Eibach pro truck sport
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wolfman00, Apr 26, 2018.
  1. Apr 26, 2018 at 4:30 AM
    wolfman00
    wolfman00 [OP] Well-Known Member
    matt
    Gambrills/Crofton MD
    '16 dclb
    sortof stock. 6112/5160, pro wheels and a tune.
    i was scanning here and the internet ingeneral on the new eibach shocks, and doesnt seem like many have them. not much out there.
    called toytec, and talked to them and they said they are progressive and not digressive like bilsteins, which is what i want.
    anyone have em? if so what are thr actual lift heights and how is the ride?
  2. Apr 26, 2018 at 5:38 AM
    awdvkd115
    awdvkd115 Well-Known Member
    Bud
    2017 Tacoma TRD OR
    Toytec lift, White Knuckle sliders, RCI Armour, ECGS (Nitro Gears), Victory 4x4 Striker Front bumper, Smittybilt X20 10K winch, Dobinson snorkel, Spidertrax 1.25 spacers and 255 R80 16 BF Goodrich KM2s.
    I have the Toytec performance lift with the upgraded 2.5 reservoir coilovers on the front and the upgraded 2.5 rear shocks. I also upgraded to the performance leaf packs and the Toytec spring bump stop kit. I did do the diff drop and carrier bearing drop, I personally think if you change the angle of the rear U joint you should do the other end at the carrier bearing to make both U joint the same. To achieve the factory caster I upgraded to the SPC UCA's to get 3 degrees. After all that I really like the ride, it is firmer than the factory suspension but I like the ride of a truck and I do a lot of towing, I figure I got about the 2.25 to 2.50 lift. The performance leaf pack did give a bit more than level but due to the towing I do it work out well.
  3. Apr 26, 2018 at 6:53 AM
    wolfman00
    matt
    '16 dclb
    ah well thats cool, but im not going that far with my suspension.
    im going up an inch at most front/rear. thats why im going this particular route.
  4. Apr 27, 2018 at 10:44 AM
    wolfman00
    matt
    '16 dclb
    Anyone??
  5. Apr 27, 2018 at 11:01 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
  6. Apr 27, 2018 at 11:10 AM
    wolfman00
    matt
    '16 dclb
  7. Oct 2, 2018 at 11:50 AM
    Taco Louie
    Taco Louie Member
    2017 Tacoma TRD Off Road 4x4
    I just had the eibach pro truck lift installed on my 2017 Tacoma TRD OR yesterday. My only comparison is with the stock suspension, which I put 20k miles on. So far I've only driven 70 miles with the new suspension, but it does feel better than the old suspension. It is very smooth and soaks up the bumps in the road. I hope to test it off roading soon. I had mine set to the second highest setting and lifted my truck about 2 inches. I also went up one tire size. I now have 265-75-R16 Falken Wildpeak AT3W tires on my stock wheels. So far I'm very happy with the results.
    taco kai and Carter'sTaco like this.
  8. Sep 30, 2020 at 7:09 AM
    taco kai
    taco kai Well-Known Member
    2016 inferno TRD off road
    I know this is an old thread. Taco Louie, how's your two year review of the eibach set up? Have you had it in the dirt much? Any issues?
