eibachs sagging
Discussion in 'Suspension' started by Greensystemsgo, Jan 10, 2013.
  1. Jan 10, 2013 at 7:53 PM
    Greensystemsgo
    Greensystemsgo [OP] 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    whatre my options? no winch, just a elite front, see sig.
    eibachs are sagging, bottom out on the fender just taking speedbumps with 32" all terrains, the stockers 31" which i put back on for that issue have no rub on speedbumps.
    883s?
    882s?
    btw the rear is allpro expos.
    i see so much debate over what coil to get, and on top of that what shocks.
    this is more of a temp thing. im wanting sas but am still so much in the planning stages. but in the mean time it looks goofy, and the front sag is doing nothing but picking up the ass end making trailer towing even more difficult. i think i have a 8" drop hitch now and its still not enough. i used to tow on a bumper ball before i had an elite rear bumper, and front and had no sag with eibachs.
    maybe just adjust the eibachs? how long are the "warranty?" is there one?
  2. Jan 10, 2013 at 8:15 PM
    tacosunday
    tacosunday GoldMember
    Josh
    San Tan Valley, AZ
    4x4 OR DCSB
    What spring rate are you running? I have a pair of eibachs 650lb 14in length that I swapped with some 700lbs 16in.
  3. Jan 10, 2013 at 8:17 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
  4. Jan 11, 2013 at 5:11 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    now, ive seen that the 883's provide no lift, or 2" of lift, or 3" of lift. which is it?
    my goal is around 2, or 2.5", not a huge fan of spacers, and am tired of replacing cv's.
    what shocks?
  5. Jan 11, 2013 at 5:16 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    hrm, so hopefully might equal out to about an inch. i was thinking about maybe the 10mm spacer, even about disassembling the rear expos and removing one.
  6. Jan 11, 2013 at 5:41 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    is it a preloader or a top spacer?
    thanks for all the help!
  7. Jan 14, 2013 at 11:37 AM
    Techy
    Techy Well-Known Member
    Montrose, CO
    06 trd off road dbl cab
    What is it that tears up the cv's? And how much do they cost to replace?
    Sorry kind of a noob question, but I am kind of a noob.
  8. Jan 14, 2013 at 11:40 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    thats going to be from too much lift and that causes the fins on the CVs to rub against eachother, which will eventually make them rip, and need new CVs.
  9. Jan 15, 2013 at 8:10 AM
    Techy
    Montrose, CO
    How much is to much? At what point do they start rubbing? 2" 3"?
  10. Jan 15, 2013 at 8:13 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    No one has suggested that your shocks are toast?
    How many miles on them?
  11. Jan 18, 2013 at 7:08 AM
    ckblum
    ckblum Well-Known Member
    Cam
    Chilliwack, BC
    Tacoma
    Bilsteins, Light Racing UCA's, Alcan's, Kragen HID's
    Because shocks don't dictate ride height.
  12. Jan 18, 2013 at 7:11 AM
    GP3
    California
    4X4 TRD Off Road
    Where did he talk about his current ride height? He talks about future springs, but not the current ride height.
    All I see is that he is bottoming out easily: "eibachs are sagging, bottom out on the fender just taking speedbumps with 32" all terrains, the stockers 31" which i put back on for that issue have no rub on speedbumps."
  13. Jan 18, 2013 at 6:04 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    shocks control the bound, and rebound bounce. sure they effect the bound, but at what speed, as the actual weight is left to the springs. im looking at ome, but also at a rock assault from trail gear.
    just frustrating, hope others can take notice of what im seeing.
  14. Feb 8, 2013 at 2:22 PM
    ckblum
    Cam
    Chilliwack, BC
    Tacoma
    I just figured sagging meant a loss of ride height. My stock rears were sagging and I couldn't hold my dirt bike with out riding the bumps, I also lost an inch of ride height empty.
    I just figured you were blaming his "sagginess" on worn shocks. Brand new springs and worn out shocks will have the same ride height as both spring with new shocks.
