eibach coils on stock shock possible?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SargeSlapnuts, Apr 15, 2011.
  1. Apr 15, 2011 at 11:14 PM
    SargeSlapnuts
    SargeSlapnuts [OP] SargeSlapnuts 보고용의!!!!
    Nick
    alpharetta, GA
    2004 TRD 4x4 converted PreRunner SR5 lifted l
    255/85-16 tires, front push bar w/9000lb winch, driver and passenger windows tinted to match factory rear tint, quick at home spray on bedliner, hid's, lifted with 3"toytec rear lift kit and ome front lift, locked with powertrax, and a cb radio in place of ash tray, fog light mod, diff breather mod, greasable shackles, Home made Baja Rack, "extra" bright reverse lights. also converted to 4x4 safari snorkel
    will eibach coils work on stock front shocks for a temporary set up until i get some billies? just trying to figure out a way to get rid of my crappy spacer lift in the front
  2. Apr 15, 2011 at 11:18 PM
    SargeSlapnuts
    Nick
    alpharetta, GA
    ok well that pretty much clears it up for me. guess i just gotta save up for some front billies
  3. Apr 16, 2011 at 12:35 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    well when you install billys u set them to 0" or stock so i assume you could but i wouldn't drive anywhere except on roads.
  4. Apr 16, 2011 at 12:38 PM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    hey im replacing my eibachs on 5100s today wanna make an offer?
  5. Apr 16, 2011 at 12:41 PM
    tb99trd
    tb99trd Well-Known Member
    Tom
    Petaluma CA
    99 TRD 4x4
    Bilstein 5100s (@ 2.5), Toytec 2" AAL, gray wire mod
    wait, you're replacing the shocks AND coils? how many miles on em? how much you want?
  6. Apr 16, 2011 at 12:43 PM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    coils got about 1k on them and the shocks have around 5-6ish... id would give sarge first dibs though since this is his thread :)
  7. Apr 16, 2011 at 12:53 PM
    tb99trd
    Tom
    Petaluma CA
    99 TRD 4x4
    totally. put me 2nd in line and lemme know if he doesn't want em
  8. Apr 16, 2011 at 2:01 PM
    SargeSlapnuts
    Nick
    alpharetta, GA
    i dunno ill get back to you on that here shortly. lemme look up the prices for them new and ill make an offer.
  9. Apr 17, 2011 at 9:04 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Why are you replacing them? :confused:
  10. Apr 17, 2011 at 9:32 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    I've been running eibachs on stock shocks for about two years with zero problems. Offroad and all.
  11. Apr 17, 2011 at 9:38 PM
    GA_TACO4x4
    GA_TACO4x4 Well-Known Member
    here 'n there
    07 DCSB 4x4
    marathon superhide max-4 seat covers, weathertechs, maglite mod, 20% tint, 2" leveling kit, leaf spring tsb.
    how much lift did the eibachs give u?
  12. Apr 17, 2011 at 9:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    IIRC, They are both a 13" long coil.
  13. Apr 18, 2011 at 1:43 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    I got new icons from demello and sorry sarge they are sold
  14. Apr 18, 2011 at 9:05 AM
    SargeSlapnuts
    Nick
    alpharetta, GA
    do you really have zero down travel? also are you now able to hit your bump stops in the front???
  15. Apr 18, 2011 at 9:14 AM
    SargeSlapnuts
    Nick
    alpharetta, GA
    so they are the same length spring just the eibach is stiffer correct???
  16. Apr 18, 2011 at 9:15 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    yes.
  17. Apr 18, 2011 at 9:16 AM
    GA_TACO4x4
    here 'n there
    07 DCSB 4x4
    note he also has a 2nd gen. eibachs are rated for somewhere around 1.5" for a 2nd gen compared to 3" on a 1st gen. so that may be a factor to consider...
  18. Apr 18, 2011 at 9:16 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yes
  19. Apr 18, 2011 at 9:17 AM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Ga_taco4x4- unfortunately I didn't measure. I wasn't satisfied enough so I went with a 1/2" spring isolator as well. I'm sitting at 23" from center wheel to fender.
  20. Apr 18, 2011 at 9:17 AM
    JLee
    Jerry
    Bay Area NorCal
    Dam too slow :mad:
