertise and advice. This time, I am hoping to see if someone can share best practices to cleaning the EGR temp sensor that is attached to the plenum. I tried looking it up here but only found info on EGR valve cleaning. Thanks in advance.
  2. Oct 20, 2020 at 7:04 PM
    97tacoma
    97tacoma Active Member
    97 tacoma sx 4x4
    Wire brush
  3. Oct 21, 2020 at 2:06 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Cleaning deposits from the coolant ??
    I use the wire wheel.
  4. Oct 21, 2020 at 7:18 AM
    Yotamachine
    2001 Yota
    Deposits around the sensor attached to plenum. It’s different from the EGR modulator but it seems like using a wire brush might be the way to go.
  5. Oct 21, 2020 at 8:08 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I used a wire brush on mine, worked pretty good. Just be gentle with the wire.
    1997tacomav6 likes this.
