Eibach pro lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Raw31993, Apr 19, 2018.
  1. Aug 28, 2020 at 8:05 AM
    #3501
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Your dealership can turn the front collision sensor off if you sign a waiver. The system is kinda bitchy when it comes to any kind of lift.
  2. Aug 28, 2020 at 8:07 AM
    #3502
    DTaco22
    DTaco22 Well-Known Member
    Darian
    17' Taco. TRD OR
    3" Eibach lift, JBA high caster upper control arms, 2" ToyTec add-a-leaf
    Yes to both. 1.5" wheel spacers.
  3. Aug 28, 2020 at 8:12 AM
    #3503
    Taco Guy11
    Taco Guy11 Well-Known Member
    Joe
    Western Maryland
    2020 Tacoma TRD off-road
    Will the truck be drive-able till i can make it to the dealer? i understand i will have lights on or flashing but its not going to go into limp mode or nothing right? The closest dealer is like 2 hours from me.
  4. Aug 28, 2020 at 9:12 AM
    #3504
    ReconMarine
    ReconMarine Well-Known Member
    Ed
    2019 White Tacoma TRD Sport
    I just pulled the trigger on these today from Wheeler. Is there a sensor issue when you add a lift? I have a steel bumper that weighs 153 lbs with 32 inch light bar and no winch so I asked for the struts to be set to the second perch so it can settle to just 2 inches of lift.
  5. Aug 28, 2020 at 9:15 AM
    #3505
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Nothing of the sort. You just get a warning on your front HUD saying that your collision sensor isn't turned on. Shouldn't have any sort of flashing lights or weirdness going on.
    sometimes the system doesn't even notice and won't flash any warnings at all and it will work just fine. Basically, it just becomes inconsistent when you have a lift. Not really a huge deal and shouldn't affect drivability whatsoever.
    Taco Guy11[QUOTED] likes this.
  6. Aug 28, 2020 at 9:15 AM
    #3506
    Taco Guy11
    Joe
    Western Maryland
    I'm not sure thats what i'm trying to find out. I actually didnt think about it till now.
  7. Aug 28, 2020 at 9:17 AM
    #3507
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Basically if you've ever gotten dirt or mud or anything on that sensor window and it's giving you the error where it can't read, that's the error you're going to get. If it doesn't bother you, you don't have to have the dealer adjust it at all
  8. Aug 28, 2020 at 10:10 AM
    #3508
    Dave3359
    Dave3359 Well-Known Member
    Dave
    Fl
    2018 Blazing blue access cab
    I installed the stage 1 about a month ago 2” in the front and 2” in the rear zero issues with the TSS
    Hooper89 and CygnusX191 like this.
  9. Aug 28, 2020 at 10:14 AM
    #3509
    ReconMarine
    Ed
    Good to hear. :) I have a 2019 TRD Sport and the last thing i wanted was more surprises. I just want to stiffen up the suspension as it is my daily driver and the roads here suck. Did you add a block or the 3 AAL to get 2" in the back?
  10. Aug 28, 2020 at 10:17 AM
    #3510
    Dave3359
    Dave
    Fl
    I did the Icon 3 leaf AAL and JBA UCAs. Also just ordered Hellwig rear sway bar setup
  11. Aug 28, 2020 at 10:29 AM
    #3511
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    If the roads suck, stiff suspension is the last thing you want.
  12. Aug 28, 2020 at 10:31 AM
    #3512
    Dave3359
    Dave
    Fl
    I’m all about the handling i don’t do any off roading
  13. Aug 28, 2020 at 11:10 AM
    #3513
    ReconMarine
    Ed
    Ok let me explain what i'm looking for. I have a TRD SPORT with 153 lbs Body armor in the front with no winch and an 85lbs bumper in the rear. I know that with the stock suspension there is a bit of role and nose dive. Now when I mean the roads suck i mean that the roads for my daily commute have a few dips and when i travel now with the new bumper those dips bounce the truck a lot more that when stock. Maybe stiffer was not the correct word. I want a suspension that would minimize the bounce (dampen) on the dips and the rolls when traveling hard pack beach roads and my daily commute. I get to the occasional dirt trail but nothing that requires a 4x4. I see that the folks here claim a smoother more grounded ride than stock and that is what i am looking for. I hope that explains it better. :) Plus i'm looking to add 275/70/R17 so i want the 2" lift.
  14. Aug 28, 2020 at 11:39 AM
    #3514
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Gotcha that makes more sense lol. I've got a sport with armor back, sides, and underneath. Off road the sport suspension is.... Rough. So when you said the roads suck, I assumed broken up and potholes lol. Oops
    ReconMarine[QUOTED] likes this.
  15. Aug 28, 2020 at 6:26 PM
    #3515
    waltuo
    waltuo Well-Known Member
    Toyotas
    No issues with my truck and a friends truck. Both 18’s
    CygnusX191 likes this.
  16. Aug 28, 2020 at 7:13 PM
    #3516
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    So where are y'all ordering your kits from? Toytec seems to sell them way more expensively than eibach
  17. Aug 28, 2020 at 7:16 PM
    #3517
    weagle22
    weagle22 Well-Known Member
    Josh
    Birmingham, AL
    2018 Blue SR5 DCSB 4x4 2022 Lexus GX 460
    Bilstein 6112s/5100s Deaver AAL
    ToyTec will assemble them for you, has blocks for the rear, diff drop kit and new U bolts. I think all that’s about 850$ if i’m not mistaken.
  18. Aug 28, 2020 at 7:19 PM
    #3518
    DTaco22
    Darian
    17' Taco. TRD OR
    Wheelers will assemble it for less than $600.
    I only ordered extended ubolts and 2" add a leafs from toytec
  19. Aug 28, 2020 at 7:44 PM
    #3519
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Diff drops aren't worth it imo, more stuff to break.
    I plan on doing aal and extended u bolts as well as a u bolt flip
  20. Aug 29, 2020 at 6:38 AM
    #3520
    Chad7088
    Chad7088 Old Newbie
    Chad
    19th state
    ‘20 Tacoma Off Road DCSB 4x4 MT
    Lots to come
    Anybody order from Headstrong with the add a leaf option? Did you get new extended Ubolts? I didn't received any Ubolts if they were suppose to send with the kit...The front is done and was going to do the rear today..and noticed this...now i'm :mad:
