El Taco Diablo... Mall Crawlin, now with LT for tall curbs
Discussion in '1st Gen. Builds (1995-2004)' started by El Taco Diablo, Dec 12, 2017.
  1. Mar 19, 2022 at 8:49 PM
    #801
    El Taco Diablo
    El Taco Diablo [OP] Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    4600 / Stock Class
    Engine/trans has to have been available in make model year.
    Leafs have to stay leafs, coilover have to stay coilovers.
    Max 35 inch tire DOT approved comercially available tires.
    Max 14 inch travel. 1 shock per corner, no byoass shocks.
    No forced induction unless factory equipped
    Fenders have to remain "factory look" cuts for tire clear cant be mor than 2 inch gap from tire stuffed.
    No bobtailing it
    unstpible and Empty_Lord like this.
  2. Mar 19, 2022 at 8:52 PM
    #802
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    So no SAS and stock leaf spring mounts / uca and lca pivot points?
    Edit:
    • Stock OEM Frame
    • Factory Engine
    • Factory Transmission
    • 35” DOT approved tires
    • Single 2.5 inch diameter shocks per corner
    • Mechanical Steering
    unstpible likes this.
  3. Mar 19, 2022 at 8:54 PM
    #803
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Leaf mounts can change but still have to be leafs.
    UCA and LCA pivot points could theoretically change, but it still would have to remain IFS coilover.
    There are limits though to stretching or lessening wheelbase.
  4. Mar 19, 2022 at 8:55 PM
    #804
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Hmm so stock frame =/= pivot points?
  5. Mar 19, 2022 at 8:56 PM
    #805
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Definately must be stock frame. I believe it also talks about factory cross members.
    unstpible and Dalandser[QUOTED] like this.
  6. Mar 19, 2022 at 9:06 PM
    #806
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    14" of travel will get you in LT travel territory and I'm not sure what you'll benefit from more with more up travel or under-axle clearance out back, but SUA will be in the neighborhood of 14" if you strap it or bump it early. Does the track width have to be stock?
  7. Mar 19, 2022 at 9:13 PM
    #807
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Track width does not have to be stock. LT would be a definate on this build.
  8. Mar 21, 2022 at 6:42 PM
    #808
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    unstpible, Impoy47, essjay and 3 others like this.
  9. Mar 21, 2022 at 9:12 PM
    #809
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
  10. Mar 22, 2022 at 9:24 AM
    #810
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I've been thinking about adding one of those. It looks like that one straps on top of your existing mirror?
    How heavy is it/ how much weight does it add to the regular mirror?
  11. Mar 22, 2022 at 9:28 AM
    #811
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    It's not that heavy. I think it's just a little heavier than my Samsung S9. I tightened the set screw on the back of the actual mirror so the weight of this mirror doesn't pull it down.
  12. Mar 22, 2022 at 9:28 AM
    #812
    betterbuckleup
    Ian
    Concord, CA
    Oh ok. So it has an attachment mechanism that doesn't let the mirror flop around from the extra weight?
  13. Mar 22, 2022 at 9:31 AM
    #813
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    The straps it uses to strap to the existing mirror are rubber, so it keeps the screen from moving around on the existing mirror.
    The existing mirror has a set screw on the back that if tightened makes the mirror much harder to adjust (I.E. much harder for it to sag from the added weight of the screen)
  14. Mar 22, 2022 at 9:31 AM
    #814
    betterbuckleup
    Ian
    Concord, CA
    Gotcha. Wasn't aware of that screw.
    You got a link?
  15. Mar 22, 2022 at 9:36 AM
    #815
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
  16. Mar 22, 2022 at 11:02 AM
    #816
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    nice! been thinking about getting something similar to replace my rear view mirror. not like I can see anything out of the back window these days. Main thing stopping me is getting lazy just thinking about having to run the wires from the mirror to the camera. ha
  17. Mar 22, 2022 at 11:07 AM
    #817
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Ya... I had this thing sitting on my work bench since the 1st of the year... because I didn't want to have to screw with running the wires through the headliner. :rofl:
    The rear view camera has been mounted since I re-built the rack, because I wanted all that wiring in side the rack, instead of being exposed. I had just ran it down and left the plug behind the passenger tail light, until I got around to finishing it.
    unstpible and rob1208[QUOTED] like this.
  18. Mar 22, 2022 at 9:20 PM
    #818
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Welp... I got my answer from Ultra4.
    Supercharger is a no go
  19. Mar 22, 2022 at 9:32 PM
    #819
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Save money on a stock crank
  20. Mar 22, 2022 at 10:02 PM
    #820
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Think I'm still going to do a forged crank if I can find a good one.
    No supercharger should save me a couple thousand bucks lol
