eibach 2" lift shocks with factory coils
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kiki111, Oct 7, 2020.
  1. Oct 7, 2020 at 2:53 PM
    kiki111
    kiki111 [OP] MENTALLY DISTURBED MEMBER
    Tacoma 2.7L SR
    noticed I find a lot of reviews on tacoma 3rd gen. with eibach pro truck sport lift shocks with eibach 2" lift coil springs. but very few with the factory (oem) coils springs. having mine installed in about three days... anyone here with that setup...eibach pro truck sport shocks set at 2" (highest ring) with (oem) coil springs...eibach max lift is 2" ..............any pros and cons...........
    btw...oem: original equipment manufacturer...not: old man emu
    with pictures if possible...
  2. Oct 7, 2020 at 9:15 PM
    PNWTacoAdventures
    PNWTacoAdventures Well-Known Member
    Washington
    2020 Super White Tacoma TRD OffRoad
    I don't have that set up, but I believe a lot of people go with the Eibach coils because they have a higher spring rate. When I did my set up (Bilstein), I swapped out the factory coils with Bilstein 650lb. The Eibach's are nice.
  3. Oct 8, 2020 at 5:46 AM
    selrod
    selrod Active Member
    Gilbert AZ
    2017 TRD Off Road
    Bilstein 5100's w OME 885x's, Headstrong 3 AAL, 16x8 -25 offset FN 5s
  4. Oct 8, 2020 at 9:05 AM
    kiki111
    Tacoma 2.7L SR
    so from what im reading eibach coil springs are rated @ 600+ lbs and stock 3rd gen tacomas come rated @ 717 lbs. only advantage to eibachs is that there 2 " longer/taller....
    tacomakid96 and 71tattooguy like this.
  5. Oct 8, 2020 at 9:24 AM
    kiki111
    Tacoma 2.7L SR
    just asking.... because the only advantage I see to the eibachs is that they're 2 in longer... the whole point of the shocks being adjustable is I'll just set it at the 2 inch (max) level with stock coils springs...which are rated heavier....
    btw....eibach pro truck have only 3 settings...0-1-2 " of lift.....
    71tattooguy likes this.
  6. May 9, 2025 at 9:25 PM
    Kbrad1991
    Kbrad1991 Member
    Kyle
    2020 Tacoma
    Op did you end up going with this? How did the oem stock coils?
  7. May 10, 2025 at 9:58 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
