Eibach stage 2
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2017 tacoma sport, Sep 23, 2023.
  1. Sep 23, 2023 at 3:40 PM
    2017 tacoma sport
    2017 tacoma sport [OP] Well-Known Member
    Webster ny
    2017 tacoma trd sport
    Installed a stage 2 kit with 1.5 blocks in the rear. New 265/70/17 wild peaks. Alignment. Seems like it’s loose in the front end. When I go over bumps I feel like to sways side to side. Is it possible that the sway bar is loose. Didn’t seem to install well when it was moved when I installed the kit..
  2. Sep 23, 2023 at 6:20 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    Did you torque everything back down properly and mark it so you could tell if anything moved?
  3. Sep 24, 2023 at 4:14 AM
    2017 tacoma sport
    Webster ny
    Yes. And nothing in the bed.
  4. Sep 25, 2023 at 9:31 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Shoot a bunch of pics of your front suspension and post them up. See if we can spot something. Also, did you get a printout of your alignment?
    Chew likes this.
  5. Sep 25, 2023 at 9:38 AM
    2017 tacoma sport
    Webster ny
    I did not get a print out but the tech left it on the rack for me to see that is was good. Had a problem with the shop. I won’t be going back. I’ll post some pics later. I was also planning on checking the torque specks too.
