Eibach Lift Coils installed today...very happy!
Discussion in 'Suspension' started by canuck_tacoma, Apr 8, 2009.
  1. May 25, 2009 at 10:49 AM
    #41
    canuck_tacoma
    canuck_tacoma [OP] Well-Known Member
    BC, Canada
    SR5 4X4 Tacoma Access Cab
    1.5" Eibach Front Coil Lift, Rear TSB, 265/75/16 BFG A/T's
    It was actually very stable.....I checked it before I pulled the tire off. I still wouldn't recommend it....I got myself some larger stands.
  2. May 25, 2009 at 10:53 AM
    #42
    canuck_tacoma
    BC, Canada
    The Eibach website has a Dealer look up, you can use them with 5100's.
  3. Jun 4, 2009 at 1:03 AM
    #43
    commtrd
    commtrd commtrd
    Corpus Christi TX
    09 Access Cab 4wd V6
    Could these springs AND the bilstein 5100's be purchased already assembled at 0" preload position so that no spring compressor is needed? I just want to level out the front end not really lift the truck.
  4. Oct 13, 2009 at 11:35 AM
    #44
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Is the spring rate same between the ones that you buy directly from eibach or the ones that toytec sells in their coilover kit? I'm referring to the silver ones
  5. Oct 13, 2009 at 2:39 PM
    #45
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    For those of you who are interested in mid lifts....there is a Group Buy for these setups on this web site. Look under Toytech's. If we get enough buyers, we can save some money.
    If you pm the contact, he will give you the specifics for your truck. Very helpful.
    Worth looking into.
  6. Oct 19, 2009 at 12:54 PM
    #46
    IndigoTaco
    IndigoTaco Well-Known Member
    07 Access Cab Sport 4x4
    I am debating between these and the 883's...what's the difference in weight and length between the Eibachs and 883's?
  7. Oct 25, 2009 at 12:45 PM
    #47
    jnguyen832@yahoo.com
    jnguyen832@yahoo.com Member
    Jack
    Cypress
    05 PreRunner
    Leveling lift kit
    I have 2005 tacoma. i just put a front 3" lift spacers with 3" block in the rear. i wanted to get some lift coil springs but i'm not sure what size to get that would work good with my set up. If you can help me out please let me know
  8. Oct 25, 2009 at 1:59 PM
    #48
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW! You cant use lift springs with lift spacers.
  9. Oct 25, 2009 at 2:45 PM
    #49
    bluevan99
    bluevan99 Active Member
    07 DC LB SR5 TRD Sport
    Chris,
    You mean coil spacers right? a small top plate spacer (to correct lean, et..) would be ok from what i've read.
    Also, i 'm guessing your gonna know ;) , What would the increase in spring rate be for the eibachs with 5100s set at .85 (vs. set at 0). Thank you.
  10. Oct 27, 2009 at 6:06 AM
    #50
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    Truck looks good man I cant wait to get my Eibach springs I ordered from the Group Buy. :headbang:
  11. Nov 2, 2009 at 7:52 PM
    #51
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    Daytime shot of the Truck with new coils, rear TSB, and BFG 265/75/16's. This is the way these should roll off the factory floor.
    [​IMG][/QUOTE]
    This is the pic that made my decision to get this in the gb. looking good :)
    can't wait to get them now.
  12. Nov 10, 2009 at 11:34 AM
    #52
    elmer29
    elmer29 New Member
    New Mexico
    Tacoma 4X4 TRD Sport
    Looks great. Since my taco is beyond the warranty for the TSB on the rear. What would be an option for leveling the rear with the front if the Eibachs are put on the front. Would the TSB on the rear be worth paying for?
  13. Nov 10, 2009 at 5:45 PM
    #53
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    you can just get an aal (add a leaf) or a block for the rear to level it off with the front.
  14. Nov 15, 2009 at 9:08 AM
    #54
    ekelley1985
    ekelley1985 KelTek
    Portland, OR
    2013 TRD Sport 4x4 double cab longbed
    no, no, no. the dealer charges just under 1800 for this job! go with some aftermarket full leaf packs or aal's
  15. Nov 26, 2009 at 1:25 AM
    #55
    ekelley1985
    ekelley1985 KelTek
    Portland, OR
    i have my eibach 1.6 springs with 5100's set @ .85, what can i do to get a little more lift?
  16. Nov 26, 2009 at 10:07 AM
    #56
    08pretaco
    az
    toytec 1/4" or 1/2" top plate spacers. they yield from about 1/2" to 3/4" lift respectively
  17. Apr 22, 2012 at 1:21 PM
    #57
    big sky
    big sky Well-Known Member
    Montana
    2012 TRD Sport DCSB 4x4
    bumping this old thread to see how the oe Bilsteins made out over time
    thanks!
  18. Apr 22, 2012 at 1:27 PM
    #58
    12Tac
    12Tac Well-Known Member
    Colorado
    2020 Double Cab, Long-bed TRD Off Road.
    SnugTop, FN Wheels, Meso Custom, Tacos4Cheap
    Nicely done.
