Eibach coils and lean??
Discussion in 'Suspension' started by Pugga, Sep 29, 2011.
  1. Sep 29, 2011 at 6:52 PM
    Pugga
    Pugga [OP] Pasti-Dip Free 1983 - 2015... It was a good run
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I'm running 5100's at 0 with Eibach coils and my truck leans toward the driver's side. I have a spacer plate on the driver's side also. Anyone else having this issue and what can I do to fix it? I wouldn't think throwing another spacer in there would be a good idea is it?
  2. Sep 30, 2011 at 4:59 AM
    Pugga
    Massachusetts
    F-150 Mod
    So I'm the only one that has a lean with Eibach coils? :confused:
  3. Sep 30, 2011 at 5:15 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    08 V6 4x4 DC TRD, 6spd
    TRD Supercharger, TRD CAI, Sirius, Rear TSB, Front 5100 with Eibach coils, 1.5" AAL, URD short throw, fog light mod, weather tech liners,
    its the TACO lean. I am not sure if putting a thicker spacer in there is a good idea on the coils.
    I have my eibachs set at 0.85 with a space and the lean is all but gone or its close enough i don't see it unless I measure
  4. Sep 30, 2011 at 5:28 AM
    Pugga
    Massachusetts
    F-150 Mod
    I'm baffled that I've got it with the Eibachs as stiff as they are. I put the top plate on the drivers side to correct it and I just noticed it leaning. Its not terrible but I've only had the setup for about 9 months now and I didn't have the lean when it was installed.
  5. Sep 30, 2011 at 5:44 AM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    What sucks is I bought Toytec's new complete 3 inch assembly, and you would think they would have thought to put the lean spacer on it. So I will always have the little lean.
  6. Sep 30, 2011 at 6:01 AM
    Pugga
    Massachusetts
    F-150 Mod
    Did you have the lean before when you had the 5100's at .85 and Eibachs? I've got a lean spacer in and everything and it still leans! :mad:
  7. Sep 30, 2011 at 8:24 AM
    raswank
    Rick
    Auburn,Ma
    No i didn't
