Eibach Sport Shocks
Discussion in '4th Gen. Tacomas (2024+)' started by TexasTacoma713, Jan 2, 2025.
  1. Jan 2, 2025 at 1:01 PM
    TexasTacoma713
    TexasTacoma713 [OP] Well-Known Member
    PNW
    2024 OR
  2. Jan 4, 2025 at 5:40 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    Nice, somewhat affordable…
  3. Jan 4, 2025 at 7:19 AM
    DaveEEE
    DaveEEE Well-Known Member
    2024 Tacoma Off Road
    I am looking at the same leveling option, I will be interested to see how the new set up impacts your ride and handling.
    fitsofrage88 likes this.
  4. Jan 4, 2025 at 8:07 AM
    slater
    San Diego
    No real reason to lift the back on these trucks unless you want to keep the extreme rake…
    Unless you plan on overloading the back full-time with over landing crap…
    Malore likes this.
  5. Jan 4, 2025 at 6:39 PM
    PDKTaco
    PDKTaco Well-Known Member
    Montana
    2024 TRD Off-road
    Had Eibachs on my G2 Tundra, g4 taco obviously is a different animal but they were fantastic on my Tundra.
    Superdave1.0 likes this.
  6. Jan 4, 2025 at 6:42 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I have eibach front shocks on my Land Cruiser. They have been awesome. I bought them as a temporary shock to run, but have kept them in there. They do great on and off road.
    PDKTaco likes this.
  7. Jan 4, 2025 at 6:47 PM
    PDKTaco
    Montana
    2024 TRD Off-road
    I think they are probably the best bang for the buck?
    Superdave1.0[QUOTED] likes this.
  8. Jan 4, 2025 at 7:26 PM
    Superdave1.0
    SoCal
    I would say so. Along with bilstein 5100. Eibach makes springs for tons of companies. If I'm not mistaken they are the oem supplier for Lamborghini and others. I read formula 1 as well. They are legitimate!
    PDKTaco[QUOTED] likes this.
  9. Jan 5, 2025 at 8:34 AM
    TexasTacoma713
    PNW
    2024 OR
    I’m got a decked drawer system with a ton of tools, so prob 250lbs constant. I’m not too concerned about the rear. Just trying to level up the front a bit without a spacer.. I did buy a Peak suspensions leveling spacer but saw these shocks.
  10. Jan 5, 2025 at 8:39 AM
    slater
    San Diego
    I did the wescott 2.5" in front only on my sport....
    left the rear 3/4" out....
    I was hoping for front slightly higher than the rear, didnt happen....
    I may add the peak top spacer on top of the strut later if it doesnt screw up the geometry..
    reached out to a guy that does alot of custom lifts on these trucks & he seems to think adding the spacer won't effect anything & should be fine...
  11. Jan 5, 2025 at 8:41 AM
    TexasTacoma713
    PNW
    2024 OR
    I just posted it in 4gen FS thread
  12. Jan 5, 2025 at 8:41 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Close.
    A larger manufacturer makes springs for Eibach, while also supplying to many large companies like King and more.
  13. Jan 5, 2025 at 11:48 AM
    TexasTacoma713
    PNW
    2024 OR
    They’re made in America.
    It’s not a puck lift.
    It was $460 for all 4 shocks.
    I think I’ll have to use my factory springs.. I’m gonna try it out at the 3rd clip setting.
    I was looking at Dobinsons IMS front but not looking to spend that much right now. I just want more cushion flying over speed bumps for the most part…
    I may have to buy JBA uca if the height is too much. I’m not paying a thousand dollars for ucas
  14. Jan 5, 2025 at 12:52 PM
    PDKTaco
    Montana
    2024 TRD Off-road
  15. Jan 5, 2025 at 5:05 PM
    Superdave1.0
    SoCal
    No sir. Please don't spread false info if you aren't informed. Eibach makes their own springs, in house, right there in Corona.
    https://youtu.be/dPG0eBbp-H4?si=xxIA8PtcnqEI7dRy
    PEAKIT and PDKTaco like this.
  16. Jan 5, 2025 at 5:12 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Not trying to spread misinformation.
    A more accurate statement could be that they make many of their springs in-house? That or maybe they stopped outsourcing their springs?
    I don't normally touch on these sorts of subjects unless I knew something for sure. The shop where I was a fabricator at, had a huge production line for powdercoat and powdercoat only.
    The assembly would easily do over 2,000 springs a day and they came from one manufacturer, only to head out to their final destination - Eibach was one of those recipients. King and many other well-known companies were also purchasing coils from this manufacturer as we would get all the purchase order details, number of coils, sizing, and surplus list (in the event of powdercoat defect), and means for sorting each set of orders out. Then they would ship out from our shop.
    Again, I wouldn't spread misinformation if I wasn't sure of something.
    PDKTaco likes this.
  17. Jan 5, 2025 at 5:30 PM
    dneal
    dneal Well-Known Member
    MidMO
    24 TRD OR 6M
    I'm a little confused.
    Your profile says you have an Off Road? If so, you already have Bilsteins with attached remote reservoir. The shock body should be red and the dust boot blue.
    The Eibachs are a great upgrade over the factory (Hitachi?) shocks - especially since Bilstein doesn't have a 4600 or 5100 for the '24 yet. That's a chocolate or vanilla debate, but I like Bilstein.
    Are you just doing the swap for the clip positions/front end raise?
  18. Jan 5, 2025 at 5:38 PM
    PDKTaco
    Montana
    2024 TRD Off-road
    The factory Bilsteins were a disappointment in my opinion.
    PEAKIT, fitsofrage88 and Jacob06 like this.
  19. Jan 5, 2025 at 6:35 PM
    dneal
    MidMO
    24 TRD OR 6M
    Maybe your expectations were higher than they should have been.
  20. Jan 5, 2025 at 7:23 PM
    PDKTaco
    Montana
    2024 TRD Off-road
    Yeah they are. Once you have a set of premium shocks it kinda does that!
    Malore and Kwikvette like this.
