Eibach Springs?????
Discussion in 'Suspension' started by moledigger, Apr 20, 2010.
  1. Apr 20, 2010 at 2:19 PM
    moledigger
    moledigger [OP] Member
    Rick
    New Jersey
    5100's,Eibach Springs, 2"aal, DDM HID's
    I have a set of the eibach springs on a set of 5100's at .85 is this to much preload for the springs?????
  2. Apr 20, 2010 at 2:22 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    From what I've read, "0" or ".85" on the 5100's works fine with the Eibachs. I've got mine set at 0 with no issues.
  3. Apr 20, 2010 at 3:58 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    should be fine at .85 from what i've heard.
  4. May 25, 2010 at 7:24 AM
    Hipster
    Hipster Nothing beats a Butter Shave..
    Tom
    Tucson
    '10 DC trd 4x4
    Billy's @ .85 w/ Eibachs front, TSB w/ 5100's rear + 1.5" AAL & shims, Debadged, Avid Bolt On Sliders, NFab Light Bar w/ (2) Lightforce 170's. Weathertechs, ATO bed bars.
    I'd love to see pics as well since I'm either going to do 0 or .85 with my eibachs. Billy's arrive tomorrow:)
  5. May 25, 2010 at 7:59 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Had that set up on my 09 prerunner 4 door 2wd and a 2" AAL.
    Little darty on the hiway due to the caster with the stock UCAs.
  6. May 25, 2010 at 8:24 AM
    Kernel
    Kernel Well-Known Member
    Ohio
    09 TRD Off Road 6sp Manual
    5100's all 4 corners, front at .85 with Eibach Coils, Rear TSB w/AAL, TRD Catback Exhaust, AFE Pro Dry S, Duratracs, redline hood struts, maglight mod, weathertechs
    Those of you running at .85, any issues with alignment/vibrations? What was your total lift after they settled?
  7. May 25, 2010 at 8:34 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    how about 1.75, have some courage
  8. May 25, 2010 at 10:23 AM
    OH-MAN
    Sunny Az.
    10 4X4 O.R. White
    My little home made spring compressor would not like squeezing them that much!!:D
    That would be a bunch of preload.
  9. Nov 4, 2013 at 8:01 AM
    Blackhawk131
    Blackhawk131 Well-Known Member
    Any information with the .85 settings on the bilstein and eibach's installed?
  10. Nov 4, 2013 at 8:04 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    What type of information are you looking for? There is a lot of info about 5100's set at .85 and Eibach coils on this site. They'll provide about 2.5" of lift on a double cab 4wd but will also give a relatively stiff ride.
  11. Nov 4, 2013 at 8:32 AM
    Blackhawk131
    I have a 4 door 4x4 and would like to know the normal ride height would with the 5100's at .85 and the eibach springs. Would this work good with 33's? Should I move to 1.75 with the eibach springs? Are there any issues I should be aware of?
