eibach or OME coils
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hakabo, Apr 30, 2013.
which options????
Poll closed May 30, 2013.
  1. 5100s at .85 and eibachs
    12 vote(s)
    40.0%
  2. 5100s at 0 and 885s
    16 vote(s)
    53.3%
  3. neither, try this instead...
    2 vote(s)
    6.7%
  1. Apr 30, 2013 at 6:03 PM
    hakabo
    hakabo [OP] Well-Known Member
    Jacob
    Concord, NC
    08 urban runner 4x4
    I have 5100s on a 2007 access cab. Currently set at 2.5 on stock coils and it rides pretty rough. I want to replace the coils and maintain my ride height while getting a softer ride. Which should i do, add the eibach coils on .85 or 885s on 0. If you have opinions or suggestions please share. THanks!
  2. Apr 30, 2013 at 11:41 PM
    majorhavok
    majorhavok Rabid Conservative
    Mike in Cali..
    Peoples Republic of Caulifournia
    '13 TRD Sport DoubleCab 4x4
    Ultragauge, ImMrYo mirror, Tailgate lock, Snugtop Rebel Shell.
    I voted. Please don't use that for consideration.. Like 99% here I haven't had the three setups you're discussing. Hopefully someone who has will chime in.
    Good luck!
  3. Apr 30, 2013 at 11:43 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    5100s & 885s
    That's what I'm running and it's great on/off road.
  4. Apr 30, 2013 at 11:54 PM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    I have the 5100s at .85 and eibach coils. It settled to be a little lower than my buddies 5100 with OR coils at 2.5
  5. Apr 30, 2013 at 11:58 PM
    8BoltRacing
    8BoltRacing Custom Fabrication and Performance
    Jared
    Greensburg PA
    The Angry Warthog
    DO 3 hoop, Wheelers HD Leaf Set w/ES poly bushings, OME 884X Coils, 5100's, Selfmade Satoshi, Single beam headlights, Fogs anytime, high beams with low beams mod, ABS kill switch, AMSOIL fluids in everything, K&N Intake, TB Spacer, FAL Electric Fan and TRD Rad Cap, DT Long Tubes, URD Y-pipe w/xtra O2 bungs and 3" v-band , Custom 3-inch Exhaust w/v-band and 3030XL Aero turbine muffler and Aero 3040 tip, URD Fuel Pump Upgrade, B&M Short Shifter, EBC Dimpled and Slotted Rotors with EBC Yellowstuff pads, Pulseplugs, HIDs: Fogs 3000k, Highs 4300k, Lows 8000k, URD Throwout Bearing Repair kit, Fidanza Aluminium Flywheel+Competition Clutch Stage 4
    Voted for the OME's. I'm running 5100's with 884X and ride is so much better than stock coils and sits a little higher too. Sry no experience or advice on the eibachs tho.
  6. May 1, 2013 at 5:37 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    oooh I love that sig
  7. May 1, 2013 at 5:42 AM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    I'd go with the OME 885's
  8. May 1, 2013 at 5:46 AM
    Large
    Large Red
    5100s @ 2.5 is probably going to be the same as 5100s & eibachs at .85, the eibach coils are pretty stiff.. I'd do 885s.
  9. May 1, 2013 at 7:50 AM
    JpAdct
    JpAdct Well-Known Member
    PB County, FL
    2003 Tacoma ExtCab
    I just installed 5100s with Eibachs but I'm running the fully adjustable coil over style. I'm running that at about 2in and its a great ride. It hasn't had time to settle yet, but I'll adjust them when it does. More firm than my stock TRD Off Road set up but still far from harsh. I'm very happy with it so far. I've had several shops tell me that OME and 5100's shouldn't be mixed. Not sure why and many on here run and love that combination. I didn't want to mix them and I am glad I went with the setup that I did. My understanding is that the Eibachs purchased through Toytec were made by Eibach as a specific application designed specifically for the 5100. I like this matching.
  10. May 1, 2013 at 9:43 AM
    Drinknmolson
    Drinknmolson Well-Known Member
    Wheat Ridge, CO
    10 DCSB sport
    I like everything about OME including the shocks, not against billy's but I have had with great success OME shocks on a 79 fj40, 97 4runner and now my '10 taco! always recommend them and I drive 90% on road but when off road they perform!
  11. May 1, 2013 at 5:57 PM
    hakabo
    Jacob
    Concord, NC
    08 urban runner 4x4
    bump...
  12. May 1, 2013 at 6:01 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Aren't you getting a 1/4" steel front bumper OP ?
  13. May 1, 2013 at 6:10 PM
    dirtrider262
    dirtrider262 Member
    southern oregon
    2013 MGM TRD OR DCSB 4.0 6SPEED
    OME 885x 5100@ 0 is awesome
  14. May 1, 2013 at 6:16 PM
    Large
    Large Red
    Why are you bumping? There is more than 1 dedicated thread to OME & eibachs with a plethora of information, plus there are really good opinions already here.
  15. May 1, 2013 at 7:01 PM
    OZ-T
    Peter North
    British Columbia
    Bump
  16. May 1, 2013 at 8:35 PM
    NorCalTRD
    NorCalTRD Well-Known Member
    Northern California
    '06 Indigo Ink DCLB TRD Sport V6
    40% Front Tint, Viper 5704 Alarm, Steel Cable Dog Tie, Super Sexy Driver Mod
    Why not full OME suspension?
  17. May 2, 2013 at 4:52 AM
    hakabo
    Jacob
    Concord, NC
    08 urban runner 4x4
    I already have the 5100s. I'm pretty much set on the 885s due to the pending plate bumper, plus then I just need the ome shocks if I do convert.
    Thanks for all the input on here and the PMs!!!
  18. May 2, 2013 at 4:29 PM
    Gus 524
    Gus 524 Well-Known Member
    Justin
    MN
    09 tacoma SR5 4WD 4-cylinder
    I just put on some eibach at .85 and i love it. It feels like its only a tad stiffer then stock, which i like for city driving. I haven't had them off road much yet but from the little bit i did they felt nice.
  19. May 2, 2013 at 4:31 PM
    2wheelnut
    2wheelnut Well-Known Member
    Angelo
    Vallejo, CA
    '11 S/C K.I.S.S. "Factory Enhanced" DC TRD OR
    TRD Supercharger, TRD First Gen CAI, TRD FJ Alloy, Toyo OC A/T II 265/75/16, 5100's Front and Rear, OME 885x with 1/4 taco lean spacer, Toytec AAL 1.5" non TSB. TSB not done. WheatherTech Side Window Deflector, Satoshi Grill, T Rex Eyelids, Matt123 Skid Black stamped, Modded Maglite with Maglite mod for driver seat, Bed extender. Full debadging
    From what I understand, you would need to run the 886's if you're adding the weight of a plate bumper.
    I run the 885s on 5100's, pretty much like you had the 5100's first. I like them alot except for washboard and rocky trails. They suck.
    People say not to match them because the shocks aren't valved for the OME springs. I believe the 5100's are digressive while OME schocks are progressive. They do ride and handle nice on road with this setup. Wheeling technical trails they do very well too. Regular dirt trails that aren't rocky and this setup does good.
    I was bombing down a rough paved country road with an FJ and a Jeep and I went quicker and handled better than both. (FJ stock Jeep lifted). Both kept sliding around and had to go real slow over the rougher stuff.
  20. May 2, 2013 at 4:39 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    884.
    F the eibachs. Sagged way to quick. Yes, I have a bumper but still.
