Eibachs on TRD shocks
Discussion in 'Suspension' started by flyingface, Oct 1, 2012.
  1. Oct 1, 2012 at 6:14 AM
    flyingface
    flyingface [OP] Well-Known Member
    Zach
    Auburn, AL
    2013 MGM DCLB TRD Sport 4x4
    Soon....
    Has anyone done this or know if it's acceptable? Would it be better to go ahead and get Bilsteins and set at 0?
  2. Oct 1, 2012 at 6:16 AM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    You have to get the bilsteins because the stock shocks aren't long enough for the eibachs
  3. Oct 1, 2012 at 6:17 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    It's possible but not ideal. Eibach coils are quite a bit stiffer than stock coils so the ride might not be great and you'll wear out the shocks pretty quickly. The TRD shocks won't do a great job dampening the stiffer coil so you could end up feeling bouncy or have a rough ride.
  4. Oct 1, 2012 at 6:17 AM
    Pugga
    Massachusetts
    OP has a 2nd Gen, stock shocks are long enough...
  5. Oct 1, 2012 at 6:18 AM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    Oops. Sorry!
  6. Oct 1, 2012 at 6:22 AM
    flyingface
    Zach
    Auburn, AL
    Soon....
    Just what I needed to know. Also, am I correct in thinking that the alignment can be brought back to ideal settings with stock UCA's when the Bilsteins are at 0?
  7. Oct 1, 2012 at 6:28 AM
    Pugga
    Massachusetts
    No worries, I unintentionally give 1st Genners advice at times also. The suspension sub-forum needs to get split up.
    Yes, you can. I've got that same setup (Billy's at 0 and Eibach coils) and was able to get good alignment numbers with the stock UCAs.
  8. Oct 1, 2012 at 6:31 AM
    flyingface
    Zach
    Auburn, AL
    Soon....
    Awesome, thanks!
    :thumbsup:
  9. Oct 1, 2012 at 6:42 AM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    Haha yeah that's for sure. It would made make things a lot easier
