Eibach pro lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Raw31993, Apr 19, 2018.
  1. Jan 1, 2020 at 4:04 PM
    #1521
    Ryan at Eibach
    Ryan at Eibach Well-Known Member Vendor
    Happy New Year!
    Burns, moser633 and siKjiTz like this.
  2. Jan 2, 2020 at 6:15 AM
    #1522
    wsb
    wsb Well-Known Member
    VA Beach
    2019 Cement TRD OR DCSB
    if i'm looking for a ~2 inch lift, would I want to set the clip at lowest setting?
  3. Jan 2, 2020 at 6:19 AM
    #1523
    AtomAnt
    AtomAnt Well-Known Member
    Adam
    South Cackalacky
    2019 TRD Sport
    Yes, lowest setting will give you 2” of lift unless you have added weight up front, like an aftermarket bumper/winch.
    wsb[QUOTED] and Burns like this.
  4. Jan 2, 2020 at 11:54 PM
    #1524
    tn111
    tn111 Well-Known Member
    2018 TRD Sport 4x4 MT
    It’s been 16 pages since we were told not to use the sway bar relocation kit. Install is Monday for me and wanted to actually make sure this solved the issue. Has anyone since installed this without the relocation kit? Did that actually solve the issue?:deadhorse:
  5. Jan 3, 2020 at 6:15 AM
    #1525
    MooseTaco87
    MooseTaco87 Active Member
    Shea
    Mulberry, IN
    2019 Toyota Tacoma TRD Offroad 4x4 DCSB
    I did not use the relocation kit. When I ordered my setup from toytec he said it was not needed and I have had no issue.
    tn111[QUOTED] likes this.
  6. Jan 3, 2020 at 6:30 AM
    #1526
    swoly
    swoly Well-Known Member
    Apex, NC
    2021 TRD Sport 4x4
    I did need the relocation kit as when we installed without it at first, there was contact. It seems as through everyone's truck is a little different.
  7. Jan 3, 2020 at 7:37 AM
    #1527
    AtomAnt
    Adam
    South Cackalacky
    2019 TRD Sport
    I didn’t need the relocation kit. 2019 Sport DCSB.
  8. Jan 3, 2020 at 7:55 AM
    #1528
    Ryan at Eibach
    That's been our conclusion, too. We think it's just a variance in Toyota manufacturing tolerances, which isn't uncommon. We've yet to see it at our place and install at least 1-2 a week.
    tn111 likes this.
  9. Jan 3, 2020 at 11:26 AM
    #1529
    tn111
    Do you no longer use the relocation kit at the shop?
  10. Jan 3, 2020 at 12:53 PM
    #1530
    Ryan at Eibach
    We leave it up to the customer, but always check for interference too.
  11. Jan 3, 2020 at 1:41 PM
    #1531
    Ryan at Eibach
    Anybody in Hawaii currently looking for a kit? I'd like to try a couple different shipping options to the islands. You'll save minimum $150. Holla!
    CUMMINGS 808 and siKjiTz like this.
  12. Jan 3, 2020 at 5:36 PM
    #1532
    patdeezy
    patdeezy Well-Known Member
    souLcaL
    '19 OR 4x4 SuperWhite DCSB
    Was out of town for a week during the holidays... had the biggest smile driving my taco back to my office this morning:bananadance:
    MooseTaco87 likes this.
  13. Jan 3, 2020 at 6:10 PM
    #1533
    Oopiehead
    Oopiehead New Member
    JD
    2017 TRD Sport
    I ended up using the sway bar relocation kit. As others eluded to I had the same clunking noise when hitting speed bumps. The sway bar was hitting the cross member on the driver side and the damage was evident to the sway bar once I removed the cross members. I didn't want to remove the sway bar completely, ditch the cross members/stock skid plate or fuss with the relocation brackets again so I just bought fender washers from Lowes. I took a guess and ended up using x6 of the 1/2 - 1 1/2" washers with each cross member bolt to drop them members a little lower. After driving around the neighborhood and hitting various speed bumps the clunking noise has gone away. I recall reading that the sport vs OR sway bar might be a different diameter so this is probably the reason why sport owners have voiced this complaint.
    siKjiTz and tn111 like this.
  14. Jan 3, 2020 at 6:27 PM
    #1534
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Looks like 2017 needs it and 2019 probably not.
  15. Jan 3, 2020 at 7:08 PM
    #1535
    Stigman
    Stigman Well-Known Member
    2020 Cement TRD OffRoad
    2020s shouldnt have to work about the sway bar relocation either?
  16. Jan 3, 2020 at 8:07 PM
    #1536
    OMGitsme
    Sold
    In my very small observation I've only seen 2017 or 18 need it. I witnessed no 2019's so I would be cautiously optimistic if I had a 19 or 20 that I did not need it. I don't plan on using it when I do mine.
  17. Jan 3, 2020 at 11:15 PM
    #1537
    siKjiTz
    siKjiTz Well-Known Member
    E
    Oahu, HI
    2017 DCSB TRD Sport Inferno
    TUNED 2.0 Beta 87 Eibach Pro Truck Lift Kit Stage 1 Wheelers 1.5” Progressive AAL Level 8 MK6 17x8 Falken Wildpeaks 265/70/17” Redline Tuning Hood struts Matt Gecko LED Bed lights OEM Roof racks GoRhino RB20 Running boards A/C drain Mod Kicker speaker upgrade w/kicker key amp. MESO Stage 1 Tail light upgrade OEM Bed Mat
    @Ryan at Eibach showin The HI some love! You da man Ryan!
  18. Jan 3, 2020 at 11:18 PM
    #1538
    siKjiTz
    E
    Oahu, HI
    I may have to do this. Thanks for the heads up and good thinking!
  19. Jan 4, 2020 at 6:13 PM
    #1539
    wsb
    VA Beach
    any company other than wheelers provide the option to ship assembled?
  20. Jan 4, 2020 at 7:24 PM
    #1540
    MooseTaco87
    Shea
    Mulberry, IN
    Yes. Toytec does. That's where I got mine.
    Inked Tacoma likes this.
