EIBACH PRO-TRUCK LIFT KIT (STAGE 1) FOR 16+ TACOMA REVIEW
Discussion in '3rd Gen. Tacomas (2016-2023)' started by androofoo, Feb 21, 2019.
  1. Mar 1, 2019 at 7:35 AM
    androofoo
    androofoo [OP] Well-Known Member
    2018 Tacoma TRD Off-Road Cement
    So far I'm loving this setup. There's a member here that is selling his kit because it was "too stiff" but honestly, I'm not experiencing that. Maybe it's my OME Dakar HD leafs that make it a little better.
    I went wheeling over the weekend with the Firestone RideRite airbags and Daystar cradle set to 10psi and it worked very well.
    Roddy13 likes this.
  2. Mar 1, 2019 at 8:17 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Increasing caster from the UCA reduces your tire clearance though. You'll want to maximize caster at your LCAs and decide whether or not it's enough for you or if you want more from aftermarket adjustable UCAs.
    In fact, I'm considering reducing my caster at my UCAs to have more clearance for my tires.
    There's nothing wrong with stock specs on your caster either. Its the driver's preference if they want more or not.
    71tattooguy likes this.
  3. Mar 4, 2019 at 3:12 PM
    GasPowered
    GasPowered Well-Known Member
    OK
    2016 DCSB TRD OR 4x4 SSM
    So you have both the Dakar leaf pack and the Firestone airbags? What made you add the airbags?
    Your write up has almost convinced me to go with the Eibach lift, but I'd like more information on the airbags with the Dakar pack if you don't mind.
    Thanks
    Cheers
    Larry_O likes this.
  4. Apr 19, 2019 at 12:59 AM
    BankrupTaco
    BankrupTaco Well-Known Member
    2021 Tundra SR5 4x4
    Considering this set up with JBA UCAs. OP, Any updates?
  5. Apr 19, 2019 at 1:01 AM
    BankrupTaco
    2021 Tundra SR5 4x4
    So this is as clear as mud to me... I know nothing about max or min caster for tire clearance. Im going to be stuffing a 285/70/17 with the SCS SR8s... what should me specs be for best tire clearance and articulation?
  6. Apr 22, 2019 at 6:27 AM
    ptat
    ptat Well-Known Member
    2019 Tacoma SR5 4WD DCLB
    This might be a very dumb question, but I can't really find an answer anywhere so I'm gonna ask here because I'm considering this kit. It's a great value.
    If I get this kit and have the front on the lowest notch (stock height), can I add a strut spacer on top to get some lift? The reason is I want a lift with a plush ride possible because I have a 100 miles commute.
    I'll add the Icon 1.5 progressive AAL to lift the rear.
    Is this a good idea? I know this forum does not like spacers lift, but I'm on a tight budget and would like to get as much performance and comfort as I can.
  7. Apr 22, 2019 at 7:26 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    The lowest notch is still a 2" lift in the front. You'll only need a 1/4" spacer on the driver side for the taco lean.
    Ride is firmer than stock, but still comfortable.
  8. Apr 22, 2019 at 8:36 AM
    ptat
    So the 3rd (top notch) should give up to 3 inch lift? That's a lot.
  9. Apr 22, 2019 at 8:52 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    You only use the 2nd or 3rd notch if you have weight on the front from a bumper or winch (or both).
