Eibach pro lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Raw31993, Apr 19, 2018.
  1. Jan 8, 2021 at 1:31 PM
    #4261
    viclava
    viclava Well-Known Member
    Scott
    North Central Washington
    2020 Tacoma TRD Off-Road
    LED lights Eibach 2.5" coil and shock liift with 2" AAL W/2* shim in rear, RTT
    Ahhhh, makes total sense. I think I will. Can’t hurt to throw them in there with the install.
    CygnusX191 likes this.
  2. Jan 8, 2021 at 1:35 PM
    #4262
    darkside2k19
    darkside2k19 Well-Known Member
    Horseshoe Bay, TX
    2019 TRD Sport
    installed mine yesterday on the 2nd notch with a 1.5 block in the rear and added the carrier bearing drop just incase. so far everything has been good with no vibrations or any other issues. i do have jba uca sitting around that i can install if i need to down the road. front should settle down in after driving a while and end up nice and level with the rear
  3. Jan 8, 2021 at 1:40 PM
    #4263
    viclava
    Scott
    Lastly, I wonder if I’ll need new U bolts for rear axle with the combo of shims and AAL..
  4. Jan 8, 2021 at 1:41 PM
    #4264
    darkside2k19
    Horseshoe Bay, TX
    2019 TRD Sport
    i would definitely recommend getting new u-bolts when adding those. ive done aal and shims on my previous trucks and always installed new u bolts just to be safe.
    MrBrooks likes this.
  5. Jan 8, 2021 at 1:53 PM
    #4265
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Rule of thumb with U-bolts, if they're being removed, new ones should be installed.
  6. Jan 8, 2021 at 1:59 PM
    #4266
    viclava
    Scott
    Will stock size work with the 2 degree shims and 2” AAL?
  7. Jan 8, 2021 at 3:49 PM
    #4267
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Tires? Yes....
  8. Jan 8, 2021 at 4:01 PM
    #4268
    viclava
    Scott
    Sorry, I meant stock U bolts for rear axle
  9. Jan 8, 2021 at 4:27 PM
    #4269
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Lol I should have gathered that from your posts.
    Since you're doing an add a leaf that should net you around 2 inches of lift, I would say be safer to go with longer u-bolts. Especially because they're really not much more expensive than a new set of stock length bolts.
  10. Jan 9, 2021 at 8:26 AM
    #4270
    viclava
    Scott
    I’m also wondering about the front Diff drop kit as well.. since I have the TRD skid plate, I’m sure I will need some sort of drop kit for that too.
  11. Jan 9, 2021 at 8:29 AM
    #4271
    Parma
    Parma Well-Known Member
    Adam
    Utah
    2019 TRD Off Road
    When I had my kit installed, the installer said they don’t do them for lifts less than 3”. And the companies that make the lift kits don’t suggest them either.
  12. Jan 9, 2021 at 8:36 AM
    #4272
    viclava
    Scott
    Hmm, the service tech at the Toyota dealer I go to, is an avid off-road 4Runner guy, and he suggested it. I told him all I’m doing is 2.5” up front and a 2” AAL in rear, with the 2degree shims in rear. If I have to I will, but dropping it just means I’m lowering components, which of course is opposite of what I’m trying to achieve with lift.
  13. Jan 9, 2021 at 8:43 AM
    #4273
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    At 2.5, you shouldn't need it. And yes, hanging the important stuff back down low defeats the purpose of a lift.
    But remember, to gain true clearance, you need bigger tires. Suspension lifts help with suspension travel/handling/flex, but they also help make room for larger tires.
  14. Jan 9, 2021 at 8:45 AM
    #4274
    viclava
    Scott
    I just bought 265/75/16 Wildpeaks. Not sure how they’ll look with the 2,5” lift. Hoping it looks ok.
  15. Jan 9, 2021 at 8:50 AM
    #4275
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    I'd change to 275 but that's me.
  16. Jan 9, 2021 at 8:53 AM
    #4276
    viclava
    Scott
    Well I just purchased prior to ordering the lift, which in hindsight was not the wisest decision..
    CygnusX191 and OMGitsme like this.
  17. Jan 11, 2021 at 5:31 PM
    #4277
    drumcj
    drumcj Active Member
    Christian
    Silver 2018 Tacoma TRD sport
    How did it settle with the bumper on?
  18. Jan 11, 2021 at 6:02 PM
    #4278
    OMGitsme
    Sold
    Didn't move at all.
  19. Jan 12, 2021 at 11:56 AM
    #4279
    drumcj
    Christian
    Finally got everything installed, aligned and on the road!
    1st notch
    1.5” blocks in rear
    275/70r17 ray 10’s
    Only have about 15 miles on the new set up but loving it so far!
  20. Jan 12, 2021 at 12:03 PM
    #4280
    ReconMarine
    ReconMarine Well-Known Member
    Ed
    2019 White Tacoma TRD Sport
    Really looks good with the new tires as well as the lift. Didn't realize that 275s can make that big of a difference.
    CygnusX191 and drumcj[QUOTED] like this.
