EGR Valve Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by starcraft232, Nov 5, 2010.
  1. Nov 5, 2010 at 2:09 PM
    starcraft232
    starcraft232 [OP] New Member
    I have a 2000 Tacoma Reg cab manual and i need to clean the EGR Valve. How do I get the thing out of the truck there is a pipe that is blocking it from coming out.
  2. Nov 5, 2010 at 9:21 PM
    WASTE MANAGEMENT
    WASTE MANAGEMENT Well-Known Member
    Travis
    Umatilla Florida
    97 tacoma 4x4 3.4 w/5 speed
    new 31x10.5 tires, mag wheels, drilled rotors, new sound, and a cb.
    4 cyl or v6?
  3. Nov 5, 2010 at 10:29 PM
    starcraft232
    It is a 4 cylinder
  4. Nov 5, 2010 at 10:32 PM
    starcraft232
    I also put some Seafoam in the gas tank to see if that will clear it out. Its throwing a code thats causing a misfire becuase of the EGR valve. How long do you think it will take for that to work?
