EGR Valve Solenoid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by labman626, Nov 30, 2015.
  1. Nov 30, 2015 at 6:58 AM
    labman626
    labman626 [OP] Member
    I had a check engine light come on ran the computer on it the code came up as the EGR Valve solenoid was bad. I am having a hard time just finding the solenoid. Was curious if I replace the whole EGR Valve itself would that fix the problem or is it two separate parts?
  2. Nov 30, 2015 at 7:57 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    do we even have an EGR? Im fairly certain the 4.0L doesnt.
  3. Nov 30, 2015 at 8:10 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    That light came on a couple of times and I just cleared the code and it's never come back. I think it may have something to do with shutting the truck off when it's hot and a certain temp (as it's cooling down- example going into a store for a few minutes and the sensors cooling down at different rates) the computer doesn't understand the difference and sets the code. Again, mine hasn't come on in a year or more. I believe you're referring to the valve onto top of the exhaust manifold air switching valve?
