Egr vacuum modulator
Discussion in '1st Gen. Tacomas (1995-2004)' started by 02taco9487, Feb 29, 2024.
  1. Feb 29, 2024 at 5:15 PM
    02taco9487
    02taco9487 [OP] New Member
    Casey
    2002 Toyota Tacoma sr5 ext. cab
    3.5” lift moto metal 17x8
    2002 Toyota Tacoma 2.7L
    Noticed my truck lagging no power when driving wouldn’t go over 2500 rpm’s and noticed a blow by coming from under hood. Got home noticed the egr vacuum modulator was melted, got a new open one from Toyota put it on and still didn’t run right and noticed after just running a mile down the road the niple on the bottom was starting to melt. What would cause such a thing is my egr bad? Or sensor? Please help
  2. Feb 29, 2024 at 7:31 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Codes?
    tht Egr pipe gets hot
    Melted some of my newly installed thin vacuum lines
  3. Feb 29, 2024 at 9:09 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    miles?
    ...you ever tried to clean the egr/pcv port on intake?
    CC this should be right up your ally.
    good chance its carboned up those ports that go into back of intake plenum...
    the egr opening and/or the pcv is all carboned up...
    you should give him a link to how you cleaned yours....
    THatt likes this.
  4. Mar 1, 2024 at 6:59 PM
    ControlCar
    Steven
    Sugar Land TX
  5. Mar 1, 2024 at 7:00 PM
    ControlCar
    Steven
    Sugar Land TX
    My major ‘cleaning’ job was TB/IAC/intake manifold/plenum
  6. Mar 21, 2024 at 5:55 PM
    02taco9487
    Casey
    My intake was clean and egr as well. What ended up being my problem was poor exhaust pressure front cat was clogged due to failure which was raising exhaust temperatures and overheating egr. Replaced cats and muffler. Runs perfect.
    Hope this helps anyone else that might have the problem.
    THatt and ControlCar like this.
  7. Mar 21, 2024 at 7:20 PM
    ControlCar
    Steven
    Sugar Land TX
    No Crap????
    how close is that melted Egr nipple away from the CAT?
    How did u determine a clogged cat?
    Way high miles?
    Interested….
