Eibach pro lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Raw31993, Apr 19, 2018.
  1. Feb 28, 2021 at 7:25 AM
    #4481
    Parma
    Parma Well-Known Member
    Adam
    Utah
    2019 TRD Off Road
    Add a 1/4” spacer to the driver side for the good ole Taco Lean
    bobfrog02747 likes this.
  2. Feb 28, 2021 at 8:21 AM
    #4482
    Dirt McGirk
    Dirt McGirk Well-Known Member
    Phoenix, AZ
    19 TRD OR 4X4
    Thank you, just a 1.5 block in the rear.
    Sandman TRD[QUOTED] likes this.
  3. Feb 28, 2021 at 9:42 AM
    #4483
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Some leaf packs are side specific to account for taco lean. If this is the case with what you ordered, you won't need a spacer.
    As far as axle shims, diff drop, or carrier bearing drop, various people have had varying levels of success with different methods. Seems to be almost truck specific.
    If you off road, skip the diff drop.
    japjoe7 and 71tattooguy like this.
  4. Feb 28, 2021 at 10:29 AM
    #4484
    JP3
    JP3 Well-Known Member
    JP
    2020 SR5 /DCLB /MGM//////B7 Audi RS4
    285/70/17 Falken WildPeak on Stealth 6 Eibach Lift
    Forgot to mention I will not be taking the truck off roading.
    I have found little information on the diff. drop actually correcting cv angle. Also read you should do a driveshaft carrier drop as well.
    I may just do 1/4” lean spacer, 2” AAL and ECGS bushing and see what else I need after the install.
  5. Feb 28, 2021 at 11:44 AM
    #4485
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    The idea of those various carrier bearing and diff drops is to correct angles and drive line and CV. You can also get extended travel CVs from O'Reilly's for example which with a 2-in lift those are more than adequate. If you're not off-roading, diff drops should be fine.
  6. Feb 28, 2021 at 12:35 PM
    #4486
    steviek121
    steviek121 Member
    2020 Black Tacoma TRD Off Road
    Anyone know where to find this kit in stock? Haven’t had any luck so far.
    CygnusX191 likes this.
  7. Feb 28, 2021 at 12:57 PM
    #4487
    OMGitsme
    OMGitsme Well-Known Member
    Sold
  8. Feb 28, 2021 at 5:11 PM
    #4488
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
  9. Mar 2, 2021 at 8:01 AM
    #4489
    jn2399
    jn2399 Well-Known Member
    Jon
    2018 TRD Sport 4x4
    Pro Wheels.
    For you guys that got aftermarket UCA's for this lift, did it make a huge difference? I know the stock UCAs are fine but Would the upgrade be worth it in the long-run? I got the lift and an icon AAL and am trying to decide to get UCAs.
  10. Mar 2, 2021 at 8:11 AM
    #4490
    patdeezy
    patdeezy Well-Known Member
    souLcaL
    '19 OR 4x4 SuperWhite DCSB
    Aftermarket UCA comes more in handy when trying to fit aftermarket wheels as there's more room for caster adjustment. It would be worth it if you decide to get a more aggressive offset set of wheels down the road so you can massage more caster to help with clearance, although there's a bunch of guys running +0mm or even -10mm offset wheels on stock UCA.
    I did, however, upgrade my UCA because there was a GB on the ones I wanted.
  11. Mar 2, 2021 at 8:16 AM
    #4491
    jn2399
    Jon
    2018 TRD Sport 4x4
    Pro Wheels.
    Ah I see, I'm sunning the 4runner Pro SEMA wheels
  12. Mar 2, 2021 at 8:46 AM
    #4492
    patdeezy
    souLcaL
    I'm not sure of the exact specs of those wheels but I'm sure there's plenty of guys running those same wheels w/ stock UCAs. Tire size plays a part in overall fitment too
    CygnusX191 and jn2399[QUOTED] like this.
  13. Mar 2, 2021 at 8:52 AM
    #4493
    jn2399
    Jon
    2018 TRD Sport 4x4
    Pro Wheels.
    Yes, plenty is correct haha
  14. Mar 2, 2021 at 8:52 AM
    #4494
    TacoRoams
    TacoRoams Well-Known Member
    David
    Whittier, CA
    2019 White Tacoma TRD Off-Road
    does it matter what notch it is set too? for example if they were set too the 2nd notch would I need UCAs
  15. Mar 2, 2021 at 8:56 AM
    #4495
    patdeezy
    souLcaL
    I'm not certain but you technically don't need UCAs even for the first notch. I was running my stock UCAs on the bottom notch w/ stock OR wheels just fine
  16. Mar 2, 2021 at 9:05 AM
    #4496
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Anything at 2.5 inches or lower, the stock UCAs can handle. However, they have no caster adjustment. As stated above, if you're looking for more agressively sized wheels and tires, aftermarket UCAs are a must.
    japjoe7, patdeezy and 71tattooguy like this.
  17. Mar 3, 2021 at 10:19 AM
    #4497
    TacoRoams
    David
    Whittier, CA
    Anyone have any idea when these will be back in stock, I have been looking everywhere and can't find them in stock.
  18. Mar 3, 2021 at 10:25 AM
    #4498
    viclava
    viclava Well-Known Member
    Scott
    North Central Washington
    2020 Tacoma TRD Off-Road
    LED lights Eibach 2.5" coil and shock liift with 2" AAL W/2* shim in rear, RTT
    They told me last week that they would be receiving this week from manufacturing then shipping them to distribution, and then on to fulfilling orders already placed, like mine from Dec 4th. Hope that helps.
  19. Mar 3, 2021 at 10:42 AM
    #4499
    JP3
    JP
    I ordered mine from poly performance a few days ago. Received the email they were on back order. I called and they said 3 weeks.
    If you’re paying full price, you can get them on eBay. I would assume they are in-stock if they are listed.
  20. Mar 3, 2021 at 10:43 AM
    #4500
    viclava
    Scott
    Just relating what they told me..
