Eibach pro lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Raw31993, Apr 19, 2018.
  1. Oct 5, 2019 at 5:54 PM
    #921
    Prowlah
    Prowlah Well-Known Member
    SoCal
    2017 Silver DCSB TRD Sport 4x4
    @siKjiTz did you confirm it's your sway bar clunking on your brackets too?
  2. Oct 5, 2019 at 6:04 PM
    #922
    whitepony04
    whitepony04 The Big Igloo is coming...
    Tanner B
    Oklahoma
    19 trdordcsbxyz
    Eibach pro kit, 3 leaf aal, ecgs, fn fx pros, bfg ko2, gator sfx, Meso stuff
    I’ve had the kit on for about a month now, I love the ride. I don’t find it stiff or jarring at all. It’s a little firmer than stock but rides a lot better than I expected.
    CementMixr and siKjiTz like this.
  3. Oct 5, 2019 at 6:04 PM
    #923
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Simple solution: take the sway bar off :smack:
    There was zero noticeable difference before/after removing mine.
    siKjiTz likes this.
  4. Oct 5, 2019 at 6:15 PM
    #924
    Prowlah
    SoCal
    Are you running with any added weight?
  5. Oct 5, 2019 at 6:17 PM
    #925
    whitepony04
    Tanner B
    Oklahoma
    19 trdordcsbxyz
    Just a trifold tonneau and I’m getting fatter.
  6. Oct 5, 2019 at 10:46 PM
    #926
    siKjiTz
    siKjiTz Well-Known Member
    E
    Oahu, HI
    2017 DCSB TRD Sport Inferno
    TUNED 2.0 Beta 87 Eibach Pro Truck Lift Kit Stage 1 Wheelers 1.5” Progressive AAL Level 8 MK6 17x8 Falken Wildpeaks 265/70/17” Redline Tuning Hood struts Matt Gecko LED Bed lights OEM Roof racks GoRhino RB20 Running boards A/C drain Mod Kicker speaker upgrade w/kicker key amp. MESO Stage 1 Tail light upgrade OEM Bed Mat
    Yup, on the driver side only. Passenger side has about 1/2” clearance.
  7. Oct 5, 2019 at 10:47 PM
    #927
    siKjiTz
    E
    Oahu, HI
    Could you please snap a picture of the top of your strut? Looking to see if mine as an extra bushing on it.
  8. Oct 6, 2019 at 12:33 AM
    #928
    Jasonstacoma
    Jasonstacoma Well-Known Member
    2019 dcsb Barcelona red
    Stock
    900 installed?
  9. Oct 12, 2019 at 8:19 AM
    #929
    Twins09
    Twins09 Well-Known Member
    Dave
    Dutchess County, NY
    2019 MGM TRD Sport, 02 WS6 vert
    Vent visor, hood protector, door sill protector, next up eibach,SCS Ray 10s to be installed next week...
    Hey need some suggestions.... my installer installed my eibach kit on lowest setting.....and headstrong aal....problem is it still sits an inch lower in the rear. They want to add an 1 1/2 block....said add a leaf didnt do much....was told the front is sitting higher and looks like crap
  10. Oct 12, 2019 at 8:22 AM
    #930
    StZu
    StZu Where the White Women At?
    Richard
    Dallas Texas
    18 Super White TRD Offroad
    Level 8 Wheels, Bilstien/Eibach lift, 2" aal, blacked out rear bumper, AC drain hose relocation, sound deadening 4 doors and back wall, amp/speaker upgrade, 10" daytona sub, LED interior lights.
    did they leave the overload spring in?
  11. Oct 12, 2019 at 8:37 AM
    #931
    CementMixr
    CementMixr Well-Known Member
    2019 Tacoma OR 4x4 ACLB
    wait so even with the 3 leaf progressive aal pack it’s sitting lower?
  12. Oct 12, 2019 at 8:40 AM
    #932
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    sounds like they didn’t install the AAL.
    The rear should still be a half inch higher with a 1.5” AAL and the fronts on the lowest notch.
  13. Oct 12, 2019 at 8:42 AM
    #933
    whitepony04
    Tanner B
    Oklahoma
    19 trdordcsbxyz
    Mine sits exactly like this with the overloads out.
    snowtaco2 likes this.
  14. Oct 12, 2019 at 8:52 AM
    #934
    Prowlah
    SoCal
    Check that they indeed are on the lowest clip and that they installed the aal the correct way, with the long end toward the back.
    CementMixr likes this.
  15. Oct 12, 2019 at 8:55 AM
    #935
    Prowlah
    SoCal
    I'm assuming you aren't carrying any weight in the back right?
  16. Oct 12, 2019 at 8:57 AM
    #936
    Prowlah
    SoCal
    Did your ride soften up bit after the sway bar delete? I'm considering it now.
  17. Oct 12, 2019 at 9:03 AM
    #937
    Twins09
    Dave
    Dutchess County, NY
    It usually sits pretty level.....they said they took out the overload leaf. There is nothing in the bed. I know they had a toughtime with the add a leaf. And they said its installed on the lowest clip.
  18. Oct 12, 2019 at 9:08 AM
    #938
    Prowlah
    SoCal
    They definitely didn't install correctly
  19. Oct 12, 2019 at 9:12 AM
    #939
    Prowlah
    SoCal
    AAL should be at 1.5 inches with the overload out and front on lowest clip should be at roughly 2 to 2.5 inches max which in worst case scenario would put you at level.
  20. Oct 12, 2019 at 9:16 AM
    #940
    Prowlah
    SoCal
    Pics would help.
