Eibach ProLift vs 5100/OME springs.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chechare, Sep 22, 2019.
  1. Sep 22, 2019 at 11:24 AM
    chechare
    chechare [OP] Active Member
    cesar
    After going thru various threads, i cant help but keep coming back to these two setups. they are basically the same price. same lift. i want a 1-1.5 inch lift all around, and hoping for a smooth ride, and some weekend offroading on desert dirt roads to go camping. no RTT or heavy loads.
  2. Sep 23, 2019 at 1:31 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Keep your OE coils, 5100s all corners, set on the 4th perch, one inch rear block, do ECGS clamshell bushing and a 1/4 shim on the drivers side for the lean. That's what I did on my 18 DCLB Sport 4wd. Rides awesome, no sagging since installed and got the lift I wanted. OME springs sag, don't listen to the bullshit that setting the Bilsteins on the higher clips make the truck ride harsh. Just do it!!!!! Enjoy.
  3. Sep 23, 2019 at 12:38 PM
    Ryan at Eibach
    Ryan at Eibach Well-Known Member Vendor
    You can run our setup on the second clip and get 1" of lift with the OE spring and it rides great. On the 3rd clip you'd get about 2".
    Or you can run our spring/shock and get 2" on the bottom clip. Again, rides great.
