Eibach Spring Lift Height vs. OME ??
Discussion in 'Suspension' started by ACE_Taco, Mar 21, 2010.
  1. Mar 21, 2010 at 6:32 PM
    ACE_Taco
    ACE_Taco [OP] Long Range Practical Marksman
    NC
    08 DBLCab TRD 4x4
    OME 885x Coils, Dakar Leafs, OME Shocks, TC UCAs, BHLM, Tailgate MOD, WeatherTec Window Deflectors, WeatherTec Floor Mats, Blacked Out chrome bumber, Satoshi Grille, Wet Okole Seat Covers
    OK, I know there are too many Eibach Threads, but I have a question about spring rate and lift. I did a search and could not find the answer.
    If the OME 885 is 590# / 16" in length and gives 2.5-3.0" of lift, how does the Eibach that is 620# / 16" in length only give 1.6"????
    Thanks
  2. Mar 21, 2010 at 6:40 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    If the measurements are accurate, that's a good question. However, the OME 885 coils do not give 2.5-3" of lift. One site advertises 1.75" of lift another site claims 2" of lift from the same coils. They claim you need the top plate spacers to the full 3" which also doesn't make sense because the 1/2" plate only gives about 3/4" of lift. That only adds up to 2.5". Either way, people love them.
    I have the Eibachs, 5100's at 0.85", a 1/2" plate on the driver's side, and a 1/4" plate on the passenger's side. Mathematically, this adds up to over 3" of lift. I actually only got 2.75" of lift with no lean.
  3. Mar 21, 2010 at 8:00 PM
    spiceman
    spiceman Well-Known Member
    Hawaii
    '07 4x4 DC OR, Desert Sand Mica
    Window Tint, Sockmonkey bed decals, Eibach 1.6" coils, 5100s front (set @ .85) / rear
    Not for sure, but I can tell you this. I only got about 1" of lift or a little less with Eibach coils on a DC 4x4.
  4. Mar 22, 2010 at 5:43 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    Same here I also got about 1" of lift out the the Eibach's, but I am very happy with the ride!
  5. Mar 22, 2010 at 9:56 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    The 885's are not 16" should be somewhere between 15.25-15.5"
  6. Mar 22, 2010 at 10:00 AM
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    OK, with that said, why do they render more lift than the Eibach?
  7. Mar 22, 2010 at 10:02 AM
    TacoSupreem
    Hayden
    Kentucky
    The eibach isn't 16" either?
  8. Mar 22, 2010 at 1:16 PM
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    Well, what is it? 16" for the 885 & Eibach is what I read I read in an older post that Chris replied to. Regardless, is the Eibach Spring as long as the OME 885??? If so, how does it only render 1.6" of lift when it is rated 30# heavier than the 885??
  9. Mar 22, 2010 at 2:46 PM
    TacoSupreem
    Hayden
    Kentucky
    A 16" spring would give 4"'s of lift. My 884's are 15.25" 855's are 1/8th" taller I believe?
    Not sure about the eibach's but I would guess around 15"?
  10. Mar 22, 2010 at 2:59 PM
    09silvertaco
    09silvertaco Well-Known Member
    Massachusetts
    2010 AC TRD Sport V6 6SPD
    i believe the eibachs are 15", 884's are 15 1/4" and the 885's are roughly 15.65" tall. eibach is higher spring rate, right around 620. 884 and 885's come in at 590.
  11. Mar 22, 2010 at 3:07 PM
    60guy
    60guy BADASS
    Dustin
    Maryland
    2017 Limited Double Cab
    With the eibachs being 620# does the make it a rougher ride?
  12. Mar 22, 2010 at 3:21 PM
    09silvertaco
    Massachusetts
    pair them with the right shock, 5100's or something very similar, and it will be negligible when compared to the OME's.
  13. Mar 22, 2010 at 3:23 PM
    09silvertaco
    Massachusetts
    stock SR5 springs are roughly 540 lb spring rate, trd springs...not so sure, probably slightly higher. the ride will definitely be a bit more firm than stock, but most people appreciate that as its a truck and expect a more firm ride from the factory.
  14. Mar 22, 2010 at 3:36 PM
    09silvertaco
    Massachusetts
    wow good info. i'd of figured higher spring rate even paired w/the better 5100's would've yielded a firmer ride.
  15. Mar 22, 2010 at 4:12 PM
    60guy
    60guy BADASS
    Dustin
    Maryland
    Thanks for the info. That is the exact set up I and going with, but I'm going to step up to some 17" Moto Metal 957s and 265/70R17 Toyo Open Country MTs.
    Did you have to do any additional work on the fron like move the sway bar or any drive shaft issues with the Eibachs and 5100s @ 0.0?
  16. Mar 22, 2010 at 8:19 PM
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    Thanks for the replies fellas... Very Helpful...
