Eibach pro lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Raw31993, Apr 19, 2018.
  1. Jan 7, 2021 at 7:36 AM
    #4241
    patdeezy
    patdeezy Well-Known Member
    souLcaL
    '19 OR 4x4 SuperWhite DCSB
    Damn, that looks perfect. I have my Headstrong 1.5" AAL sitting in the garage waitingto install but I ordered the 0.5" spacer to give me the full 2" but after seeing your truck... I'm like hmmm :rofl::bananadead::anonymous:
    Parma[QUOTED] and CygnusX191 like this.
  2. Jan 8, 2021 at 10:52 AM
    #4242
    viclava
    viclava Well-Known Member
    Scott
    North Central Washington
    2020 Tacoma TRD Off-Road
    LED lights Eibach 2.5" coil and shock liift with 2" AAL W/2* shim in rear, RTT
    I’m now rethinking the spacer blocks for the rear part of my Eibach kit I’m going to install. If I add the 2” Wulf AAL in rear, will I need to do anything with diff, so as not to get vibrations from the lift in rear?
    japjoe7 likes this.
  3. Jan 8, 2021 at 10:58 AM
    #4243
    japjoe7
    japjoe7 Well-Known Member
    Joey
    Pike County, PA
    21 Barcelona Red Sport DC AT
    You may need to if you are going w/ the 2nd notch and Wolf leafs. Some people have used carrier bolt spacers and/or wedge shims.
    @Duke4x4 has his at the 2nd notch, Wolf AAL, and has been having some vibe issue. Although he mentioned they may have been there before the lift install.
    CygnusX191 likes this.
  4. Jan 8, 2021 at 11:18 AM
    #4244
    viclava
    Scott
    I also have a 1” spacer, and a tapered 1.5” spacer blocks as options. I am going to be installing the Eibach kit at the 2nd notch. I just thought with my RTT I carry(120lbs) the AAL might be better. I don’t want vibes, and thought with the tapered 1.5” spacer block, that would prevent that. With just the AAL, I wasn’t sure. I’m not sure which I should go with. I generally don’t haul a lot of heavy stuff.
  5. Jan 8, 2021 at 11:34 AM
    #4245
    japjoe7
    Joey
    Pike County, PA
    I mean you could go with blocks with a RTT but you will prob. see your leafs start to flatten at some point, an AAL would help to combat that. Either way you may need carrier bolt spacers or shims with that height you want in the back.
    CygnusX191 and 71tattooguy like this.
  6. Jan 8, 2021 at 11:50 AM
    #4246
    viclava
    Scott
    What size carrier bolt kit do I need to prevent vibes with a 2.5” lift up front, and a 2” AAL in rear? Will I still need shims too?
  7. Jan 8, 2021 at 11:59 AM
    #4247
    japjoe7
    Joey
    Pike County, PA
  8. Jan 8, 2021 at 12:26 PM
    #4248
    Miles009
    Miles009 Well-Known Member
    Miles
    2019 TRD sport
    OME 887 w/ AAL
    I did the OME 887 with deaver AAL. Got 3.25 inches of lift over stock. Can’t align the truck now. Need aftermarket UCAs. Truck is all over the road
    71tattooguy and japjoe7 like this.
  9. Jan 8, 2021 at 12:30 PM
    #4249
    viclava
    Scott
    Yes, I decided after talking with guys at Eibach, that going with 2nd notch up front(I ordered aftermarket UCA’s) and go with the Wulf 2” AAL in rear, it will be good.
    I guess if there’s a vibe due to driveline angle, then I’ll try the Toytec carrier drop spacers.
    Sheesh!! So many decisions..
  10. Jan 8, 2021 at 12:34 PM
    #4250
    japjoe7
    Joey
    Pike County, PA
    Yeah, I wish it was as easy as we want it to be. I want the same exact components (2nd notch/Wolf AAL) and lift you are looking at. I'm just going to expect to get vibes and prepare myself for that headache.
  11. Jan 8, 2021 at 12:36 PM
    #4251
    viclava
    Scott
    Yea, I’m going to just go ahead and order a carrier spacer drop kit. If I don’t need it, then oh well.
  12. Jan 8, 2021 at 12:40 PM
    #4252
    viclava
    Scott
    Hmm, I’ll have to reach out to him to track how he gets rid of it. Thanks for the heads up.
    scott
  13. Jan 8, 2021 at 12:48 PM
    #4253
    japjoe7
    Joey
    Pike County, PA
    887's are known for settling so you will lose some height in the front. UCA's are a must with those lift heights.
  14. Jan 8, 2021 at 12:53 PM
    #4254
    MrBrooks
    MrBrooks Well-Known Member
    Midwest
    2018 DCSB - 2021 Rav4
    Didn't Toyota correct the front vibration in 2019 & newer truck by not using the needle bearing anymore?
    I have the rearend clunk already but hoping some angle shims will get rid of that
  15. Jan 8, 2021 at 12:54 PM
    #4255
    Miles009
    Miles
    2019 TRD sport
    OME 887 w/ AAL
    I currently have 1,027mi on the lift .
  16. Jan 8, 2021 at 1:09 PM
    #4256
    japjoe7
    Joey
    Pike County, PA
  17. Jan 8, 2021 at 1:12 PM
    #4257
    japjoe7
    Joey
    Pike County, PA
    No, needle bearing have not been replaced in the '19-present trucks. It's still a good idea to replace it if you think you're getting the front vibes.
    MrBrooks[QUOTED] and CygnusX191 like this.
  18. Jan 8, 2021 at 1:21 PM
    #4258
    japjoe7
    Joey
    Pike County, PA
    Hey, also you might want to order a shim as well in case you need it. Better safe than sorry. https://www.headstrongoffroad.com/store/p119/Axle_Shims_-_(2_degree_to_4_degree).html
  19. Jan 8, 2021 at 1:25 PM
    #4259
    viclava
    Scott
    Yea, no clue which degree I would need..
  20. Jan 8, 2021 at 1:30 PM
    #4260
    japjoe7
    Joey
    Pike County, PA
    From what I've read, "calculate 1 degree for every inch of lift so if 2 inches of lift, 2 degree shims."
