Eibach Pro-Truck 2.0 Adjustment
Discussion in 'Suspension' started by MR.WaynesWorld, Jan 3, 2022.
  1. Jan 3, 2022 at 1:01 PM
    MR.WaynesWorld
    MR.WaynesWorld [OP] Well-Known Member
    Wayne
    North East Pa
    2021 Black Tacoma Limited
    **** 2021 Mods **** Sokietech No Drill Hood Struts (Replaced) Color Matched Mirror Caps Color Match Door Handles SUPAREE LED Side Mirror Turn Signal Lights AVS Dark Smoked Hood Bugflector (Removed) Meso Black Interior Door Handles AVS Window Vents AUTOGINE Super Bright 6000K White LED Vanity Mirror Lights 3D Rear Tacoma Letters Matte Black OEM Blacked Out Emblems OEM Black Trim around Fog Lights Full BedRug AMP Research Bed Extender LoMax Tonneau Cover (Replaced) RBP 77-Spike Wheels 18X9 (Replaced) Nitto Terra Grappler G2 tires 285/60 (Replaced) Blacked out Toyota emblem on steering wheel Night Shade Front Grill (Replaced) Dark Tint Front TSS Emblem (Replaced MBRP Dual Exhaust KTJO Door Pod lighting Window Tint, 5% in the back 30% up front MESO Chrome Delete center console MESO Chrome Delete Vent Rings **** 2022 Mods **** Cali Raised Steel Front Skid Plate (Replaced) Ice Blue Map and Dome LED bulbs Rek-Gen XL Mud Flaps - Black on Black All interior trim painted Matte Black with Flat Clear Coat Aqua Blue Foot Lights - Front and Rear MESO Switch Panel Custom Layout MESO 3 Switch Overhead console panel MESO Chrome Delete Climate Control Rings UpTop Bravo Roof Rack Extreme LED 38 inch LED Light Bar in Roof Rack Diode Dynamics LED Strip Grill Lights Meso Ultimate Tail Lights (Replaced) Rock Lights - 8 Cyclone V2's (Replaced) UpTop Roof Rack Grab Handles UpTop Scene Pods with Baja Design Rock Lights Diode Dynamics Elite Series Fog Lights CaliRaised Stealth Bumper 30 inch Infinite Offroad LED Light Bar X2 Zeak 10,000 Winch KTJO Driver's Side Grab Handle LambTek Winch Switch Boomers "faux" TRD Pro Shift Knob Tacoma Lifestyle Smoke Third Brake Light Blacked out Instrument Panel Lens Diff Drop Dobinson's Suspension, Front Coil Overs, UCA's, Rear Shocks and Leaf Packs DB Customz Grill, Color Match with RGBW LED Letter Lighting **** 2023 Mods **** PowerTrays Tray with Busemann Fuse Relay Pioneer DMH-WC6600NEX Maestro RR2 SiriusXM SXV300 Tuner BoxWare Anti Glare HU Screen Protector Varity of cables and adapters Focal ACX 690 Front Speakers (Replaced) Focal ACX 165 Rear Speakers (Replaced) Diode Dynamics Stage Series Rock Lights - 3 in each wheel well Diode Dynamics Flush Mount Brackets Revolver X4s Tonneau Cover UpTop Roof Rack Grab Handles V2 Raceline Compass 17X9 wheels Toyo Tires Open Country A/T III 275/70R17 Tacoma Beast Infinity Tail Lights Taco Clout Wide Angle Convex Mirrors - Heated + Turn Signals + BSM KTJO Powered Folding Mirrors **** 2024 Mods **** Lighting Trendz Glow LED lights in Grill Lettering Cali Raised Cat Shields The Sub Box Shop Sub Amp box Rockford Fosgate 10 inch 4 ohm Dual VC Sub Kicker 3.5 inch speakers in dash (Replaced) Auto Harness House harness adapters for speaker wires Alpine PXE-C80-88 8 Channel Amp. Polk Audio DB 6502 Front Doors Polk Audio DB 6502 Tweeters in Dash Polk Audio DB 652 Rear Doors Hidden LED's in Bed Charvonia Design Bed Rail Tie Down Anchors Charvonia Design Bed Tie Down Anchors Charvonia Design Bed Floor Tie Down Anchors Charvonia Design Billet Battery Tie Down Redline Hood Struts TRD Pro Hood KITT Scanner LED in Hood Scoop Cali Raised Aluminum Skid Plate
    Maybe a stupid question but I have been known to ask some.
    I installed the Eibach Pro-Truck 2.0 Coilovers on my truck over the weekend.
    If I want to raise the front drivers side by 1/4 inch to remove the Taco Lean, do I turn the adjustment collar to the right to expose more threads?
    How many full, half or quarter turns would equal 1/4 inch?
    Also I take it jacking up the front end to release the weight off the coilovers would make the adjustment easier?
    boston23 likes this.
  2. Jan 6, 2022 at 7:02 AM
    Dean62
    Dean62 Well-Known Member
    Jacob
    Florida Panhandle
    2020 TRD Sport 4x4 BR Access Cab Manual
    These are the measurements i got when i was adjusting the Eibach 2.0 on my Access cab
    Jacking up the truck is a must otherwise you might mess the threads
    Before lift
    DF 21.5"
    PF 21.75"
    DR 22 5/8"
    PR 22.75
    After lift
    DF 22.75"
    Pf 23.25"
    Dr 24.75"
    Pr 25"
    After 1 full turn driver side front
    DF 23"
    Pf 23.25"
    Dr 24.75"
    Pr 25"
    After 3 turn driver front
    DF 23.25" 1.5 thread showing
    Pf 23.25"1.25 thread showing
    Dr 24.75"
    Pr 24 7/8"
    After 6 turns driver front
    DF 23.5" 1.75 threads
    Pf 23.5" 1.25 threads
    Dr 24.75"
    Pr 25"
    9 turns driver front
    DF 23.75" 2 threads
    Pf 23.75" 1.25 threads
    Dr 24.75"
    Pr 25"
    9 turns driver 6 turns pass
    DF 24"
    Pf 24.25"
    Dr 24.75"
    Pr 25"
    8 turns driver 7 turns pass
    DF 24"
    PF 24.125"
    DR 24.75"
    PR 25"
    MR.WaynesWorld[OP] likes this.
