Eibach suspension..
Discussion in 'Suspension' started by toyotahenry, Nov 21, 2023.
  1. Nov 21, 2023 at 4:47 PM
    toyotahenry
    toyotahenry [OP] N/A
    Houston, Texas
    2021 TRD OFF ROAD 4X4 ARMY GREEN
    So based on all my research and knowledge, EIBACH is the only brand that’ll make your truck have an annoying “clunk” after install correct? Yes i understand not ALL are having this issue but handful amount of people are. If EIBACH is the ONLY one known to do this, then i’ll send my monies to FOX.
  2. Nov 21, 2023 at 4:48 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  3. Nov 21, 2023 at 5:05 PM
    toyotahenry
    Houston, Texas
  4. Nov 21, 2023 at 5:17 PM
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
    Not correct. While I believe eibach strut bodies are compromised compared to other s due to diameter and/or material quality, clunking can occur with any suspension upgrade. Improper install, torque, alignment, is usually the culprit. Comparing Eibach to Fox is apples to oranges really
  5. Nov 21, 2023 at 5:20 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I can't speak for the shocks themselves, but most clunking occurs due to the above mentioned response.
    In fact, if you 'search' for clunking...most times it's after 'just lifted my truck...' and nothing specific to Eibach.
    908tacoma likes this.
  6. Nov 21, 2023 at 5:21 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Have Bilstein 6112, and I have a clunk. I believe it’s my lower bushing that connects to the lca is ripped…..and I’m too lazy to change it.
  7. Nov 21, 2023 at 5:21 PM
    EL DUDE
    EL DUDE Well-Known Member
    I had eibach lowering everything in the past without issue. May be installer or user error.
  8. Nov 21, 2023 at 5:37 PM
    toyotahenry
    Houston, Texas
    interesting.. interesting..
    my conclusion is only based on the common pattens i have seen. a lot of Eibach users experience the "clunk" to my understanding, compared to FOX, BILSTEIN and etc...
    908tacoma[QUOTED] likes this.
  9. Nov 21, 2023 at 5:43 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Several people have experienced clunk after lifting their vehicle, and many have experienced clunk without ever lifting their vehicle; it happens for many different reasons.
    Not everyone posts about it as they just figure it out themselves (especially if they installed the suspension on their own). This is especially true as I experienced it myself and know of a few others that have as well (and never felt the need to post about it).
    I ran Fox 2.5 on my Tacoma, and figured out I needed to replace my LCA bushings.
    I ran King 2.5 on my 4Runner, and well..I forget what caused it. Think it was my driveshaft so I lubed that fucker up.
    Again, I never posted about it as I saw no need for it. Others will chime in with their own experience.
  10. Nov 21, 2023 at 7:18 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I’ve not heard of the eibach clunk. I suspect you might be over reacting to anecdotal information.
    Kwikvette likes this.
  11. Nov 21, 2023 at 7:27 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    "I read somewhere..."
  12. Nov 22, 2023 at 9:12 AM
    toyotahenry
    Houston, Texas
    It can be found all over this forum lol. I’m not hating against any manufacturer just FYI.
  13. Nov 22, 2023 at 9:13 AM
    toyotahenry
    Houston, Texas
    I can copy & paste some posts if you think i’m lying lol?
  14. Nov 22, 2023 at 9:17 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Not saying you're lying.
    Think you're just overthinking it and assuming that a Fox or other popular brand won't give you the same results.
    What I'm saying is, the clunk could be the result of having lifted your vehicle meaning something else was up or wrong that you haven't noticed before.
  15. Nov 22, 2023 at 9:20 AM
    toyotahenry
    Houston, Texas
    noted
