Eibach pro lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Raw31993, Apr 19, 2018.
  1. Feb 8, 2021 at 7:34 AM
    #4421
    Aqualoon
    Aqualoon More stickers!
    Minnesota
    2019 Off-Road DCSB Cavalry Blue
    So let me get some thoughts from you guys...
    Getting the Eibach Pro kit once it comes back in stock later this month/early March.
    Base kit w/strut assembly is $700. Deaver single leaf is $100, 3-leaf is $200 or there is a block/u-bolt kit for $100.
    I want to do a 2" lift in the front and 1.5" lift in the back, I don't do any off-roading or towing. What is the best route I should take with the above rear options?
    CygnusX191 likes this.
  2. Feb 8, 2021 at 7:37 AM
    #4422
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Regardless of which way you go, see if you can get a differential carrier bearing drop or axle shims to help with your driveline angle. It'll keep vibrations down which sometimes happen when you start lifting the rear.
  3. Feb 8, 2021 at 7:38 AM
    #4423
    Aqualoon
    Minnesota
    Excuse my ignorance but that was pretty much all gibberish to me. Is this something I should request from the shop I have install the lift?
    CygnusX191[QUOTED] likes this.
  4. Feb 8, 2021 at 7:59 AM
    #4424
    jeffmansion
    jeffmansion Well-Known Member
    16UTILITY4x4MT2.7
    K&N 63 series CAI, AVS Vent Visors, 16x8 Level 8 MK6 Rims, 285/75/16 MT, Eibach Pro lift, JBA UCAs, Wheelers 3leaf AAL, DV8 skidplate, Westin bedmat, Backrack, swaybar delete, Magnaflow cat-back, 9Drive throttle controller, 2LO Mod, Cali Raised Rock Sliders, Tyger rear bumper, Chinese Body Armor front bumper clone, 10K pound Winch, Smoked headlights, LED Bulbs.
    For Best Ride:
    I would go with the 3 leaf AAL. W/O Overload spring to net around 1.5'' rear lift.
    I'm running the wheelers 3 leaf AAL + Overload spring and happy with the setup and ride.
    I would skip the diff drop and CB drop for now.
  5. Feb 8, 2021 at 8:02 AM
    #4425
    IrishRed
    IrishRed Appalachian Ridgerunner
    Central PA
    2017 TRDOR DCSB 4x4 MGM Prem&Tech Auto
    Eibach Suspension, JBA UCA’s, 16” SCS Ray 10s, BFG KO3s, ECGS Bushing, Pro Skid Plate, Fumoto Valve, Pro Grille, Opt7 Tailgate Light Bar, AVS Window In-Channel Vents, Roknlokz XL Mud Flaps, Husky Floor Mats, Bed Mat, Tailgate & Glovebox Letter Inserts, TRD Grille Badge, Exhaust Tip, Toyota Hitch Plug.
    Wow! I was unaware of this. That’s too bad. Anyone know why?
    CygnusX191[QUOTED] and patdeezy like this.
  6. Feb 8, 2021 at 12:53 PM
    #4426
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    OME kits come with a carrier bearing drop kit, might have to ask about the others. It's a simple metal spacer with longer nuts that goes under the carrier bearing (where your two piece driveshaft connects). Should be a pretty cheap add on.
    I believe she and the Mr. Sold their share/portion/half (however it broke down). Not sure if they just wanted to retire or change it up or what.
  7. Feb 8, 2021 at 9:49 PM
    #4427
    AH17
    AH17 Well-Known Member
    2018 Tacoma TRD Off Road
    Thanks for the info. I might be screwed then because I have the 2020 TRD Pro wheels on mine and they have a positive offset. I believe your wheels have a negative offset, am I correct?
    I do not haul or tow anything either so I should also be fine with blocks if I decide going with that route.
  8. Feb 15, 2021 at 10:35 AM
    #4428
    MGM13
    MGM13 Well-Known Member
    Joe
    Knoxville, TN
    19 TRD Sport Cavalry Blue
    Eibach Pro Kit 1.5" rear blocks 285/70R17 Ridge Grapplers
    Sorry, just saw this. No CMC. I had to remove the front black air dam piece below the bumper (TRD Sports have this) and remove the mud flaps. I did a little bit of plastic trimming but that was only because I did the 285's before the lift. If you do the lift first you shouldn't have to trim anything:cheers:
  9. Feb 15, 2021 at 10:40 AM
    #4429
    Aqualoon
    Minnesota
    Thanks! I'm also running a -10 SCS wheel so it's good to see I'll have some tire options once I get the lift. I had to do some trimming and heat gunning my liners to even get 265s on without rubbing.
