Eibach pro lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Raw31993, Apr 19, 2018.
  1. Mar 27, 2019 at 5:03 PM
    #261
    Kjntaco
    Kjntaco Well-Known Member
    Oahu, Hi
    We have a bunch here in Hawaii that look like that.
    09 Redneck[QUOTED] likes this.
  2. Mar 27, 2019 at 5:05 PM
    #262
    Orvechkin
    Orvechkin Well-Known Member
    Sam Or
    2019 Tacoma
    It's on the top notch. I got 3 inches of lift all around. And thanks!
  3. Mar 27, 2019 at 5:05 PM
    #263
    Orvechkin
    Sam Or
    2019 Tacoma
    Like the Fall Guy? Lol
    MrBrooks likes this.
  4. Mar 27, 2019 at 5:14 PM
    #264
    MrBrooks
    MrBrooks Well-Known Member
    Midwest
    2018 DCSB - 2021 Rav4
    Yep I had that exact one & many others! :thumbsup:
  5. Mar 28, 2019 at 9:05 AM
    #265
    Ryan at Eibach
    Ryan at Eibach Well-Known Member Vendor
    throwback!
  6. Mar 28, 2019 at 9:11 AM
    #266
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    It's bouncy because you are on the third notch and don't have any weight up front. It's got too much preload in the front.
    For the rear did you leave in the over leaf?
  7. Mar 28, 2019 at 9:26 AM
    #267
    Xx_Evilvirus_xX
    Xx_Evilvirus_xX Well-Known Member
    Houston, TX
    2018 Tacoma TRD Offroad 4x4
    This set up seems perfect for what I am looking for.
    Andrew H[QUOTED] likes this.
  8. Mar 28, 2019 at 4:18 PM
    #268
    Orvechkin
    Sam Or
    2019 Tacoma
    Sorry you'll have to rephrase that or explain the question LOL i come from the motorbike and car world
  9. Mar 30, 2019 at 9:22 AM
    #269
    Jbak501
    Jbak501 Well-Known Member
    DFW Tx
    2017 MGM Toyota Tacoma TRD OR
    Ok, I am going to pull the trigger on the Eibach pro stage 1 kit and Icon 1.5" aal. Being my first lift is there any outliers I need to aware of? I don't need extended brake lines or a diff drop for such a small lift right? Looking to achieve a 2"/1.5" lift . Also Eibach states with that kit you can only accommodate a 1" lift in the rear. What complications will I run into going 1.5" aal?
  10. Mar 30, 2019 at 9:26 AM
    #270
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    You’ll be fine for the rear lift up to 2”. The rear shocks are actually longer than standard 5100s.
    Jbak501[QUOTED] likes this.
  11. Apr 1, 2019 at 5:08 PM
    #271
    Jbak501
    DFW Tx
    Ok, just ordered the Eibach pro stage 1 kit and an Icon 1.5 aal. No weight up front (yet) so I will be setting on the bottom notch. I know a lot of people on here have a similar setup if not the exact same... @Rob Daman .. do I need to plan for the bro lean spacer or am I going to be in the clear?
  12. Apr 2, 2019 at 4:09 PM
    #272
    Ryan at Eibach
    You shouldn't need it
  13. Apr 2, 2019 at 7:43 PM
    #273
    jdmstuff
    jdmstuff Well-Known Member
    Derrick
    Torrance, CA and Las Vegas, NV
    '18 TRD OR DCSB AT, '08 TRD Sport DCSB AT, '03 TRD 3.4l 4x4 MT Supercharged
    I was a 1/4" low on the driver's side when I was done and I put in a spacer to even it out. I'm running the same setup as you are getting except for the AAL kit.
  14. Apr 3, 2019 at 5:31 AM
    #274
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Got mine on this past weekend. The ride is incredible.
    I got a tad more than 2" up front, but it should settle out some. I put a 1/4" spacer on the driver side and it's level side to side, I would recommend going ahead and doing it since spacers are cheap and you don't have to do the work two times.
    Highly recommend this kit for the price.
    patdeezy and MrBrooks like this.
  15. Apr 3, 2019 at 8:09 AM
    #275
    Jbak501
    DFW Tx
    Where did you pickup the spacer?
  16. Apr 3, 2019 at 8:35 AM
    #276
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I used the poly spacer from Wheeler's.
    jdmstuff and Jbak501[QUOTED] like this.
  17. Apr 3, 2019 at 7:50 PM
    #277
    jdmstuff
    Derrick
    Same here, but they were out of the poly and got the alloy one instead, for twice as much. Whatever, I couldn't wait, I had the install planned already.
  18. Apr 4, 2019 at 1:58 AM
    #278
    Kjntaco
    Oahu, Hi
    Anyone with updated pics after it settled? Measurements? Still considering this lift.
  19. Apr 4, 2019 at 6:48 PM
    #279
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    Just ordered this set up.
  20. Apr 7, 2019 at 11:55 AM
    #280
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Here are my measurements after having the lift on for 1 week.
    Fronts were set on the 2nd notch and a 1/4” spacer on the driver side. Rear is 3 leaf AAL and kept the over leaf.
    In the front I have a 65lb IFS skid, 70lb streamline bumper, and 65lb winch.
    LF - 23” | RF - 23 1/8”
    LR - 24” | RR - 24 1/2”
    Edit - truck has a full tank of gas as well.
