Eibach pro lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Raw31993, Apr 19, 2018.
  1. Oct 15, 2020 at 6:51 AM
    #3881
    ReconMarine
    ReconMarine Well-Known Member
    Ed
    2019 White Tacoma TRD Sport
    That 1/4" spacer is for the driver side lean is to compensate for the gas tank. You just add it to the top of the driver side strut. I did the install myself and never worked on suspensions before. I went with the Eibach kit myself. I am still waiting on the AAL to get to me so i can finish the rear. I'll post pics once I'm done.
    CygnusX191 and 71tattooguy like this.
  2. Oct 15, 2020 at 6:54 AM
    #3882
    jeremy5000
    jeremy5000 Well-Known Member
    Philadelphia
    Are those 265s?
  3. Oct 15, 2020 at 7:04 AM
    #3883
    Sakhone712
    Sakhone712 Well-Known Member
    Sakhone
    2016 TRD OFF Road Silver
    so i would add this spacer to the driver side? which rear AAL did you go with?
    and what were your goals?
  4. Oct 15, 2020 at 7:30 AM
    #3884
    ReconMarine
    Ed
    Yes on that spacer but get in in aluminum, not polyurethane. AAL that I went with is wheeler but I have not received it yet. Maybe others that have them installed can give you opinions on what they installed. I just went with the single AAL that should give me 1.5" to 2". I might leave the overload leaf in. Not sure about that yet. I'm just doing it for aesthetics since i don't haul much. It depends on if you toe or have a load on the bed like a tent and stuff.
    Parma, CygnusX191 and 71tattooguy like this.
  5. Oct 15, 2020 at 7:31 AM
    #3885
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Leave overload in IMO
  6. Oct 15, 2020 at 7:59 AM
    #3886
    Cobrado
    Cobrado Member
    Longmont, CO
    17OR
    Recommend leaving in the Overload. Installed the same Eibach kit with Wulf AALs and left in the Overload. Netted +2" in the rear and rides better than stock setup.
  7. Oct 15, 2020 at 8:01 AM
    #3887
    THE_KiRRAx
    THE_KiRRAx Well-Known Member
    Tampa, Florida
    2016 BBP Tacoma SR5 DCSB
    I went with the Headstrong 3 leaf AAL, advertised as 1.5" but you're supposed to remove the overload leaf. Kinda happy with the results, though I wish the truck had a bit of rake (for if I haul anything in bed) to it, might swap to a different AAL or leaf pack in future. Truck sits perfectly level now.
  8. Oct 15, 2020 at 8:02 AM
    #3888
    71tattooguy
    Dino
    Petaluma , Ca (707)
    You can re install your overload if you want.
  9. Oct 15, 2020 at 8:51 AM
    #3889
    THE_KiRRAx
    Tampa, Florida
    Yeah, I gotta look at that. I thought this was discussed before and HS mentioned that the AAL wasn't really designed to work with the overload as the overload was actually longer than the shortest leaf on the AAL. Or something like that, or maybe I'm mis-remembering things and now I'm just talking out of my ass. :rofl::rofl::rofl:
  10. Oct 15, 2020 at 9:07 AM
    #3890
    ShouldItBeDoingThat
    ShouldItBeDoingThat Well-Known Member
    Unclean
    The West
    18' MGM Tacoma TRD Sport OVTuned
    Eibach pro truck kit + Icon 1.5" progressive AAL 255/75/17 Continental Terrain Contact AT LED interior light kit. Derp: wheels, grill
    @THE_KiRRAx, you are right about the overload being too long. I had mine cut down to where it wouldn't interfere with the AAL and reinstalled them. They work just fine. You may need longer U bolts if they where barely long enough to begin with.
    THE_KiRRAx and 71tattooguy like this.
  11. Oct 15, 2020 at 9:49 AM
    #3891
    THE_KiRRAx
    Tampa, Florida
    Thanks for clarifying that for me mate, I'll look into this. I THINK I should be fine with the u-bolts HS sent me, I have a couple inches of threads left and I was lazy so I haven't cut them down yet. Laziness might pay off it seems, haha.
    71tattooguy and CygnusX191 like this.
  12. Oct 15, 2020 at 1:40 PM
    #3892
    ReconMarine
    Ed
    DO any of you here have a 2WD TRD double cab that has or are planning to do the Eibach lift? Regardless can anyone of you that has not lifted the truck give me the measurements from the center hub to the bottom of the fender?
    CBrob likes this.
  13. Oct 15, 2020 at 8:58 PM
    #3893
    Sakhone712
    Sakhone
    Sounds good show me before and after pictures please
    CygnusX191 likes this.
  14. Oct 15, 2020 at 11:46 PM
    #3894
    hwntaco20
    hwntaco20 Well-Known Member
    2020 Tacoma TRD Offroad 2wd
    here u go:
    2020 DBL CAB SB 2WD Off Road
    hub to fender LF = 20 5/8 RF = 20 7/8 (pre lift)
    shouldn't matter for the measurement but running OEM Wheels and 265-75-16 GY Duratracs
  15. Oct 15, 2020 at 11:50 PM
    #3895
    waltuo
    waltuo Well-Known Member
    Toyotas
    Those numbers can’t be right?
    edit: nevermind, I was thinking ground to fender haha.
  16. Oct 15, 2020 at 11:57 PM
    #3896
    hwntaco20
    shucks! was just going to ask if you want to bet on it? lol no worries
    my ground to fender is 35 1/4 and 35 1/2 but shouldn't go off those #'s as a gauge.
  17. Oct 16, 2020 at 12:15 AM
    #3897
    waltuo
    Toyotas
    Nah I was just thinking that cause @ReconMarine measured that way.
  18. Oct 16, 2020 at 4:30 AM
    #3898
    ReconMarine
    Ed
    Thanks. I've been back and forth with Eibach on this and even went to a dealership and found a truck with the same wheels and tires and 20 ish is what I'm getting too. I got 24 from hub to fender after the lift but it has dropped almost an inch driving it around. I'm hoping that after the weekend it settles down some more. I also filled up the tank so that weight might have something to do with it dropping almost an inch. 4 inches out of this lift should not be normal. The tires I have are the 265/65/17
    Thanks again.
  19. Oct 16, 2020 at 9:25 AM
    #3899
    LOSOROSO
    LOSOROSO Member
    2016 Inferno Tacoma TRD OR
    I have stock UCA’s with no running, what would cause the rubbing is the offset of your wheel choice. My offset is 0, i have no rubbing, stock tacoma OR wheels have a positive offset and will rub
    xtrmnop[QUOTED] likes this.
  20. Oct 17, 2020 at 6:14 PM
    #3900
    xtrmnop
    xtrmnop Well-Known Member
    Karl
    Austin
    2019 Cement TRD OR
    Nice. Yeah have 0 offset on my RPT1s. Still have decent thread on my tires so probably just wait it out. Thanks.
