Eibach and 5100 pics.
Discussion in 'Suspension' started by FrustrationFabTaco, Jul 23, 2012.
  1. Jul 23, 2012 at 2:25 PM
    FrustrationFabTaco
    FrustrationFabTaco [OP] Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
    I've been looking for pics of a second gen access cab with 5100's and eibachs up front also without a tsb or aal. I just got new tires a few months ago and cant really afford to replace them with bigger ones for make an aal not look goofy with small tires. if anyone has stock rear suspension with 5100's set at 0 with eibachs please leave some pics. on a side note i have 265/70/16 tires. thanks
  2. Jul 23, 2012 at 2:34 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Jack the front end of your truck up roughly 1.6" and take some pics
  3. Jul 23, 2012 at 5:29 PM
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    that crossed my mind, ill probably do that tomorrow for a rough figure but i would like to see a picture of a truck that actually has that setup due to conflicting measurements from people.
  4. Jul 23, 2012 at 6:02 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm still running Eibachs and an AAL with stock sized tires. Doesn't look bad in my opinion. Here are some pics:
    http://www.tacomaworld.com/forum/2nd-gen-builds/120964-puggas-superwhite-3.html#post5418187
    If you scroll up that page a little bit, you can see the same setup with 265/70R17 tires (the stock size tires are Bridgestone Dueler blackwalls, if you see Cooper AT3's, those are the 265/70R17)
  5. Jul 23, 2012 at 6:22 PM
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    exactly what i was hoping to see. thanks!
  6. Jul 27, 2012 at 2:21 PM
    ae111black
    ae111black Well-Known Member
    Kimo
    Hilo Hawaii
    2013 Trd Sport
    plenty
    What would happen if I set an 5100 to 1.75" with an eibach spring?
  7. Jul 27, 2012 at 2:27 PM
    Pugga
    Massachusetts
    Not a good idea. With that much preload you'll be well over 3" of lift so there's a whole bunch of potential issues you could run into including: increased wear on the CV joints and boots, coil binding, UCA's hitting the coils and a very rough ride.
    Why would you want to do that, are you trying to get more lift?
  8. Jul 27, 2012 at 3:52 PM
    ae111black
    Kimo
    Hilo Hawaii
    2013 Trd Sport
    plenty
    yes on my DCSB 4x4 i just wanna bring it up to a full 3" and with the added weightof the DC.... It was just a thought. Getting the eibach's soon though. So the .85" setting on the 5100's would in theory give me 3"?
  9. Jul 27, 2012 at 4:13 PM
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    I have a DCLB and Billies with OME 885's and I set the billies on .85 but didnt get 3", I set them up one more notch and got my 3" and the CV's look just fine. I think the Eibachs should be close to what the OME 885's are since you set the billies to the same height for 3" of lift. A smaller truck would probably not have to preload past .85
  10. Jul 27, 2012 at 4:22 PM
    Pugga
    Massachusetts
    Eibach coils on 5100's set at .85 will get you to around 2.5" of lift. To get to the full 3" of lift, Toytec makes a kit for it that puts a thicker top plate spacer on top of the 5100/Eibach combo. Here's the 3" kit that Toytec sells:
  11. Jul 27, 2012 at 4:27 PM
    Pugga
    Massachusetts
    You've got 885's on 5100's set to 1.75?!?! Unless the 885's were horribly worn out, that would get you a lot more lift than you'd want unless you have a drop bracket.
    Either way, the Eibachs are a stronger coil than the OME coils and shouldn't be preloaded that much (either should those 885's but that's your problem).
  12. Jul 27, 2012 at 4:28 PM
    ae111black
    Kimo
    Hilo Hawaii
    2013 Trd Sport
    plenty
    Ok so we would't be dangerously preloading the eibach coil. The build on this thread
    http://www.tacomaworld.com/forum/2nd-gen-builds/85962-johnsons-silver-bullet.html
    is a prerunner, so I'm thinking the extra weight of the front axle diff and T case might be an issue to get the full 3"
  13. Jul 27, 2012 at 4:36 PM
    mh.meier
    The Doctor
    Commiefornia
    I got them brand new, and wheel the Taco every weekend, wheeled MOAB with them, I dont have a drop bracket and I am sitting level with my All Pro standard leafs, and my CV's are just fine, fins aent even touching. Its weird because so many people say ewhat you said and have been wrong. I dunno if its because I have a DCLB V6 or what but I dont have moe than 3" of lift, thats for sure.
  14. Jul 27, 2012 at 4:37 PM
    mh.meier
    The Doctor
    Commiefornia
    Sorry for the speeling errors, stupid sticky keys
  15. Jul 27, 2012 at 4:50 PM
    Pugga
    Massachusetts
    You can safely set the 5100's to .85 with the Eibachs, there's no harm there at all. The top plates don't add preload, they set on top of the top plates.
    In that build thread, he would have gotten around 2.5" from the 5100's and Eibachs and then added a 1/2" spacer on the driver's side and 1/4" spacer on the passenger side for some additional lift and to counteract the infamous 'Taco Lean'. I'd be willing to bet he was just shy of the 3" mark with that setup (maybe not because he has a prerunner). The Toytech kit has thicker top plates to get you to 3" of lift, then you'd add the 1/4" spacer on the driver's side to account for the Taco Lean.
    That's nuts... Lots of people got 2.5" of lift, even on DCLB with 5100's at 0. I've heard of some people kicking the 5100's up to .85 as the 885's settle but you're the first I've heard running them at 1.75.
  16. Jul 27, 2012 at 5:53 PM
    ae111black
    Kimo
    Hilo Hawaii
    2013 Trd Sport
    plenty
    I think it's time to invest in a good wal mounted spring compressor so I can play around with the settings when my eibach's come....... Lol I wish I could afford one!
  17. Jul 30, 2012 at 5:17 AM
    Kelly's
    Kelly's Well-Known Member
    N.H.
    '21 DCLB Limited 4x4
    Might as well invest in an alignment rack also while your at it.
