egr valve
Discussion in '4 Cylinder' started by Scummy, May 23, 2011.
  1. May 23, 2011 at 6:00 PM
    Scummy
    Scummy [OP] SCUMBAG CUSTOMS
    Phelan, CA
    hopped up 96 single cab 5 lug 4 banger
    Fabtech uppers and spindles, extended shackles in rear, k&n intake, flowmaster exhaust, and much more to come
    anyone know how to fix an egr valve on a 96 2.4l 4 banger. it says i have excessive flow. i dont know what hell to do. any ideas other than replacing it?
  2. May 23, 2011 at 6:12 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    You normally can't fix them. I would look for vacuum line leaks, check the VSV and if that doesn't fix your issue, replace the EGR
  3. May 23, 2011 at 10:01 PM
    Scummy
    Phelan, CA
    Vsv? And where is that?
  4. May 24, 2011 at 3:26 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  5. May 29, 2011 at 3:21 PM
    toycar18
    toycar18 Well-Known Member
    Colorado
    98 Reg Cab 2.7L
    OME Suspension, BFG 33x10.50 AT, Light Racing Upper Control Arms, Rear ARB Air Locker, LCE Header, Dynomax Super Turbo Muffler, K&N Intake
    I had the same code. Egr was fine.
    Fixed some exhaust leaks and it took care of it.
    Could be a number of things.
  6. May 29, 2011 at 7:30 PM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    before replacing the egr valve, i would try cleaning it!
  7. May 29, 2011 at 10:06 PM
    Scummy
    Phelan, CA
    Just replaced it. It was so jacked
  8. May 30, 2011 at 7:41 AM
    Zebra
    Zebra Well-Known Member
    Millington, TN
    2008 Tacoma 2.7L 4x2 Reg. Cab 5-speed
    Volant ram air and CAI setup, Fumoto oil drain valve, Pioneer DEH-3900MP
    do they make an egr delete for the 2.7L?
  9. May 30, 2011 at 8:00 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Why would you want that?
  10. May 30, 2011 at 12:46 PM
    Zebra
    Millington, TN
    For performance
  11. May 30, 2011 at 12:50 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Mad Performance 2.7L......
  12. May 30, 2011 at 1:03 PM
    Zebra
    Millington, TN
    I meant fuel mileage performance
  13. May 30, 2011 at 3:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Removing the EGR does nothing for performance. The EGR doesnt function at WOT, and its needed to keep the combustion chamber cool during part throttle operation, which also gives optimal fuel economy.
  14. May 30, 2011 at 4:15 PM
    Zebra
    Millington, TN
    well i stand corrected. it is useful to delete them on diesel engines though right? i still don't see how throwing exhaust back into the engine cools the combustion chamber. am i missing something here?
  15. May 30, 2011 at 4:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Read this:
    http://www.fordscorpio.co.uk/egr.htm
  16. May 30, 2011 at 4:30 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    reading....
