eibachs strong enough for plate bumper?
Discussion in 'Suspension' started by GA_TACO4x4, Jul 6, 2011.
  1. Jul 6, 2011 at 10:09 AM
    GA_TACO4x4
    GA_TACO4x4 [OP] Well-Known Member
    here 'n there
    07 DCSB 4x4
    marathon superhide max-4 seat covers, weathertechs, maglite mod, 20% tint, 2" leveling kit, leaf spring tsb.
    i'm gonna order a winch bumper in the coming weeks (most likely arb) and plan on upgrading my suspension at the same time. i have 5100s sitting in my room now but i need to get some coils. dont want 886s b/c i plan on staying under 3 inches...closer to 2" preferably. toytec says the eibachs are 620 lb rated. will these support the bumper and maybe a winch later down the road? anyone know what the 886 or 885 coils are rated?
    TIA
  2. Jul 6, 2011 at 10:17 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    886's are rated at 650 lbs and I believe the 885's are rated at 590 lbs.
  3. Jul 6, 2011 at 10:22 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    That rating is the spring rate. Stock I believe is 540#/in, Eibach's are 620#/in, 886's are 656#/in 885's and I believe 884's are 588#/in. The difference between the 885's and 884's are the length.
    If you're planning on an ARB and a winch, I wouldn't go with the Eibachs... I would imagine they'd be rougher than hell with that kind of weight on them. Maybe the newer 885x coils?
  4. Jul 6, 2011 at 10:37 AM
    GA_TACO4x4
    here 'n there
    07 DCSB 4x4
    Eibach's have a higher #/in rating than the 885x's. so im kinda confused why you'd say that. cause they're not as tall as the 885s? :confused:
  5. Jul 6, 2011 at 10:43 AM
    Pugga
    Massachusetts
    Yes, that is correct, sorry, should have been more clear in my response. If you want to stay around 2" of lift, I'd go with the taller coil (885x). The Eibach coil provides just under 2" of lift before you add 200# to the front end. You could set the 5100's at .85 to compensate I suppose or just get a taller coil to begin with.
  6. Jul 6, 2011 at 10:50 AM
    GA_TACO4x4
    here 'n there
    07 DCSB 4x4
    no worries dude. im just trying to get all this info correct. my plan was to get the eibachs installed at .85 like you said, and possibly adding the .25" top plate spacer netting 2.6" and i figured everything would sag .25-.5" from the additional weight. but after i do all that the 885x seems like a simpler route. just worried about them holding up to the weight
  7. Jul 6, 2011 at 10:55 AM
    Pugga
    Massachusetts
    Maybe hold off until you know what kind of weight you're going to be supporting. You sounded indefinite about which plate bumper and also about the winch. ARB is definitely on the heavier end vs. the other vendors on here and some are even making aluminum versions which are very lightweight. Before you spend the money twice, you might want to get the plate bumper/winch set-up nailed down, then figure out what coils you need to support the weight.
  8. Jul 6, 2011 at 11:20 AM
    GA_TACO4x4
    here 'n there
    07 DCSB 4x4
    im pretty set on the arb. ive seen all the other vendors on here but arb just looks the best and gives will suit my needs the best. and i plan on getting a winch just not right away...maybe closer to winter.
    ps i appreciate all your help and info mike!
  9. Jul 6, 2011 at 11:30 AM
    Pugga
    Massachusetts
    With that response, which would you choose, 885x or Eibach? 885's are under 600# but taller whereas the Eibachs are over the 600# mark but a shorter coil. Just curious as to what you'd choose and why?
  10. Jul 6, 2011 at 11:45 AM
    Pugga
    Massachusetts
    You're killing my logic! So the Eibachs are a short spring with a higher rate so they'll sag initially under the weight but shouldn't wear out as quickly afterwards. The OME 885's are taller and will sag initially to the OP's desired 2" lift but will eventually wear out more quickly than the Eibachs. The newer version of the 885's the 885x's are supposed to be made to resist sagging and fatigue and might stay up at the 2" a bit longer. Because the OME's are a taller coil with a lower spring rate, they'll ride softer with the weight of the bumper and winch on it. I think that about sums it up? Sounds like it's all about trade-offs...:cool:
  11. Jul 6, 2011 at 2:07 PM
    GA_TACO4x4
    here 'n there
    07 DCSB 4x4
    so im thinking eibachs @ .85 and top plate spacer if they sag too much, which i doubt b/c the higher rate
    :notsure:
  12. Jul 6, 2011 at 2:10 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Yes! My buddy has allpro front/rear and sliders with eibachs on 5100s and running 285/75/16. I'll put a pic up in a bit.
  13. Jul 6, 2011 at 2:17 PM
    GA_TACO4x4
    here 'n there
    07 DCSB 4x4
    thanks derek! whats your opinion on 885s with a bumper? since thats what u have
  14. Jul 6, 2011 at 3:35 PM
    GA_TACO4x4
    here 'n there
    07 DCSB 4x4
    i agree with what you're saying. thats why im shooting for around 2" of lift. im just tryin to find out how much they'll settle/sag.
  15. Jul 6, 2011 at 8:12 PM
    DWreck
    Derek
    Las Vegas, NV
    I'm at 0.85" right now. Thinking of bumping up to 1.75" if my cv joints allow it. It's still a little low and soft for my liking.
  16. Jul 6, 2011 at 8:23 PM
    DWreck
    Derek
    Las Vegas, NV
    Here's that pic I promised.
  17. Jul 7, 2011 at 7:38 PM
    GA_TACO4x4
    here 'n there
    07 DCSB 4x4
    both of these post are making me favor the eibachs. bump for new imput
  18. Jul 7, 2011 at 7:42 PM
    DWreck
    Derek
    Las Vegas, NV
    Ya. I kinda wish I went that route but what's done is done. I got a sweet deal on these 885s so f* it!
  19. Jul 8, 2011 at 3:24 PM
    GA_TACO4x4
    here 'n there
    07 DCSB 4x4
    ARB being the heavier one, right?
  20. Jul 8, 2011 at 4:08 PM
    DWreck
    Derek
    Las Vegas, NV
    Yes. Just for the record, it's not mine! Lol
    And yes. ARB is heavier by far.
