eibach spring question
Discussion in 'Suspension' started by 08pretaco, Oct 13, 2009.
  1. Oct 13, 2009 at 9:14 PM
    08pretaco
    08pretaco [OP] Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    toytec used to sell a coilover kit with the silver eibach springs, look like the ones on their website that give the 1.6" lift.
    i was curious if both those springs are the same or if the springs that were included in the coilovers had a lower spring rate and dont give the initial 1.6" lift?
    thanks
  2. Oct 13, 2009 at 11:48 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    It has been discussed before and I think it was determined they are different, but not by very much.
  3. Oct 14, 2009 at 12:14 AM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    they're different springs. I dont know about the spring rates, but one difference is the bottom of the spring- on the CO kit its flattened for the seat on the spring collar, but the factory replacement 1.6" lift ones arent; the spring loops around and comes to an end randomly and unevenly.
  4. Oct 14, 2009 at 8:05 AM
    08pretaco
    Oliver
    az
    ya i searched through the number of threads and wasnt able to find it unfortunately so i was just curious if anyone happened to know the rates of the different springs. thanks guys
  5. Oct 14, 2009 at 4:43 PM
    aww1970
    aww1970 Well-Known Member
    2009 Tacoma TRD Long Box
    Not so. The bottom of the Eibach is flat and the ends on the top and bottom stop in the same spot when looking at a set.
    The eibach spring rate is 620#.
  6. Oct 14, 2009 at 10:11 PM
    08pretaco
    Oliver
    az
    regardless of the coilover or the ones they sell separate? and they stock spring rates what 520 540 for an sr5 suspension?
  7. Oct 14, 2009 at 11:04 PM
    08pretaco
    Oliver
    az
    do you know the spring rate of 884's or the stock springs which i think are 540 or something
  8. Oct 16, 2009 at 11:05 AM
    Tacoluver
    Tacoluver Well-Known Member
    Norcal
    TRD Off Road shortbed
    Volant cold air intake, RevTek 3" Lift, Snug Top Toneau cover, Kenwood Navi, Jamoshi grill
    Sorry not trying to jack but the description on toyyecs' site says that the Eibachs' can be used with Bilstein height adjustable shocks for more lift. Is this to say I could crank the Bilies up to 1.75 install these and have just over 3" of lift? If so these sound like adjustable coilover springs to me.
  9. Oct 16, 2009 at 11:09 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    No. They recommend the 0 setting for use with the coilovers.
