El Taco Diablo... Mall Crawlin, now with LT for tall curbs
Discussion in '1st Gen. Builds (1995-2004)' started by El Taco Diablo, Dec 12, 2017.
  1. Apr 15, 2023 at 8:23 PM
    #1281
    El Taco Diablo
    El Taco Diablo [OP] Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Notes for me:
    1st gen Tacoma rear axle = 60.75
    T100 rear axle = 66.75
    1st gen Tundra rear axle = 66.75
    After long travel, at ride height my front is 67.375 (67 3/8)
    I'm thinking 66 inch rear axle will work.
    81 wms to wsm - 66 = 15 --> 7.5 off each side
    IF
    The third member is not offset in the housing. I need to find out if where the axle spines on the third member are even on both sides. I want to be able to carry just 1 spare axle shaft.
    unstpible and Dan8906 like this.
  2. Apr 16, 2023 at 7:24 AM
    #1282
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Why 66 and not matching the front? What axle shafts are you going to be running?
  3. Apr 16, 2023 at 7:58 AM
    #1283
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Most truck rear ends are slightly more narrow than the front. Tracts better that way.
    Dan8906 and El Taco Diablo[OP] like this.
  4. Apr 16, 2023 at 9:59 AM
    #1284
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    100% what @nDub said.
    RCV shafts
    Dan8906[QUOTED] likes this.
  5. Apr 18, 2023 at 9:46 PM
    #1285
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    This wasn't my favorite thing... but it's done.
    Tapped 10 holes in 3/8 plate... Helicoil... now the bolts fit. :thumbsup:
    Littles, rob1208 and nDub like this.
  6. Apr 21, 2023 at 4:19 PM
    #1286
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Dropped by Yota1 today to pick up some replacement (hub) studs for the rear axle build, and some other odds and ends. There were a couple broken hub studs on the Toyota Truck IFS hubs I bought... easy fix.
    But these were hanging there on the shelf and calling out to me.
    Gotta love buying parts for the next project before you're halfway done with this project.
    :rofl:
    And also... Brown Santa brought me more goodies from Front Range Offroad. :thumbsup:
  7. Apr 23, 2023 at 8:40 PM
    #1287
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Well that was about 1 million percent harder than I thought it would be. But the third member is finally fitted to the housing :thumbsup:
    Had to ream out the bolt holes in the third member to get it end up fitting in place, but now it's snug like it should be. About 20 test fits and stepping the holes up 1/32 at a time was a time consuming pain in the ass... and the difference between an 8 inch and 9.5 inch 3rd is HEAVY lol
    CemenTRDgen, essjay and rob1208 like this.
  8. Apr 23, 2023 at 10:12 PM
    #1288
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Also, got the broken hub studs replaced. Test fit the drive flanges, everything rolls smoothly.
    Then I found out a bought an entire box of lug studs that don't seem like they are going to work. Was looking to do longer studs, but these seem like they are too big at the knurl to work here. Somehow I'm not suprised.
  9. Apr 26, 2023 at 9:16 AM
    #1289
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Which studs did you get?
  10. Apr 26, 2023 at 9:34 AM
    #1290
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    The ones in the box, shown. 610-463 Dorman.
    The shoulder of the stud (beginning at the yellow line) is bigger than the knurl on the old studs.
  11. Apr 26, 2023 at 9:43 AM
    #1291
    slander
    Hickory, NC
    Going to sound like a dick here, but did you actually try to pound them in? I have the same studs and the same hubs and they hammered on in.
    If you just look at them they look like they don't fit.
  12. Apr 26, 2023 at 9:49 AM
    #1292
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I haven't tried yet. I pushed them in to the shoulder and tapped on it a couple times. It didn't want to go at all... and then, you still have to press the knurl which is even bigger. I threw the studs in the freezer, when I have time, I'll see if that makes any difference.
    You didn't sound like a dick lol
    slander[QUOTED] likes this.
  13. Apr 26, 2023 at 9:56 AM
    #1293
    slander
    Hickory, NC
    Ok LOL!! Yea they weren't any harder to install than any other studs, obviously they are supposed to be tight as hell in there.
  14. Apr 26, 2023 at 10:01 AM
    #1294
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Ya, I've installed quite a few studs over the years. These seem like they are tighter than they should be. And the tightness starts WAY before the knurl. That shoulder should push through with a little resistance and then it should be tight at the knurl. That's not what it's doing.
  15. Apr 26, 2023 at 10:09 AM
    #1295
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    So I have another question. And I just want to make sure I'm not under thinking this. Normally, I have a habit of over thinking things, and now I may be overthinking, thinking I'm under thinking :rofl:
    Ok... The suspension NOW is at the ride height I want. The pinion angles are good. I have no vibrations.
    When I install the new axle, I will also be swapping to Chevy 63s... BUT... I will be making sure to stay at THIS ride height.
    When I'm looking to set the pinion angle on the new axle. I.E. mock up the leaf perches at the angle they need to be relative to the mounting face on the 3rd member.
    Since I am going to stay at the same ride height (or as close to it as possible) I should just be able to copy my current leaf perch angle to the 3rd mounting surface and copy that to the new axle... No?
    @ToyRyd04 @slander @Speedytech7 @cbechtold @Robmonster117 @foxrcing07
  16. Apr 26, 2023 at 10:22 AM
    #1296
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    I'd personally moch up the rear axle and measure everything out before you weld anything in place.
  17. Apr 26, 2023 at 10:24 AM
    #1297
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Ya... trying to avoid having the truck down for the period of time that would take. It's currently my daily.
    But that would be the optimum way to do this, for sure.
  18. Apr 26, 2023 at 10:35 AM
    #1298
    cbechtold
    Cory
    Pleasanton, CA
    I definitely get that. I had to schedule some time off work so I could work on my steering rack in May.
  19. Apr 26, 2023 at 10:48 AM
    #1299
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Nope 63s have a different spring rate than your current pack, and then the shackle angle will also dictate ride height/spring rate.
    3 day weekend type job without a car lift.
    Day 1 Tear Down/Tack up front hangers/spring perches
    Day 2 Adjust rear shackle closer/farther with weight on axle/pinion angle
    Day 3 Finish welding/shock mount cycling/final install
    Biggest time consuming will be locating the rear shackle mount. On the forum here I've seen guys relocating the front hanger forward between 6-8" (mine was 7.75).
    This is going to set where your center pin will sit in the rear wheel arch. Rear shackle mount will increase (closer to front) / decrease (farther from front) your spring rate/ride height.
    ***Also dependent on shackle length***
    Speedytech7 likes this.
  20. Apr 26, 2023 at 10:58 AM
    #1300
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I get all that. I'm just trying to set the spring perches on my actual axle right now. Totally know the truck is going to be down for the 63 swap (with axle swap as well) But I'm trying to get the axle built so when I'm doing the swap I'm not swapping leafs and (frame perches) AND building an axle all at the same time.
