Egr valve check engine light
Discussion in '1st Gen. Tacomas (1995-2004)' started by 01Yotalac, May 31, 2016.
  1. May 31, 2016 at 4:42 PM
    01Yotalac
    01Yotalac [OP] Active Member
    2017 tacoma TRD off road
    I have a 01 2.7 liter 4x4. Recently my check engine light came on, I put it on a computer and it said to replace egr valve. Well I replaced the egr valve with a brand new one. I also disconnected my negative ground on battery to turn check engine light off. About 7 days later my check engine light came back on, so I put it on a computer and again it said replace egr valve. Anyone ever have this same problem, if so what did you do?
  2. May 31, 2016 at 5:24 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    What was the actual code?
  3. May 31, 2016 at 5:33 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    I doubt the computer said "replace the EGR valve". It just points you to the problem area. The next step should be to check the EGR system as outlined in the repair manual, step by step to see what's wrong.
    Dalandser likes this.
  4. May 31, 2016 at 6:30 PM
    01Yotalac
    I didn't see the actual code number. I carried my truck to auto zone and had them hook up a computer. They showed me the screen and it just said replace egr valve. This time autozone turned off my check engine light with their computer for me, I'm now waiting to see if check engine light comes back on
  5. May 31, 2016 at 8:11 PM
    craziedave79
    craziedave79 Member
    Dave
    Yuba City,Ca
    2000 4banger nothing fancy
    Same here. Replaced and passed smog, 2 dsys later check engine light came on with same code. Now even jerks a little stopped at Red lights.
  6. May 31, 2016 at 8:15 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Hmm...I don't think the trucks ECU tells you or autozone exactly what to replace, makes me wonder if that's a little sales ploy on their part...
    Ive also heard with parts like this it's best to stick with OEM parts, anything else can be temperamental. See if they can give you the exact code so you can look it up here and see what others have done, that's what I did to help solve my PO171 code.
  7. May 31, 2016 at 8:24 PM
    craziedave79
    craziedave79 Member
    Dave
    Yuba City,Ca
    P0402 I believe was code.
  8. Nov 10, 2017 at 7:07 AM
    TacoGary
    TacoGary New Member
    Gary
    2001 2.7 liter tacoma
    Extra suspension
    I have the same problem .2001 Tacoma ,last year my mechanic and I replaced the EGR valve after the code showed up, the light stayed off just long enough to cycle for emissions and then came back on and it stayed on this past year. I just had my truck inspected again,same issue they could only get the light to go off long enough to run emissions.( This is after cleaning the throttle body which someone suggested, but it only kept the light off for a day ...if that had any connection at all )Truck seems to stutter a little bit when idling but otherwise runs great. I just want that stupid light off I hate looking at it. If anyone solves this problem please post thank you
  9. Nov 10, 2017 at 7:57 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    My similar issue turned out to be the EGR temp sensor. The CPU might be getting a false reading from it. Instead of getting a new one (actually for a P0401 code), I removed/cleaned/replaced the sensor. CEL never came back.
    TacoGary likes this.
  10. Nov 10, 2017 at 8:15 AM
    TaCoJoE650
    TaCoJoE650 Cars are the sculptures of our everyday lives.
    Joey
    Bay Area
    99 tacoma 2WD 2.4L
    :rofl:
    First check all vacuum lines.if good than
    Check EGR VSV(vacuum switching valve). Common on toyotas for going bad.
    EGR valves themselves rarely go bad other than getting carbon on seat causing to stay open. Did you also check ports when you removed valve? Could also be clogged of carbon
    :thumbsup:
    12TRDTacoma, TacoGary and Dalandser like this.
  11. Nov 10, 2017 at 1:46 PM
    01Yotalac
    Vsv solved the problem. A headache to get to but a very inexpensive piece
  12. Nov 10, 2017 at 2:38 PM
    TacoGary
    TacoGary New Member
    Gary
    Extra suspension
    Thanks for checklist TaCoJoE650, I'll do some tinkering. ....01 Yotolac, what's Vsv? Thanks.
  13. Nov 10, 2017 at 3:18 PM
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    VSV = Vacuum Switching Valve.
    It's how the computer prevents the EGR valve from opening until the engine is warm. If it's not working the EGR valve will not open. It's hidden underneath the intake.
    cruiserguy and TacoGary like this.
  14. Nov 10, 2017 at 3:59 PM
    TacoGary
    TacoGary New Member
    Gary
    Extra suspension
    Ok, got it! Thanks again
  15. Nov 10, 2017 at 4:13 PM
    TaCoJoE650
    Joey
    Bay Area
    99 tacoma 2WD 2.4L
    Right on. Glad to hear. Can't even see on a Rav4.
  16. Nov 10, 2017 at 5:57 PM
    01Yotalac
    Tacogary, the vsv is for sure the problem, do a google search for where it’s at, very cheap part, but hard to get to. Learn from me, spent a lot of money to realize such a simple fix, wished I’d checked it first
  17. Nov 25, 2017 at 7:38 AM
    TacoGary
    TacoGary New Member
    Gary
    Extra suspension
    Thank you all! It was indeed a pain in the ass to switch that little thing out ,but the check engine light has stayed off for 2 weeks now and it's running like a dream.... the dreaded vsv!Thanks again ✌
    DrZ likes this.
  18. Nov 25, 2017 at 8:41 AM
    01Yotalac
    Awesome!! Glad it fixed it! I knew that’s what it was!!! Lol
  19. May 22, 2019 at 7:03 PM
    bkrdave36
    bkrdave36 Well-Known Member
    Dave
    Wittmann,AZ
    06 Prerunner Double Cab Black
    Front OME Springs, Upper Control Arms, Icon Stage 3 Rear Leaf Springs, Durobump bump stops,Bilstein 5125 shocks, BFG All Terrain KO2 Tires, Avid Light bar and step rails, Victory 4x4 bed rack with Tepui Ayer Rooftop Tent, Anytime Fog light mod, Outside Air Temp Gauge mod, ImMrYo Rearview Mirror mod, Chinese Knockoff LED lights, Body Armor 4x4 Offroad Swingout rear tire carrier and bumper, Victory 4x4 Bed Stiffeners, Rattle can Custom Camo paint stripe, Truxedo Lo Pro tonneau cover, various Blue Ridge Overland Gear storage solutions in cab, thats it so far .... to be continued!
    Will this solution work on a 2d Gen Tacoma V6?
  20. May 22, 2019 at 9:35 PM
    1997tacomav6
    Denver
    More than likely the same type parts, but not sure
