EIBACH PRO-TRUCK LIFT KIT (STAGE 1) FOR 16+ TACOMA REVIEW
Discussion in '3rd Gen. Tacomas (2016-2023)' started by androofoo, Feb 21, 2019.
  1. Mar 30, 2021 at 5:27 AM
    #101
    TacoTuesday103
    TacoTuesday103 Member
    2017 Tacoma sport
    With no added weight, I have mine set to the bottom perch with eibach springs, and they are measured to about 22” from bottom bolt to the top plate. A stock TRD Sport strut measured out to 22” as well. I plan on taking it the top perch to see where it will measure at.
  2. Apr 16, 2021 at 6:41 PM
    #102
    G007
    G007 Well-Known Member
    Gary
    Vancouver, Canada
    2023 Tacoma Premium Lunar Rock
    275 70 17 KO2 on 17" Bronze TRD Wheels AFE Intake Magnaflow Exhaust OEM TRD Pro Grill
    Ordered my Eibach Stage 1 set up today from Lowriders in Surrey BC. They said they have never heard of of the Taco lean. If I go 2" and 1" rear block will I have the lean and how do I ask them to correct it?
    They said it should not have any lean and Eibach does not provide anything in the kit to correct... if the lean occurs what do you suggest?
  3. Jul 19, 2021 at 7:38 PM
    #103
    grantacoma123
    grantacoma123 Well-Known Member
    Grant
    2020 Tacoma Sport
    Ryan, so with the shocks set at 0, this will still lift the front of the truck around 1.5-2” and then each level will incrementally lift it about half an inch more?
    if that’s the case, would you recommend adjusting them to level 1 to achieve around 2.25”?
  4. Nov 21, 2021 at 1:48 PM
    #104
    Ryuguyu51890
    Ryuguyu51890 Member
    2014 spruce mica limited
    Does the kit come with a top mount also? Or did you use the stock one
  5. Mar 17, 2022 at 11:39 AM
    #105
    kbecerra
    kbecerra Well-Known Member
    2006 Red Tacoma Double Cab Long Bed PreRunner
    Eibach Pro-Truck Lift (Stage 1), Deaver AAL, JBA STD UCAs
    No sure If this question was asked previously but for the Eibach Rear Shocks rated to accommodate 0-1.5” lift, Are the OME Leaf Springs safe to use with Eibachs Rear Shocks?
    Thanks. Considering this kit
  6. Nov 2, 2022 at 6:58 PM
    #106
    disel_V1
    disel_V1 I eat cold pizza rolls
    3rd Gen
    few things here and there.
    Incredibly late to the party, but if you happen to see this.. mind sharing your center hub to fender measurement?
    I am at the bottom, and getting about 22” front. Curious if the middle would get me 23? Or above 23? Thanks!
    Same exact setup!
