Eight Facts About Warming Up Your Car in Winter
Discussion in 'General Automotive' started by surfsupl, Jan 8, 2011.
  1. Jan 15, 2011 at 9:16 AM
    #161
    Sproulesxrunner
    Sproulesxrunner Well-Known Member
    Canada
    08 Xrunner
    Too much for TW to know
    I am only 16 so I can see why I never seen the ad haha. Right after I sent the first post I realized I forgot lawyer but I knew you had to a be a very well read person who is considerate to the environment, sensible and likes to teach... so I was pretty close on the guess. Thanks again for explaining it to me. I'll add it to my list of words.
  2. Jan 15, 2011 at 9:19 AM
    #162
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Its the same thing with cars. People should let them warm up atleast a little.
    Water moisture collects everywhere especially if it is freezing outside. At normal temp when you start your engine operating oil pressure goes from 4 psi at idle to 80 psi at 3000 rpms
    When is super cold you can get 80 at 1500 RPM so when you revup all the bypass valves open. and your oil filter have helluva work cut for it. There are two O-rings between the pump and filter that hold the seal.
    Now even if its not engine power steering pump has crap load of o-rings and much higher pressure to deal with. Rev up and its pushing oil through system like crazy. Cold oil again here will be hard on seals.
    It does npot take a lot to warm up to atleast when RPMS drop to below 1000 thats when ECT knows engine is almost at temp and engine bay gets warmer.
  3. Jan 15, 2011 at 9:21 AM
    #163
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  4. Jan 15, 2011 at 9:21 AM
    #164
    DanT
    DanT Old Member
    Dan
    Richland, WA
    4WD 2.7L SR5
    I'd definitely start with hot water on that one. :) Seriously. That would be a good example of how the water would not be contacting the cold glass.
    Also demonstrates why at some point, turning on windshield wipers is a good idea.
    You may have your theories, I have my experience.
  5. Jan 15, 2011 at 9:24 AM
    #165
    daftcon
    daftcon too many clowns, not enough circuses.
    François Dillinger
    places
    '05 PreRunner
    just about black everything. i don't dig the chrome.
    ^^do you think warm water would crack that super cooled windshield? i know it can crack thin glass, but what about that?
  6. Jan 15, 2011 at 9:26 AM
    #166
    DanT
    DanT Old Member
    Dan
    Richland, WA
    4WD 2.7L SR5
    And also the importance of a synthetic oil that is relatively thin at cold temperatures yet can also protect at operating temperature.
    If those who say 90% of engine wear occurs at startup are correct, then it is crucial to use an oil that has a low viscosity number at the traditional test temp of 40C. I wish data sheets included a viscosity number at 0C.
  7. Jan 15, 2011 at 9:30 AM
    #167
    daftcon
    François Dillinger
    places
    '05 PreRunner
    Lucas oil makes a petroleum additive that coats and seals your pistons long after you shut your engine down. allows for less wear on your engine on start up.
  8. Jan 15, 2011 at 9:33 AM
    #168
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    i would use a chisel and hammer....or a blow dryer:)
  9. Jan 15, 2011 at 9:33 AM
    #169
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    I do the 3-4 minute warmup idling-I did it with all the 14 vehicles I have owned and have never had engine issues on any of my vehicles. My folks did it when I was a kid their cars always mechanically perfect-like you say, it's a personal thing. That doesn't change the fact that I have had no engine issues using this practice. 14 vehicles under my care-no issues. This is MY opinion here-I personally will not throw a 4000lb load onto that drivetrain till that temp guage bumps:)
  10. Jan 15, 2011 at 9:39 AM
    #170
    daftcon
    François Dillinger
    places
    '05 PreRunner
    and thats another thing. oil temp gauges give you a minimum and maximum your oil should be at (an operating range if you will). if the temp rises above that top hash mark, it raises some eyebrows. why not treat it the same at the other end of the spectrum? just food for thought...
  11. Jan 15, 2011 at 9:41 AM
    #171
    DanT
    DanT Old Member
    Dan
    Richland, WA
    4WD 2.7L SR5
    Certainly. I agree with the notion there is risk. That is why I try to only pour warm or warmish to cold water on the ice, not on the glass. And I also agree that if you already have a crack in your windshield the risk goes up, way up. Even turning on the defroster increases this risk.
    The only time I've seen glass crack due to a temperature differential is when I've seen hot fat (much hotter than 212F) poured into a cheap jar sitting in cold water. Cracked perfectly right at the level of the hot oil.
    Windshield glass is tempered (the process involves subjecting the glass to quick changes of temperature) to strengthen it and laminated.
  12. Jan 15, 2011 at 10:18 AM
    #172
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Most of those addatives are "Snake oil". They do more harm than good. Modern oils leave a coat of oil on the suface as it is.
  13. Jan 15, 2011 at 10:34 AM
    #173
    Dilley
    Dilley Well-Known Member
    WA
    06 2.7L
    KN Cold air intake, Dynomax exaust, Husky liners
    Cold water seems to melt the ice almost as fast as warm water with almost no risk of cracking your window. unless you have a chip or something then I would get that taken care of first.
  14. Jan 15, 2011 at 10:36 AM
    #174
    08chocotaco
    08chocotaco Well-Known Member
    TAYLOR
    San Diego/Los Angeles
    2016 Silver TRD Sport
    No current modifications
    yahoo has wonderful articles
  15. Jan 15, 2011 at 10:55 AM
    #175
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    ya, it's just that the way you say it makes it sound like you're suggesting doing it some way other than just letting it idle.
  16. Jan 15, 2011 at 11:01 AM
    #176
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I am. Get in, start it up, and drive it.
  17. Jan 15, 2011 at 11:09 AM
    #177
    southpier
    southpier Well-Known Member
    yup; common sense!
  18. Jan 15, 2011 at 11:36 AM
    #178
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    On the other side of the coin,, who here lets it idle for just a bit before shutdown??,or do you just twist the key and get out?.
  19. Jan 15, 2011 at 11:40 AM
    #179
    BlueT
    NorthEast
    Rev up to 2000 then shutoff ( 2000 rpms = around 60 Psi of oil pressure ) That will leave some oil pressure even when engine is off for a second or two. Enough to cover things in oil before next startup
  20. Jan 15, 2011 at 12:06 PM
    #180
    40950
    CR, WA
    stock
    Interesting.
    Took my 22R valve cover off once to examine the oil flow at idle. had a HUGE mess pouring over both fenders before I could get in the truck and shut it down:rolleyes:. Kinda amazing acctually. It's a high speed blender in there, just at idle.
    Anyone else??
