eibach/5100's installed, but slight problem...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bucksnort06, Dec 13, 2009.
  1. Dec 13, 2009 at 4:02 PM
    bucksnort06
    bucksnort06 [OP] Well-Known Member
    pete
    cape cod
    09 TRD
    4 leaf TSB, 5100's all four, eibach 1.6" coils, ARE cx cap, yakima racks, weathertech floor mats/rain guard/hood guard.
    .....now my ABS light and the slip indicator light is on and I have no idea why??? any suggestions.. Im confused..
  2. Dec 13, 2009 at 4:46 PM
    choptop
    choptop Molōn labe!
    Scott
    Austin, TX
    2014 4Runner TEP
    Did you disconnect the ABS sensor wires during the install? Might want to check the connectors/ wires for damage. These could have been over stressed if the spindle and lower a-arm hung at full droop during install without something to keep the tension off the wires.
  3. Dec 13, 2009 at 4:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2. Check to make sure they are plugged all the way in.
  4. Dec 13, 2009 at 6:35 PM
    bucksnort06
    pete
    cape cod
    09 TRD
    thanks guys.. they did hang at full droop and nothing was keeping the tension off the wires.. Ill take a closer look at the connections tomorrow.. btw, the truck looks soo much better and rides awesome with the eibach coils and 5100s..
  5. Dec 13, 2009 at 6:41 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    take the wire lose from the inside of the inner fender and from the spindle and pin out the wires (use a multi meter in the diode position and one lead to each end of the contact and listen for the beep) . If you let the suspension pull on the wires they are probably broken inside. The other way is to look for any skinny spots in the wire indicating a break. I hit something in the road and it wrapped around the drive shaft and must have caught my right abs sensor wire. there was an internal break requiring me to strip the wire and solder and heat shrink it back together...
  6. Dec 13, 2009 at 6:44 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Have any pics of the truck? :)
  7. Dec 13, 2009 at 6:44 PM
    Yoytoda
    Roland
    completely stock
    yeah the wire inside is probably broken... next time you need to pull the suspension apart take the wire lose from inside the inner fender and there is one mount on the frame it is zip tied to.
  8. Dec 13, 2009 at 6:51 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    what did you set the 5100's too? and also, lets see some pics!
  9. Dec 13, 2009 at 7:07 PM
    Dr.D
    Dr.D Well-Known Member
    sold my truck
    09 DC 3" lift LR UCA's URD TCAI
    3" lift Bilstein 5100's, small top plate spacer and poly spacer, 1" Block and TSB Springs in rear with 2.5 degree shims, MagnaFlow stainless exhaust, 275/70R17 BFG A/T 17x9 RBP wheels, Light Racing UCA's, PHILIPS 4300K HID, URD TCAI, 10" Kicker Comp, Advantage TorzaTop, Scanguage II, Foglight mod, Backup camera switch mod
    Mine did that too, once I first put the lift on my 09. The previous years don't have the traction control. Once I got it aligned both lights went off. The ABS and Traction control light. That's probably all it is. Go get it aligned I bet that will do it buddy.
  10. Dec 13, 2009 at 7:20 PM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    ...VSC has to also be recalibrated
  11. Dec 13, 2009 at 7:21 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    not necessarily....
    i've had 2 different lift setups on mine, both 3" and no lights, nor VSC recal
  12. Dec 14, 2009 at 3:21 AM
    bucksnort06
    pete
    cape cod
    09 TRD
    Ill put up some pics tonight after work.. I set them at zero for now and looks to have gotten about 1.6" like the say the would with just the coils.. Once i get some new sneakers, I may set the billys at .85 and do an AAL to the rear..
    I will also take a peek at the wires.. I put alot of pressure on them and as you guys were say they probably broke internally.. thanks everyone for the help
  13. Dec 14, 2009 at 1:18 PM
    bucksnort06
    pete
    cape cod
    09 TRD
    took a quick pic of my truck.. It has the rear TSB done and had a wicked rake after I got that done.. Looks way better now I think.. I have the billys set at 0"
  14. Dec 14, 2009 at 2:32 PM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    looks good, going to attempt to get mine done wed.
