Eibach lift 2 gen???!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Carson1199, Apr 28, 2020.
  1. Apr 28, 2020 at 10:56 PM
    Carson1199
    Carson1199 [OP] Well-Known Member
    Carson
    Overland park
    2013 black limited tacoma
    Black taillights, blackout headlights,
    I was looking around and saw that barely any tacomas have eibach pro truck lift!! I'm going to purchase the lift soon and will give you updates!
  2. Jan 30, 2021 at 8:40 PM
    JWILL10
    JWILL10 Well-Known Member
    Jonathan
    Austin, TX
    2013 Toyota Tacoma SR5 4X4
    Snug Top Super Sport, SCS SR8's 17 X 8.5 -10mm offset, Nitto Terra Grappler G2 (295/70-17), BAMF Hybrid Bumper.
    Any updates?
  3. Jan 30, 2021 at 10:55 PM
    Ryan2103a
    Ryan2103a Well-Known Member
    SoCal
    2011 Sequoia 4x4 2022 SR 4x4
    Here's mines right after I installed it set at 2.5" in the front and 2" aal in the back. It's been a couple months and has settled about a quarter of an inch down.
  4. Jan 31, 2021 at 7:03 AM
    JWILL10
    Jonathan
    Austin, TX
    What are you wheel specs? And tire size? Also, did you get aftermarket UCA?
  5. Jan 31, 2021 at 8:48 AM
    Ryan2103a
    SoCal
    Wheels are from 3rd gen. Tires are Hankook Dynapro 265/75/16. OEM uca.
  6. Jan 31, 2021 at 9:36 AM
    JWILL10
    Jonathan
    Austin, TX
    Do you think if you really wanted to, you could run a 285/75-16?
    Jaflynn2112 likes this.
  7. Jan 31, 2021 at 11:34 AM
    Ryan2103a
    SoCal
    Yes it's possible but will need to do a cmc. I do plan on going bigger when I need to replace my tires in about a year. Going with pizza cutters 255/85/16 (skinny 33s).
  8. Jan 31, 2021 at 12:37 PM
    JWILL10
    Jonathan
    Austin, TX
    Nice, that’s cool man. Thanks for the info. I think I’ll be going Eibach pro truck lift. I’m thinking Dakar mediums in back (looking for 2+ in the rear).
  9. Jan 31, 2021 at 1:07 PM
    Ryan2103a
    SoCal
    If you go with the stage 1 kit make sure you get the 2nd gen version and not the 3rd gen one. 2nd gen version gives you a 2.5" front lift with 4 different notches while the 3rd gen only gives a 2" and 3 different notches.
    2nd gen part #E80-82-007-01-22
    3rd gen part #E80-82-069-01-22
  10. Jan 31, 2021 at 1:59 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    What brand soft top is that?
  11. Jan 31, 2021 at 2:39 PM
    JWILL10
    Jonathan
    Austin, TX
    I’ve been looking at the one one Headstrong. I’ll double verify PN’s though to make sure. Throw some more pics of your truck up when you get the chance.
  12. Jan 31, 2021 at 10:08 PM
    Ryan2103a
    SoCal
    Bestop supertop
    gotoman1969[QUOTED] likes this.
  13. Feb 1, 2021 at 8:08 AM
    MrFixit420
    MrFixit420 Well-Known Member
    Portland Oregon
    2014 TRD Off Road DCSB
    Eibach Pro Stage 1 on 2nd clip, 3 leaf Icon AAL's in back.
    I had mine installed last spring and love the ride and looks. Rides better than stock on and off road.
    It's at 3" on the second clip with 2" 3 leaf progressive aal's in back.
    265/75/16 also aftermarket 0 offset wheels. Great setup.
    Yes it will fit but personally I would go to a 17" wheel if you want a 33" tire so you have more selection of tires. 285/75/16's are usually heavy duty and weigh a lot more than a 265/75/16 do, where in a 285/70/17 you can get that size in a much lighter tire from most manufacturers. Unless you need the heavy duty tires for your off roading. To me the extra weight isn't worth it.
