EGR VALVE V6, HOW DO YOU TEST THIS ITEM TO SEE IF ITS WORKING?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, Sep 29, 2019.
  1. Sep 29, 2019 at 11:09 AM
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    Anyone one know how to test the v6 EGR?
    My fuel trims went through the roof yesterday to 14 and I checked for vacuum leaks and could
    not find any, so I know if the EGR is stuck open or not working there will be un metered
    air coming in causing this problem possibly.
  2. Sep 29, 2019 at 11:40 AM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    If it’s stuck open, it will not idle. Start truck, remove vacuum line to egr and suck on it or use vacuum pump, it should stall. You can cycle it like this to hear it open and shut. Unmetered air is normally an exhaust leak before 02 , sometimes the brake vacuum booster.... good luck
    1997tacomav6[OP] likes this.
