Eibach pro lift kit
Discussion in '3rd Gen. Tacomas (2016+)' started by Raw31993, Apr 19, 2018.
  1. Jul 28, 2020 at 4:32 AM
    #3341
    Ricster
    Ricster Active Member
    Ric
    2020 TRD Off Road
    It’s a 1/4” spacer that is placed on the top hat of the front drivers side spring. I asked about it when I bought the kit from Wheelers and they suggested it. I think it was $11. I read a bunch about this on the forum as well. Apparently the stock suspension takes into account some sort of left front end lean the truck has but aftermarket suspensions don’t. Glad I got it because I am level with it.
    71tattooguy likes this.
  2. Jul 30, 2020 at 12:06 AM
    #3342
    volblood
    volblood Member
    jason
    Big ORANGE country
    2019 double cab TRD off road - super white
    Eibach pro truck lift system - set at middle notch JBA upper control arms 2” readylift rear block (changing soon to wheelers aal) Meso customs has hole AJT KEY FOB/black vent rings/cup holder/start button/4wd button TRD pro grille Tacomabeast raptor grille lights Auxbeam led low beam bulbs N2 remote start Rough Country inline speedometer recalibrator Nitto Ridege Grappler 285/70/17 Fuel Covert 17x9
    Anybody on here set on the first notch running 285/70/r17 tires? If so, any rubbing?
    Gs4x46mt likes this.
  3. Jul 30, 2020 at 6:59 AM
    #3343
    Sandman TRD
    Sandman TRD Well-Known Member
    Indy
    2018 Black DCSB TRD Off Road 4x4
    Yes, a lot of guys are. Rubbing will really depend on how aggressive your offset is. For example, you will have much less chance of rubbing with a 0 offset wheel than you would with a -10 offset. Also depends how much you will be pushing the suspension. Lots of variables.
  4. Jul 30, 2020 at 7:26 AM
    #3344
    Cement_Bane
    Cement_Bane @Cement_Bane
    Luis
    Portland, OR
    2019 Cement Tacoma TRD Off Road 4x4 DCLB
    I rub a little bit driveways and backing up.
    With a passenger it happens more often but not all the time.
    • First notch
    • Stock UCAs
    • No CMC... yet (coming soon)
    • 17x9 0 offset wheels
    • 285/70/17 duratracs
    dewelrTX and CementMixr like this.
  5. Jul 30, 2020 at 7:52 AM
    #3345
    Dave3359
    Dave3359 Well-Known Member
    Dave
    Ct
    2018 Blazing blue access cab
    In regards to the rubbing issues I have a SR5 with stock 16” wheel I just installed the stage 1 kit first notch want to put on 17 “ 4 runner wheels with 285/70/17 where do I find out the off set of stock wheels TIA
  6. Jul 30, 2020 at 8:19 AM
    #3346
    Cement_Bane
    Luis
    Portland, OR
    back of the wheel on the inside. Basically the other side of the face of the wheel
  7. Jul 30, 2020 at 8:51 AM
    #3347
    Dave3359
    Dave
    Ct
    I get that. the inside of the wheel mounting to the back of the rim give you X dimension. My question is where does 0 off set start?
  8. Jul 30, 2020 at 9:56 AM
    #3348
    THE_KiRRAx
    THE_KiRRAx Well-Known Member
    Tampa, Florida
    2016 BBP Tacoma SR5 DCSB
    Check this thread to see if your wheels are on the list, MIGHT have the info you want. MAYBE....
    https://www.tacomaworld.com/threads/wheel-specs.30754/
  9. Jul 30, 2020 at 1:10 PM
    #3349
    Dave3359
    Dave
    Ct
    Thanks for the link unfortunately the one I’m looking at aren’t there. I’ll do some more research
    THE_KiRRAx likes this.
  10. Jul 30, 2020 at 2:38 PM
    #3350
    iamjase
    iamjase Well-Known Member
    Jase
    Maryland
    2019 MGM Tacoma TRD Offroad
    Install done on the first notch. Wheels and tires will be put on this Saturday.
    EOi-vvpcPJ5dd3g1zYbYBro-9d6nNuIOwZX0hSjd_908e462d556c626ea7fbdba7d34741f9e303630c.jpg
  11. Jul 30, 2020 at 5:42 PM
    #3351
    lawrenceu88
    lawrenceu88 Well-Known Member
    Lawrence
    2019 Black TRD Sport 4x4
    What size wheels and tires you getting? And why did you decide on the 1st notch. I am trying to decide myself. Thanks
  12. Jul 30, 2020 at 6:05 PM
    #3352
    waltuo
    waltuo Well-Known Member
    InterWebs
    Tacoma
    You already asked about the first notch.
  13. Jul 30, 2020 at 6:13 PM
    #3353
    RNO_TACO
    RNO_TACO Well-Known Member
    NorCal
    2019 Cement Grey Tacoma TRD Off-road 4x4 DCSB
    Softtopper, black out emblems, star armor side steps, CAI, TRD exhaust, TRD 16in rims, Meso coin holder, TRD skid plate, 2/1 suspension lift
    For the people who have ran both this Eibach stage 1 kit and Bilstein 5100s on OME springs, which would you prefer and why?
    I literally have both kits in my cart at headstrong and for the life of me can’t make a final decision because they both are good. So opinions needed from people who have ran both. Please and Thankyou.
  14. Jul 30, 2020 at 6:26 PM
    #3354
    iamjase
    Jase
    Maryland
    I have 16 inch SCS Ray10s and KO2 265/75 tires going on Saturday. I just did the first notch since I don't have a aftermarket bumper going on. Eibach recommended that if you don't have any armour up front to just run the first notch. I also have the ICON 3 leaf AAL on with the overload taken out.
  15. Jul 30, 2020 at 6:34 PM
    #3355
    lawrenceu88
    Lawrence
    I never asked you. Some people have their different reasons.
    Some people put it on the 2nd notch and don't have an aftermarket bumper.
  16. Jul 30, 2020 at 6:35 PM
    #3356
    waltuo
    InterWebs
    Tacoma
    It’s all the same reason though. Eibach recommends first notch if there is no added weight in front.
  17. Jul 30, 2020 at 6:36 PM
    #3357
    lawrenceu88
    Lawrence
    Like I said, I never asked you
  18. Jul 30, 2020 at 6:39 PM
    #3358
    waltuo
    InterWebs
    Tacoma
    You’re gonna ask everyone why they set it to first notch when it’s obvious why? Ok.
    Some people read through these types of threads to gather info, not to read the same question, by the same poster(you), that will almost guarantee yield the same answer.
    NO ADDED WEIGHT IN FRONT.
  19. Jul 30, 2020 at 6:42 PM
    #3359
    lawrenceu88
    Lawrence
    Why you being a Dick! I am just asking another person's opinion. Some people put it on a different setting because they want to, or because they have bigger tires, or they want a higher lift. Simple as that.
  20. Jul 30, 2020 at 6:45 PM
    #3360
    waltuo
    InterWebs
    Tacoma
    But you’re asking why on the first notch. I haven’t read one post that said they set it on the first notch because they wanted more lift. Or because they had a winch. Or because they had a steel bumper. The first notch is for no added weight in front. Simple as that. There are no variables to the first notch.
