Eibach coils on stock struts?
Discussion in 'Suspension' started by thegrandpoohbah, Feb 6, 2010.
  1. Feb 6, 2010 at 10:58 PM
    thegrandpoohbah
    thegrandpoohbah [OP] Well-Known Member
    Fort Nelson, BC, Canada
    2013 4x4 Double Cab V6 TRD Sport
    I am planning on purchasing a 2010 4x4 DC V6 TRD Sport soon and the first thing I get for it will be the ARB bumper. I was going to leave the suspension stock for the time being but would like to lift the front end a little if possible in order to combat the sag from the extra weight. Problem is money will be tight as we are also buying a new house this summer. So I got to thinking, could I run the Eibach coils with the stock struts? According to Toytec's website it will work. I know the struts won't last as long this way but by the time they wear out I could afford a set of 5100's or maybe even an OME lift kit. If it does work, what is the ride quality going to be like?
  2. Feb 6, 2010 at 11:44 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    I think just getting the Bilstein 5100s for the front right off the bat would be a better idea. Its only what, $150-200 for the pair of em, then you could adjust the height of them down the road if desired also. I think the heavier spring rate of the Eibachs would give a poor ride on the factory front struts since they wont have enough dampening.
  3. Feb 6, 2010 at 11:56 PM
    THROUGHITALLDUDE
    THROUGHITALLDUDE Someone didnt put the tailgate down!
    Jeff
    Southern California
    2005 Silver Tacoma
    285-75-17 Definity ATs - 16'' Chrome Moto Metal 951s - 4'' Maxtrac spindles - Rear Icon Progressive Leaf Pack - Magnaflow exhaust - Aftermarket LED Taillights - BHLM - Custom Wet Okle Seat Covers - Moog Tire Rods - US Spec Ipod - K&N High Flow Filter - Daytime Running Lights - TRD Skid Plate - Grillcraft - Hellas Mounted behind the grill
    hey quick question anyone know this off the top of their head what is the stock height of the front and rear suspension in inches?
  4. Feb 7, 2010 at 12:26 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    ^ what are you referring to exactly? like, inches from ground to fender? height of shock on regular ride height?
  5. Feb 7, 2010 at 1:22 AM
    THROUGHITALLDUDE
    Jeff
    Southern California
    2005 Silver Tacoma
    sorry ya from the fender to the ground
  6. Feb 7, 2010 at 9:14 AM
    thegrandpoohbah
    I was thinking about that but if I'm not mistaken, lifting using the the 5100's on stock coils would reduce the down travel?
  7. Feb 7, 2010 at 9:38 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    I dunno about Eibach's with a DC + ARB. I would go with 885's and OME shocks. Do it once, do it right. Save your cash for it. No need to lift your truck twice ya know?
    Lifting with 5100's is plain 'ol silly to me. No offense to anyone who has done that.
    Just my .02 which really is cheap lol.
  8. Feb 7, 2010 at 10:37 AM
    thegrandpoohbah
    Why do you say that? Spring rate on the Eibach is 620lbs vs. 590lbs for the 885 unless I am mistaken?
  9. Feb 7, 2010 at 11:44 AM
    RelentlessFab
    Eric
    nope, the 5100's wouldn't increase or decrease any portion of the suspension travel.
    you are right about the spring rates.
  10. Feb 7, 2010 at 1:46 PM
    thegrandpoohbah
    Ok, so what would be the best short term budget solution: Eibach coils on stock struts or 5100's on the front with stock coils? Either way, I would be upgrading down the road as I wear out the stock components.
  11. Feb 7, 2010 at 5:56 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    i have heard that the eibach coils with stock struts doesn't give a good ride. i think you will bottom out on speed bumps and such? if i'm remembering correctly? just go with the billy's set at .85. then when you upgrade down the road you will already have some good offroad shocks. the 5100 billy's have a lifetime guarantee.
  12. Feb 7, 2010 at 5:59 PM
    weidjd
    weidjd Well-Known Member
    '10 DC TRD OR 4x
    Saw COs/RR,TSB + 1.5AAl, LR UCAs
    I was going to do that. Toytec said to get the 883/884 to use with stock did not recommend Eibach. I would get the OME shocks and springs.