  10. Apr 22, 2019 at 9:14 AM
    Dampahee
    Dampahee Well-Known Member
    So Cal
    2019 TRD Off Road
    Fox Factory 2.5 extended travel w/DSC Eibach 650x14 springs Fox Factory 2.5 x 12 in smoothies with rr and DSC / Accutune Adventure tune Archive Garage shock relocation Archive Garage hammer hangers with 3.6" shackles Archive Garage high clearance cross bar Deaver Expedition u402 stage1leaf pack Camburg Racing Uniball UCA's Total Chaos Gusseted Spindles Marlin Crawler HD LCA/cam tabs Frame Brace gussets @weldstaco front diff reinforment kit Wheelers u-bolt flip kit with super-bumps Crown performance SS 24 in extended rear brake lines SS extended front break lines Exhaust re-route mod Dirt King Cab Mount Relocation OV Tune-91 Performance Nitro 5.29 Gears ARB Front Locking Differential ARB High output in board compressor Slee On-board compressor mount Blais Bros Taco differential breather mod Schmellfab 12.5° sliders with kick out RCI steel IFS skid RCI steel transmission skid RCI steel T-case skid RCI LCA skid BAMF Rear differential skid Relentless Fabrication hybrid front bumper Relentless Fab High Clearance rear bumper ATHF rear fender supports SOS performance rear disc brake conversion Trimmed Fenders 2.5" Softopper TRD Heritage grill RFT Raptor lights Morimoto XB headlights Baja Designs amber S2 flush mount chase lights Baja Designs S8 30 in lightbar Cali Raised Relay Mount Cali Raised cubby switch mount Smittybuilt X20 10 k winch Factor 55 Fairlead Factor 55 Flatlink E Factor 55 Flatlink Ropeguard Tandem Off Road Manor winch solenoid mount 1.25 inch Spidertrax wheel spacers 17x9 Ultra Wheel x103 beadlocks 35/11.5/17 Nitto Trail Grapplers Fend-X Wheel Liners Clazzio leather seat covers Taco Garage DMM Mount Taco Garage Anytime Front/Rear Camera MESO Customs Chrome Delete MESO Extended fuse cover AVS in channel low-profile wind visors Kicker CS tweeters, 6x9, 6.5's Kicker Key amp Kilmat sound deadening
  11. Apr 22, 2019 at 9:31 AM
    ptat
    Is there any advantage of this system vs. the Bilstein 5100 with factory coils? Which one has a softer ride on pavement?
  12. Apr 22, 2019 at 12:38 PM
    patdeezy
    patdeezy Well-Known Member
    souLcaL
    '19 OR 4x4 SuperWhite DCSB
    @androofoo love your site man :thumbsup: any updated pix with the Dakar leafs installed?
  13. May 15, 2019 at 7:13 AM
    zi0n
    zi0n Well-Known Member
    Leo
    Puerto Rico
    2018 Cement Tacoma DCSB
    Pictures are dead? I might be buying these.
  14. May 15, 2019 at 7:16 AM
    MedlinAround
    MedlinAround Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
    Hope you plan on leaving it on pavement or you'll be purchasing better coils in the near future.
  15. May 15, 2019 at 3:37 PM
    #35
    Racz.Rides
    Racz.Rides Member
    Daniel
    '18 TRD OR
    TRD PRO Grill TRS Headlights bulbs & Fogs
    Wish I knew about these before I did my Bilsteins almost a year ago. I did the UCAs and they clunk like there is no tomorrow :frusty:
  16. May 15, 2019 at 7:48 PM
    #36
    patdeezy
    souLcaL
    Can any of the TW fam recommend a good AAL/replacement pack w/ this coil setup? Currently no armor, no bed rails, no RTT. Looking max 2" lift all around, trying to mimic stock offroad on road mannerisms as my truck is my daily.
    Will hit some trails after suspension swap.
    Thanks guys :bananadance:
    71tattooguy and BankrupTaco like this.
  17. May 15, 2019 at 7:49 PM
    #37
    patdeezy
    souLcaL
    :confused::confused::confused:
    That rusted out shock/spring combo doesn't look like the Eibach kit tho?
  18. May 15, 2019 at 8:18 PM
    #38
    BankrupTaco
    2021 Tundra SR5 4x4
    I opted with the OME Heavy Duty for the rear. Came recommended by several ppl and even Eibach. I still have to put everything on lol
    patdeezy[QUOTED] likes this.
  19. May 15, 2019 at 8:26 PM
    #39
    MedlinAround
    Cody
    Kentucky
    Not a kit but it's thwir coils. Wouldn't have been rusted if it wouldn't have broke without me knowing it. That side was broke, the other was barely having on with a crack in it
  20. May 15, 2019 at 8:28 PM
    #40
    BankrupTaco
    2021 Tundra SR5 4x4
    OP, you went with the 2nd perf notch up front?
