Eibach Stage 2 | Should I also do leaf springs
Discussion in 'Suspension' started by Bird.Dog.Dad, Nov 29, 2024.
  1. Nov 29, 2024 at 10:44 AM
    Bird.Dog.Dad
    Bird.Dog.Dad [OP] Member
    Mitch
    2023 Taco SR5 4x4
    Hey all,
    Putting a Eibach Stage 2 on '23 Tacoma SR5 4x4. Should I do a add a leaf or even a Icon Multi Rate RXT Leaf Spring Pack w/ Add in leaf?
    I use my truck for daily driving, pulling my 19ft Vexus aluminum bass boat, and driving around the hunting lease.
    Thank you for your insight.
    -M
  2. Nov 29, 2024 at 5:09 PM
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    Personally, I think a truck should maintain some rake AFTER other mod weight/constant load, for better driving with additional bed load and/or trailer tongue weight. Also, rear sag looks broken. I like an inch rake. In fact, I started with my rear leaf pack install and then set my front lift to be one inch shorter.
    Everyone is different.
  3. Nov 30, 2024 at 5:02 AM
    BPKlein
    BPKlein Active Member
    2023 TRD OR Lunar Rock
    I installed the Eibach Pro Truck 2 along with an Icon AAL on a 2023 OR.
    The truck is a daily driver and regularly pulls a 19’ bay boat. Plus it is used on unimproved state park roads.
    The AAL gave me 1.25” of rear lift, so I set the front at 1.5” of lift. This still leaves a slight rake so that it is level when the boat is hooked up.
    The ride on the road is much improved over the factory setup. I’m pretty happy with the setup.
    PandaPandaPanda likes this.
