Eibach Protruck 2 Science Experiment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sand_In_My_Taco, Mar 20, 2024.
  1. Mar 23, 2024 at 5:18 PM
    #61
    Sand_In_My_Taco
    Sand_In_My_Taco [OP] Well-Known Member
    NOR*CAL
    2025 1794 Tundra TRD-OR
    I can't get the coilovers to compress past 20 1/4.
    Going to try lowering the adjustment screw 6 turns (1/8 per turn) to match the block (3/8 block, ~6/8 lift) and see if it's easier to compress.
  2. Mar 23, 2024 at 6:23 PM
    #62
    Sand_In_My_Taco
    NOR*CAL
    Driver's side complete, drove around block to see how it settled
    On ground
    DF 22 1/2
    Tires off the ground
    DF 25 1/2
    I now essentially have "long travel" coilovers (I think?)
    Great news is that I now have ~3" of downtravel. I don't believe that I will bottom out the shocks at this height, you would probably need to drop it down 1 1/2 or more before you start running into the opposite issue, just a guess.
    Need to loosen and retorque the LCAs, then I'll check out the passenger side.
    Sidenote - suspension is still limited by the coilovers, albeit barely at this point. Also, and max droop, the UCA will nearly skim the coil.
    So far... Success????
    JSX likes this.
  3. Mar 23, 2024 at 7:08 PM
    #63
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    Lol at long travel reference
  4. Mar 23, 2024 at 7:18 PM
    #64
    Sand_In_My_Taco
    NOR*CAL
    Ghetto "long travel"
    I've got a long weekend to burn and don't mind testing some shit.
    Also.... Aren't long travel coilovers just.... 1/2" longer?
  5. Mar 23, 2024 at 7:34 PM
    #65
    Veet-88
    I think your mixing up mid or extended travel over a proper LT set up. Proper long travel kits are substantially more involved longer shocks different LCA and UCA.
    This experiment truly didn't change anything regarding travel it just added lift.
    JFriday1 likes this.
  6. Mar 23, 2024 at 7:56 PM
    #66
    Sand_In_My_Taco
    NOR*CAL
    More of a, "changed up/down travel center" since the coilovers are adjustable.
    Added 3/8 spacer, lowered coilovers adjustment by 3/8, thus shifting my "center" from "nearly fully extended" more towards "neutral + -"
    My terminology is off, my apologies.
    Driver and passenger side are complete, just loosen/retorque LCAS then I should be done.
    Mrcooperou812 likes this.
  7. Mar 23, 2024 at 9:42 PM
    #67
    Sand_In_My_Taco
    NOR*CAL
    Good news!
    I did some testing.... And the clunk is gone!
    It's getting late, but tomorrow I'll hit some terrain at a bit higher speed and see if I can get it to go, however so far, things that would normally clunk.... Do not!
    Great success
  8. Mar 23, 2024 at 9:46 PM
    #68
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    I wasn't gonna say anything :rofl:
    Veet-88[QUOTED] likes this.
  9. Mar 23, 2024 at 9:58 PM
    #69
    Sand_In_My_Taco
    NOR*CAL
    My mistake, amended first post.
    I'm happy it appears to have worked tho!
    Strictlytoyz[QUOTED] likes this.
  10. Mar 24, 2024 at 5:38 AM
    #70
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    Outstanding!
  11. Mar 24, 2024 at 11:34 AM
    #71
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    What was the lift before? Looks like you dropped below 2" territory.
  12. Mar 24, 2024 at 11:52 AM
    #72
    Sand_In_My_Taco
    NOR*CAL
    25.5-22.5=3 (am I missing something?)
    I'm right in the money for 3" at the moment. I might lower the front by a 1/4" tho.
    Still riding much better than before, when I had sub 3" of downtravel.
  13. Mar 24, 2024 at 12:04 PM
    #73
    Vlady
    Issy, WA
    Lift, not the articulation
  14. Mar 24, 2024 at 12:11 PM
    #74
    Sand_In_My_Taco
    NOR*CAL
    I went from 22 3/4 to 22 1/2.
    Roughly 1/4 lower up front then I was, however I could just add 2 turns to each coilover for the extra 1/4 lift.
  15. Mar 24, 2024 at 12:21 PM
    #75
    Vlady
    Issy, WA
    I guess you proved Tinker's point -more lift does not equal better suspension
    Daulll and sbl23 like this.
  16. Mar 24, 2024 at 12:26 PM
    #76
    Sand_In_My_Taco
    NOR*CAL
    That's a known fact I feel.
    What I really did was get 22" ride quality with a 22 1/2" lift.
    Daulll likes this.
  17. Mar 24, 2024 at 12:30 PM
    #77
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    All really depends on stroke length and aplication.
  18. Mar 25, 2024 at 7:21 PM
    #78
    Mrcooperou812
    Las Vegas NV
    2016 DCSB OR 4WD
    I am glad I got to be a follower of this experiment as it unfolded.. Apparently many others haven't taken to their garage to try any self help. Good work!
    Sand_In_My_Taco[OP] likes this.
  19. Mar 25, 2024 at 8:01 PM
    #79
    Sand_In_My_Taco
    NOR*CAL
    Thanks!
    I edited the title of the thread to more accurately represent the content.
    I really wanted to see if how they are setup from Eibach was the problem, and if this experiment would be a solution for others, albeit one that costs a bit more money ($30 isn't bad).
    These are the blocks I used if anyone else wants to do the same. https://www.amazon.com/gp/aw/d/B08V4H5Y8X?ref=ppx_pop_mob_b_asin_title
    With everything all said and done, I'm still likely going to order a tuned set of coilovers form @AccuTune Offroad.
  20. Mar 26, 2024 at 7:22 AM
    #80
    K9tacoma
    K9tacoma Well-Known Member
    Austin
    Central Ohio
    2023 Tacoma TRD Off Road - Lunar Rock
    I knew I wasn't crazy when I first put on these Eibach Stage 2s. We have a speed bump in my neighborhood and as soon as I put these on, I knew they were topping out and causing the clunk. Your video confirmed exactly what I feel in the front end on the same type of bumps. I'll likely throw on these spacers to correct in the meantime, but like you I'll be upgrading suspension again here soon. Thanks for the testing and write up on here, doing the gods work to fix what Eibach couldn't develop right from the get-go.
