Eibach - 1st vs 2nd notch
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lee1092, Apr 21, 2022.
  1. Apr 21, 2022 at 4:53 PM
    lee1092
    lee1092 [OP] Well-Known Member
    Lee
    Charlotte, NC
    18 MGM Tacoma
    Ok I’ve read the entire eibach forum and gone back and forth about this for weeks lol.
    I can’t decide if I should do the first notch with 1.5 deaver and over load in
    OR
    Second notch with 2in aal and over load.
    Will have a soft topper in the back it’s looking like, to start.
    As far as use goes, I’ve gotten involved in some local groups so I’m going to go wheeling with them as much as possible.
    I do know I’m going to get a full leaf pack soon. A friend has a level 3 rxt he was going to sell. So probably was going to get that.
    so thought I’d get the aal temporarily.
    And eventually I know I want to do steel bumpers in front and rear (just don’t know how soon)
    and still need to do sliders and front skid plate eventually as well
    For now I just want to do some wheeling with the group with what I’ll start with “to get my feet wet”
    oyemengitsamie likes this.
  2. Apr 22, 2022 at 6:03 AM
    lee1092
    Lee
    Charlotte, NC
    18 MGM Tacoma
  3. Apr 22, 2022 at 6:10 AM
    Dank Donkeh Luvver
    Dank Donkeh Luvver Well-Known Member
    Eric
    Maryland
    2020 TRD OR White 6MT
    OVTune/Coyoza, Eibach Pro Lift, Mobtown Sliders/Skid, Softopper, Martin Offroad Rack
    I'm on the first notch with mine. I have the Wheelers 1.5" 3 leaf progressive AAL but only got 1.15"-ish so I put the stock overload back in to get closer to 1.5". I have a softopper as well, plus slider, front skid, and Martin OR roofrack with two boxes - so a decent amount of weight, but not a ton. It has a little rake, which I prefer.
    If you're doing the install yourself, I'd do first notch, since you can go back and switch it later. If having a shop do it, I'd probably just have them do second notch to avoid paying labor twice.
    lee1092[OP] likes this.
  4. Apr 22, 2022 at 6:11 AM
    lee1092
    Lee
    Charlotte, NC
    18 MGM Tacoma
    Can you post some pics of yoj don’t mind? And I’m in the middle paying someone I met on here lol
  5. Apr 22, 2022 at 6:13 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    I think I have my final recommendation for you, since your future setup goals have changed a handful of times over the week lol Ditch the Eibach fronts altogether and bite the bullet for some adjustable coilovers. You're obviously not buying all of this armor at one time, and your ride height is going to change every time you add something new to weigh it down. Its gonna be a gamble going to that 2nd notch with stock weight up front. There's no harm doing it, but you run the possibility of being nose high, and especially if you start adding weight in the rear first.
    I'd say take whatever money you planned on putting towards an aftermarket front bumper, and invest it into your suspension, in preparation for adding a bumper at a later date. Then you can have the ability to adjust as you want it over the next years to come.
    89hatcher likes this.
  6. Apr 22, 2022 at 6:17 AM
    lee1092
    Lee
    Charlotte, NC
    18 MGM Tacoma
    Lol! My goals seem to keep growing as I go further in the rabbit hole.
    How much more are coil overs typically?
    i did decide yesterday after you commented to go with the aal for now then change to rxt or deaver as I’m building
    maybe I should do the same with the front! Start at one then move to second
    I’ve seen so many that look good on the second though, lol first seems to vary almost
  7. Apr 22, 2022 at 6:19 AM
    Dank Donkeh Luvver
    Eric
    Maryland
    I'll try and run out at lunch and grab some.
    I think that @Off Topic Guy might have a point about adjustable coilovers. I saw a few pics of 2nd notch with stock front weight and it looks a little nose high.
  8. Apr 22, 2022 at 6:19 AM
    Off Topic Guy
    Welcome to TW :spending:
    Its extremely easy to do. What lift height do you ultimately want? Thats really going to determine what your options truly are.
    Aqualoon likes this.
  9. Apr 22, 2022 at 6:20 AM
    lee1092
    Lee
    Charlotte, NC
    18 MGM Tacoma
    I’m ok in the twos. Both the first and second notch fit larger tires
  10. Apr 22, 2022 at 6:21 AM
    Off Topic Guy
    If fitting tires is the end goal, I need you to start down the rabbit hole of wheel specs and alignment, and figure lift out after that lol.
  11. Apr 22, 2022 at 6:22 AM
    lee1092
    Lee
    Charlotte, NC
    18 MGM Tacoma
    I have 16x8 -25 Fn 5 stars coming and I have 265 75 16 ridge grapplers for now. Seems to be fine for my first go
    Ordered spc uca too
    Off Topic Guy[QUOTED] likes this.
  12. Apr 22, 2022 at 6:36 AM
    Off Topic Guy
    Those SPCs will definitely help if/when you move up to 33's. Just gonna go back to one of the very first things I told you though; be realistic. If I had been realistic with my build, I would have saved much of my money spent on the flashy things and put it towards better suspension components. Don't get me wrong, what I have is sufficient, but like you, I probably would benefit from the option of adjustability instead of riding on stiff notch 2 fronts until I buy a bumper years later. I did the same in the rear; heavy duty leaf packs with no added weight, with anticipation of rear bumper/decked/etc. Building it out with your weight in mind should be one of the more important factors. Thats tough to do when you're looking at budget options and intend to add more weight over time.
    lee1092[QUOTED][OP] likes this.
  13. Apr 22, 2022 at 6:37 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    You have been fight this question of which notch to go with over countless posts and threads, so I am gonna suggest.. Eibach Pro-Truck Stage 2 coil over. No clip to consider... if you want to adjust the lift, jack the truck up, removing weight off strut you want to adjust and use supplied tool. Drop, measure repeat until you have what you desire.
    https://youtu.be/nqW3n8oR560
    Chew and Off Topic Guy like this.
  14. Apr 22, 2022 at 6:44 AM
    Off Topic Guy
    Bingo :hattip:
  15. Apr 22, 2022 at 6:54 AM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    Your looking at about a $200 difference with the Stage 2 coilovers compared to the stage 1. Also can get a 1/2" more lift according to the specs. They show out of stock but Tirerack is a supplier and they always seem to have stock. I have the Eibach springs with my Bilstein 5100 shocks in front and Bitstein 5100s in back with a 3 AAL Icon leafpack with the OL leaf in and I have a slight rake and tows my 21' TT really well (with the help of a weight distribution hitch of course)
  16. Apr 22, 2022 at 7:44 AM
    lee1092
    Lee
    Charlotte, NC
    18 MGM Tacoma
    What do you have the front set at?
  17. Apr 22, 2022 at 9:34 AM
    TacoSupremo19
    NJ
    1st groove with the 5100s around a 2" lift maybe 2.25"
  18. Dec 1, 2022 at 4:07 PM
    disel_V1
    disel_V1 I eat cold pizza rolls
    3rd Gen
    few things here and there.
    What did you end up going with? 1st or 2nd notch? :D