  10. Feb 15, 2021 at 10:59 AM
    #4430
    MGM13
    Joe
    Knoxville, TN
    Yes sir, you're welcome! I'm surprised you had to do some trimming with the 265's. I had to do minor trimming and modifications to fit the 285's and -10 offset with NO lift but was able to get rid of 90-95% of the rubbing. You can check out what I did here, again that was with no lift though.. post #2486 on this thread https://www.tacomaworld.com/threads/eibach-pro-lift-kit.545060/page-125
    Aqualoon[QUOTED] likes this.
  11. Feb 15, 2021 at 11:03 AM
    #4431
    Aqualoon
    Minnesota
    I was too. I spent months reading all the SCS threads in the wheel/tire section and came down to that I'd have to take off the mud guards and after that I shouldn't rub much at all. I was wrong but it worked out well because I learned a lot from having to correct that. After I get my lift done (plan on buying the kit when it comes back in stock at Headstrong Offroad) I may just stick with 265s for awhile. Although I really really want to move to 275s for no other reason than I like the look better. That's been the story about my entire truck, I don't offroad I just mod because I like the looks, so it's a hardware store crawler as I don't do malls.
  12. Feb 15, 2021 at 11:25 AM
    #4432
    MGM13
    Joe
    Knoxville, TN
    I understand that..I don't take mine offroad either. I bought my kit pre-assembled from Headstrong. My wife just bought a 4runner so now I'm starting all over again with all the online reading haha!
  13. Feb 15, 2021 at 5:02 PM
    #4433
    viclava
    viclava Well-Known Member
    Scott
    North Central Washington
    2020 Tacoma TRD Off-Road
    LED lights Eibach 2.5" coil and shock liift with 2" AAL W/2* shim in rear, RTT
    Does anyone know if when I install my Eibach kit on the 2nd setting up front with a 2" AAL in the rear is gonna cause both vibration issues and over extension of the rear Eibach springs? I bought 2mm rear axle shims just in case> I wanted some rake in the back, but not a huge amount, as I do carry a 130lb-ish RTT on back most of the year. Any input appreciated.
    Scott
  14. Feb 15, 2021 at 7:47 PM
    #4434
    Seoul Brother
    Seoul Brother Member
    James
    Gilbert, AZ
    2021 Silver Sky TRD OR MT
    I'm running my fronts on the second notch but I'm running 2 inch blocks (tapered) in the rear. Did not use any carrier bearing or diff drops kits. No vibrations or overextended shocks. Rides great.. You should be fine.
  15. Feb 15, 2021 at 7:50 PM
    #4435
    viclava
    Scott
    Cool, thanks for the response.
  16. Feb 16, 2021 at 7:46 AM
    #4436
    swoly
    swoly Well-Known Member
    Apex, NC
    2021 TRD Sport 4x4
    Hey all. I know all of our trucks are a little different, but is there a general consensus on stock ('17 TRD Off Road DCSB) hub to fender measurements? I didn't measure pre-lift and I wanted to check out what I actually have for lift after 1.5 years and 30,000 miles. I'm on the lowest setting with 1/4" driver side spacer and Wheeler's 1.5" add a leaf. Thanks!
  17. Feb 16, 2021 at 8:29 AM
    #4437
    Parma
    Parma Well-Known Member
    Adam
    Utah
    2019 TRD Off Road
    I believe it's 21" for the front and 22" for the rear for 3rd gens
    CygnusX191 and swoly[QUOTED] like this.
  18. Feb 21, 2021 at 10:58 AM
    #4438
    CascadianAngler
    CascadianAngler Send It & Mend It
    Brad
    Washington
    2018 DCLB
    Looking at doing this kit and wondering this: I just got some new 265-70 16 tires for super cheap and don’t want to replace for a year or two. I know it would probably look like I skipped leg day if that was all, but I am running my front/trans steel skids(68lbs), sliders(100ish lbs), and 27F(67lbs) battery up front and I have a canopy (170lbs) roof basket (40lbs unloaded), fridge (40ish lbs) plus tools/recovery gear that probably nets around 75lbs in the rear. The other thing is we tow a 2400-2800 lb trailer a lot of the summer too.
    Anyone think that weight will slightly drop the lift closer to 1.5-1.75” and look ok? Probably add a spacer on the driver for the lean as well.
    Any input is always appreciated.
  19. Feb 21, 2021 at 11:03 AM
    #4439
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Skip the spacer and go for a slightly stiffer driver side leaf spring. Quite a few options out there. But yeah it should settle just a bit and make you look less like you skipped leg day lol
  20. Feb 21, 2021 at 11:11 AM
    #4440
    CascadianAngler
    Brad
    Washington
    2018 DCLB
    The other option would probably be 5100’s with OME 885. Pretty close to the same price. Probably doing either Deaver or Wheeler’s AAL for the time being with the long term being a full Deaver leaf pack when I can afford it.
    71tattooguy likes this.
