Eibach / 5100 Lift, Wheels + Backspacing help?
Discussion in '1st Gen. Tacomas (1995-2004)' started by JAM, Apr 10, 2014.
  1. Apr 10, 2014 at 7:48 AM
    JAM
    JAM [OP] Well-Known Member
    Jeremy
    Point Reyes Station, CA
    2002 DC 4x4
    Toytec Bilstein Adjustable lift. Bilsteins + 3 inch Eibach Coils + AAL in the back
    Hey everyone, I am pretty new here and have only made a few posts. I have been reading and researching for a long time now on tacoma world looking for what lift I want to go with. Finally decided that I am going to pull the trigger on this bad boy:
    The eibach / bilstein lift with AAL in the back.
    I drive a 2002 Double Cab 4x4 that is currently completely stock. I am definitely going with this lift because my birthday is coming up and my parents said they would give me some funding towards it! Hoorah!
    So that being said, I am not mechanically inclined at all. I can change headlights, tires, etc and do basic things like that, but I have never installed shocks, coils and an AAL and a diff drop. My dad is going to help me through it, but would anyone be willing to help me with it? I am located in Northern California, I am willing to drive anywhere in the northern region to get this thing installed!
    Okay, enough with that. Next I want to buy 285/75/16 tires. I have a few questions if anyone could help. I know I will have to trim a bit to fit them, which is fine by me. I was wondering what wheels should I go with? I have no clue in hell what backspacing they should be or if I need wheel spacers, etc. I am clueless. Can anyone tell me what I need for the wheels and my tires to fit? I am most likely going with BFG AT KO's but other suggestions are appreciated.
    SO basically, who can help with my lift install?, what do I have to do once I have the lift installed in terms of fitting 33 inch tires on there: What wheels, backspacing, wheel spacers (if any), etc.
    Any help is really appreciated guys.
  2. Apr 10, 2014 at 7:46 PM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    As for installing the lift, as long as your dad has some mechanical aptitude, you guys should be able to handle it fine. Go to O Reilly's and get the free spring compressor rental. The biggest pain is usually breaking seized hardware loose and prying the UCA downward to make enough space to wedge the coil assy in or out.
    As for wheels, I would buy an 8" deep rim with a 3.75" backspacing. With that backspace, you won't need any spacers with your 285s. Find a rim you like in that spec, throw it on and go! Feel free to ask if you have any more questions.
  3. Apr 11, 2014 at 7:26 PM
    01taquito
    01taquito "thats what she said"
    joe
    san antonio
    01 pre-runner sr5 quad-cab
    Bilsteins 5100's front and back. Wheelers add a leaf
    I currently have that set up. Soon to be exchanged for eibachs and all pro leaf set. If you do a search for the install you should find everything you need. I bought everything and took it to a local shop with a "good reputation". They looked aty truck and said it wouldn't work. I went to my dads place and did the install. Neither one of us ever had experience with this but we had basic car/truck knowledge. Tacoma world will show you what you need. Use the search button, become a little obsessed ;)
  4. Apr 11, 2014 at 7:48 PM
    JAM
    Jeremy
    2002 DC 4x4
    Awesome sounds good. I think well be able to install it. As for the wheels, can you recommend some good ones that aren't too expensive with the same specs you mentioned? Also, with the 3.75 back spacing how much will the tires stick out?
  5. Apr 11, 2014 at 7:49 PM
    JAM
    Jeremy
    2002 DC 4x4
    Haha will do man. I don't think we will have a problem! I'll post if I do!
