Eibach pro lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Raw31993, Apr 19, 2018.
  1. Jun 3, 2020 at 9:09 PM
    #2881
    MrFixit420
    MrFixit420 Well-Known Member
    Portland Oregon
    2014 TRD Off Road DCSB
    Eibach Pro Stage 1 on 2nd clip, 3 leaf Icon AAL's in back.
    Eibach Pro lift on second clip from @Wheeler's Off-Road Inc $622 assembled.
    Icon 3 leaf AAL's "with overload left in" from Autoanything $171
    2 Front sway bar end links. $76 You shouldn't need these.
    Install $340, alignment $79 done by Automotive Outfitters in Portland Oregon.
    Total Parts: $793 without the end links
    Labor: $419 for install and alignment.
    So $1,212.00 installed. Not a bad price.
    Here is a link to the info with pictures and alignment and height specs.
    Replaced RC Spacer lift with Eibach Pro 1 and Icon 3 leaf.
  2. Jun 4, 2020 at 6:43 AM
    #2882
    Fernando95diaz
    Fernando95diaz Well-Known Member
    Fernando
    2019 Tacoma off road 4x4
    Did anybody install a spacer for the lean? Is it really that noticeable ?
  3. Jun 4, 2020 at 6:55 AM
    #2883
    THE_KiRRAx
    THE_KiRRAx Well-Known Member
    Tampa, Florida
    2016 BBP Tacoma SR5 DCSB
    I noticed the well known taco lean a day or two after I bought my truck, no lift. When you see it, it's very noticeable, just try to ignore it and you'll eventually forget about it.
    That being said, I'm getting my lift installed this weekend and the drivers side spacer will be used to correct the lean just because. It came with the kit so why not right? haha
    Fernando95diaz likes this.
  4. Jun 4, 2020 at 6:57 AM
    #2884
    Hot Taco sauce
    Hot Taco sauce Well-Known Member
    WI
    Dclb lover
    Just starting out, give me time
    From where??
  5. Jun 4, 2020 at 7:02 AM
    #2885
    Edubreuil
    Edubreuil Back in a Jeep
    Ed
    Cornville, Iowa
    2021 Jeep Gladiator Mojave
    Got the same "two more weeks" line again yesterday. Awesome! Like groundhog day.
  6. Jun 4, 2020 at 7:12 AM
    #2886
    THE_KiRRAx
    Tampa, Florida
    @HeadStrong Off-Road includes the spacer in their kit to compensate for the lean.
  7. Jun 4, 2020 at 7:40 AM
    #2887
    phocas
    phocas Well-Known Member
    $419 labor? Damn that's amazing! I might drive down from Seattle, i can't seem to get in contact with anyone around here.
    MrFixit420[QUOTED] likes this.
  8. Jun 4, 2020 at 7:45 AM
    #2888
    leebrachi
    leebrachi Member
    Available through their website already. If not call customer service, got mine through them.
  9. Jun 4, 2020 at 9:25 AM
    #2889
    MrFixit420
    Portland Oregon
    I know, I was thinking of doing it myself after I heard what others were paying.
    A tire shop I use recommended them for having the extended length lugnuts I needed and it went from there. I was so happy with the service they gave me I ended up buying a set of new wheels from them and I had them put in the lift to.They do a lot of work on Toyotas and for that matter all 4x4's there.
    Couldn't be happier with the service and the work done.
    phocas[QUOTED] likes this.
  10. Jun 4, 2020 at 9:29 AM
    #2890
    MrFixit420
    Portland Oregon
    I only have 1/4" lean in front and they don't even make a spacer small enough for that. Haven't seen a 1/8" spacer yet.
    The back though is about 1" lower. Was thinking of putting a 1/2" shim under that side in the back. That should also bring the front even closer.
  11. Jun 4, 2020 at 4:19 PM
    #2891
    Tmaloy
    Tmaloy Well-Known Member
    Troy
    2019 SR DC LB
    My truck had the lean while stock. More pronounced when I got larger tires. I did install the lean spacer when doing my lift and the truck is more leveled. Bear in mind I try not to let my fuel go less than 1/2 tank so more weight on drivers side.
  12. Jun 4, 2020 at 7:51 PM
    #2892
    Fernando95diaz
    Fernando
    I should’ve bought the spacer before I scheduled go install the kit I don’t notice it on my stock truck so I hope it’s not noticeable with the lift
  13. Jun 4, 2020 at 8:25 PM
    #2893
    Tmaloy
    Troy
    2019 SR DC LB
    Best I can tell the lean gets more pronounced the higher the lift. Good luck and hope it turns out well.
  14. Jun 5, 2020 at 10:10 AM
    #2894
    leebrachi
    leebrachi Member
    When is your install? I have mine that i did not end up using since I went with the stage 2.
  15. Jun 5, 2020 at 11:17 AM
    #2895
    Fernando95diaz
    Fernando
    I was scheduled for tomorrow but I canceled
  16. Jun 5, 2020 at 12:55 PM
    #2896
    patdeezy
    patdeezy Well-Known Member
    souLcaL
    '19 OR 4x4 SuperWhite DCSB
    How’s the stage 2?! Can’t wait to get mine installed
  17. Jun 5, 2020 at 1:16 PM
    #2897
    leebrachi
    leebrachi Member
    It’s perfect! Rides really smooth, absorbs everything real good. I can’t compare to stage 1, but compared to stock it’s a HUGE difference. I haven’t had a chance to go off-road neither but I’m sure for the amount I’ll be doing this is the prefect set up.
    Gs4x46mt, patdeezy[QUOTED] and Azdvo like this.
  18. Jun 5, 2020 at 1:17 PM
    #2898
    leebrachi
    leebrachi Member
    If you send me a shipping label I’ll send it over your way! PM me if you want it.
  19. Jun 5, 2020 at 11:45 PM
    #2899
    Gs4x46mt
    Gs4x46mt Member
    Grant
    4x4 OR 6Speed
    Looking for suggestions...
    Congratulations man. I plan on going from stock to stage 2 by the end of the month or so. Would like to see some pictures when you are able. I check this thread constantly and am excited to see how you like it. Any advice/photos would be, greatly, appreciated and helpful.
  20. Jun 6, 2020 at 4:48 AM
    #2900
    Tmaloy
    Troy
    2019 SR DC LB
    So after a clean and wash, I found out my TPMS sensors are registering over 40lbs on the install, I'm going to air down and try and level out the tires and do a calibration and chalk test. I hope to run around 37 front and 35 rear to get a bearing on the truck. Hopefully that will help the MPG. Fingers crossed.
